97 90 05
97 90 05
    KNIPEX(凯尼派克)
    KNIPEX - 97 90 05 - Box of Assorted Ferrules for use with 97 71 180 Crimping Pliers
97 90 05 数据手册
97 90 05 Crimp Assortment for end sleeves (ferrules) ● ● ● ● ● ● ● Article No. 97 90 05 EAN 4003773025535 200 end sleeves each mm² 0,5 / 0,75 / 1,0 / 1,5 / 2,5 150 end sleeves each mm² 4,0 / 6,0 50 end sleeves each mm² 10,0 / 16,0 Net weight g 930 In a TANOS MINI-systainer® (solid plastic box) T-Loc fastener for one-handed operation: open or close the systainer® with one turn and connect to a second systainer® Opening when connected: fast and simple access to content without disconnecting Two stackable plastic inserts with 6 trays each for connectors With an assortment of end sleeves (ferrules) with/without collar With Crimping Pliers for end sleeves 97 71 180 End sleeves (ferrules) without collar technical change and errors excepted systainer® is a registered trademark of TANOS GmbH Content 97 90 05 (10) Article No. 97 71 180 Quantity Crimping Pliers for end sleeves (ferrules) 1 Non-insulated End Sleeves (ferrules), 30 / 16 mm 200 25 mm² Non-insulated End Sleeves (ferrules), 6 mm 200 0,75 mm² Non-insulated End Sleeves (ferrules), 6 mm 200 1 mm² Non-insulated End Sleeves (ferrules), 7 mm 200 1,5 mm² Non-insulated End Sleeves (ferrules), 7 mm 200 2,5 mm² Non-insulated End Sleeves (ferrules), 9 mm 150 4 mm² KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 1 Non-insulated End Sleeves (ferrules), 12 mm 150 6 mm² Non-insulated End Sleeves (ferrules), 12 mm 50 10 mm² Non-insulated End Sleeves (ferrules), 12 mm 50 16 mm² KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 2
97 90 05 价格&库存
很抱歉,暂时无法提供与“97 90 05”相匹配的价格&库存,您可以联系我们找货
