90 25 40
90 25 40
    KNIPEX(凯尼派克)
    KNIPEX - 90 25 40 - Cutter, Pipe & Conduit, 40 mm Pipe Diameter Max, 210 mm Length
90 25 40 数据手册
Product information 90 25 40 ● For cutting thick walled plastic and composite pipes with diameters from 26.0 to 40.0 mm ● Cuts pipes using the ratchet principle in several strokes ● Self-adapting pipe support positions pipes of various diameters correctly for a rectangular cut ● Blades: special tool steel, oil-hardened, interchangeable ● Tool body: high-grade chrome vanadium electric steel, oil-hardened Pipe Cutter For composite and plastic pipes General Article No. 90 25 40 EAN 4003773045182 Pliers galvanized Handles with multi-component grips weight 500 g Dimensions 210 x 100 x 28 mm Technische Attribute Cutting capacities composite pipes (diameter) Ø 26 – 40 mm Blade length 40 mm Classification eCl@ss 5.1.4 21040601 ETIM 5.0 EC000148 ETIM 6.0 EC000148 proficl@ss 6.0 AAB927c006 UNSPSC 13.1 23151901 technical change and errors excepted KNIPEX Werk - C. Gustav Putsch KG - 42337 Wuppertal 09.03.2020 | page 1 2 KNIPEX Werk - C. Gustav Putsch KG - 42337 Wuppertal 09.03.2020 | page 2 2
90 25 40 价格&库存
很抱歉,暂时无法提供与“90 25 40”相匹配的价格&库存,您可以联系我们找货
