29452
29452
    GREENLEECOMMUNICATIONS(格林利)
29452 数据手册
Line Up and Punch Out! With the new Greenlee Slug-Splitter SC™, the tool does the work... Introducing the upgraded Greenlee Slug-Splitter SC ™ Knockout. Punch through stainless steel in less time and with less potential for errors or alignment problems. What's changed with the new knockout? If you're interested in making sure your holes are perfectly centered, we've added a self-centering feature. This new feature greatly simplifies conduit hole and pilot device alignment. Just tighten down the punch on your draw stud and let our new punch center itself on the pilot hole. No more trying to line up the die alignment marks in poor lighting conditions or drawing crosshairs on the box to ensure alignment. Greenlee has once again given you a tool designed to make your job easier. • Save time and ensure accuracy! Self-centering punch aligns itself on pilot hole. • No need to draw crosshairs or line up die alignment marks. • Punch 16 gauge stainless steel with a ratchet driver. • Unique, patent pending punch profile also splits slugs for easier slug removal. PUNCH PUNCH CAT./UPC NO. 28154 28156 36490 28158 28160 28162 28165 DIE HOLE SIZE DIE CONDUIT ACTUAL CAT./UPC NO. & PIPE Ø (INCH) Ø (MM) 28155 1/2" 7/8 .885 22.5 28157 3/4" — 1.115 28.3 36489 — 1-7/32 1.210 30.5 28159 1" 1-11/32 1.362 34.6 28161 1-1/4" 1-11/16 1.701 43.2 28163 1-1/2" 1-15/16 1.951 49.6 28166 2" 2-3/8 2.416 61.5 DRAW STUDS PG 16 21 — — — — ISO — — — — — — — — CAPACITY DRAW STUDS STAINLESS STEEL HYDRAULIC DRIVERS RATCHET DRIVER* GA. (MM) 7804/7904 7646/7625 1904 10 3.5 29451 29451 30227 10 3.5 31872 29452 12098 10 3.5 31872 29452 12098 10 3.5 31872 29452 12098 10 3.5 31872 29452 12098 10 3.5 — 29452 12098 10 3.5 — 29452 12098 * 16 ga. stainless steel capacity with ratchet driver. DISTRIBUTED BY MA-4608 09/04
29452 价格&库存
很抱歉,暂时无法提供与“29452”相匹配的价格&库存,您可以联系我们找货
