13 92 200
13 92 200
    KNIPEX(凯尼派克)
    KNIPEX - 13 92 200 - 200mm Multifunctional Pliers with Activated Locking Lever and Latching Mechanis...
13 92 200 数据手册
13 92 200 Pliers for Electrical Installation ● ● ● ● ● ● ● ● ● ● ● ● Article No. 13 92 200 EAN 4003773075103 Pliers black atramentized Head polished Handles with multi-component grips 6 functions in one pair of pliers Multifunctional pliers for the electrical installation; to grip flat and round material, for bending, deburring, cutting cable, stripping and crimping end sleeves (ferrules) Smooth surfaces near the tips grip single cores without damaging them; serrated gripping surfaces and pipe grip for gripping flat and round material Clear-cut outside edge on the jaw for working on flush-mounted junction boxes and deburring feed-through holes Stripping holes for conductors of 0.75 - 1.5 mm² and 2.5 mm² Crimp die for wire-end ferrules 0.5 - 2.5 mm² Cable shears with (induction-hardened) precision cutting edges for copper and aluminium cables up to 5 x 2.5 mm² / dia. 15 mm Slim dimensions for easy access Bolted joint: precise, zero backlash operation of pliers High-grade special tool steel, forged, multi stage oil-hardened In case of models with opening spring integrated in the joint, the activated locking lever keeps the cutting edges closed while other functions remain active The intelligent latching mechanism enables you to "grip" without opening the pliers. The cutting edge remains closed and protected. Cutting capacity copper cable, multiple15 stranded (diameter) Ø mm Cutting capacity copper cable, multiple- 50 stranded mm² Stripping capacity for cross-sections mm² 0,75 - 1,5 + 2,5 Capacity in square millimetres mm² 0,5 - 2,5 AWG 1/0 Length mm 200 Net weight g 280 technical change and errors excepted KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 1
13 92 200 价格&库存
很抱歉,暂时无法提供与“13 92 200”相匹配的价格&库存,您可以联系我们找货
