9R 471 900 3
9R 471 900 3
    KNIPEX(凯尼派克)
    KNIPEX - 9R 471 900 3 - SCREW EXTRACTOR SET, 1-5 SIZE
9R 471 900 3 数据手册
Double-Edged Screw Extractors from Rennsteig Patent Pending Product Specification • f or unscrewing damaged screws and bolts without damaging threads • for both right and left handed threads • non-slip and double-edged engagement with the screw being removed The Double-Edged Screw Extractor represents a new generation of its kind used to remove damaged screws or bolts out of threads. Centering point for centering of bore Cutting edges for non-slip engagement The Screw Extractors have four double-edged cutting edges. Only the two opposite edges engage with the screw to be removed. This technology is perfect for use with both right and left handed threads. Application  the screw / bolt to be removed by using the • mark centering point of the Screw Extractor  the screw / bolt by boring with an adequate drill • open • drive the Screw Extractor into the bore hole until the cutting edges are in full contact with the object Hexagonal driving flat for optimum torque  a wrench to remove the object out of the thread • use hole by turning the screw extractor clockwise or counterclockwise  unscrewing, remove the damaged screw / bolt • after from the Screw Extractor RENNSTEIG Rennsteig is a division of the KNIPEX Group that specializes in the manufacturing and development of high quality tools. For over 30 years, Rennsteig has been manufacturing products designed for maximum performance, ease of use and long life. 2035 S. Arlington Heights Rd., Suite 110, Arlington Heights, IL 60005 | 847.398.8520 • 847.398.8526 (fax) | www.knipex-tools.com KNIPEX Quality – Made in Germany Double-Edged Screw Extractors from Rennsteig Range of Delivery The Double-Edged Screw Extractor is available in 7 different sizes! sw Art.-No. Drill Ø mm Screw Sizes sw Drill Ø Inch Screw Sizes Inch Size mm min max min max Inch min max min max ounces 9R 471 001 3 1 6.3 3.2 4.8 M5 M6 1/4” 1/8” 3/16” 10” 1/4“ 0.3 10 9R 471 002 3 2 10 4.8 7.1 M8 M10 3/8” 1/4” 9/32” 5/16” 3/8” 0.6 10 9R 471 003 3 3 13 6.4 9.5 M10 M12 1/2” 1/4” 3/8” 7/16” 1/2” 1.2 10 9R 471 004 3 4 16 8.7 12.7 M12 M16 5/8” 11/32” 1/2” 1/2” 9/16” 2.0 10 9R 471 005 3 5 19 11.1 15.9 M16 M20 3/6” 7/16” 5/8” 5/8” 3/4” 3.1 10 9R 471 006 3 6 22 14.3 19.1 M20 M24 7/8” 9/16” 3/4” 7/8” 1” 4.6 5 9R 471 007 3 7 26 19.1 23.8 - M30 1” 3/4” 15/16” 1” >1” 7.2 5 Packaging Options Individual Item in Transparent Plastic Case Size 1-5 in Vinyl Pouch Art.-No. 9R 471 900 3 Size 1-5 in Metal Case Art.-No. 9R 471 900 3 2035 S. Arlington Heights Rd., Suite 110, Arlington Heights, IL 60005 | 847.398.8520 • 847.398.8526 (fax) | www.knipex-tools.com KNIPEX Quality – Made in Germany
9R 471 900 3 价格&库存
很抱歉,暂时无法提供与“9R 471 900 3”相匹配的价格&库存,您可以联系我们找货
