99 14 250
99 14 250
    KNIPEX(凯尼派克)
    KNIPEX - 99 14 250 - Cutter, 250 mm, Edge, 3.3 mm, 61 °
99 14 250 数据手册
99 14 250 High Leverage Concreters’ Nipper high lever transmission ● ● ● ● ● ● ● ● Article No. 99 14 250 EAN 4003773071419 Pliers bright zinc plated 25 % less effort required compared to conventional concreters’ nippers of the same size Extra-slim form for tying deep mounted steel rods To lace concrete reinforcing steel with binding wire from a roll Wire is twisted and cut in a single pass High-leverage joint, minimising strain, even when thick binding wires are used The high damping of the cutting stroke on cutting through the binding wire reduces the strain on tendons and muscles Cutting edges additionally hardened; cutting edge hardness approx. 61 HRC High-grade special tool steel, forged, multi stage oil-hardened Head Handles Cutting capacities medium hard wire (diameter) Ø mm 3,3 Cutting capacities hard 1,8 wire (diameter) Ø mm Head width mm 25,0 Length mm 250 Net weight g 350 technical change and errors excepted KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 1
99 14 250 价格&库存
很抱歉,暂时无法提供与“99 14 250”相匹配的价格&库存,您可以联系我们找货
