231
231
    GREENLEECOMMUNICATIONS(格林利)
    PLIERS NEEDLE NOSE 5"
231 数据手册
PUNCH UNIT - CONNECTOR 15 PIN (231) Electronic Connector Panel Punches Cat No: 231 UPC No: 783310344377 Description • • • • • Cut-out and mounting slots are punched in one operation Drill only one 7/16" (11.1 mm) pilot hole. (use with Kwik Stepper® step bits.) Fast, accurate panel punching with no sawing or filing required Universal size punches for front or back mount of TRW Cinch and ITT Cannon-type or equivalent connectors in 9, 15, 25, 37 or 50-pin configurations U.S. Patent No. 4,899,447 Specifications • • • • • • • Capacity : ƕ 16 GA (1.500 MM) Mild Steel ƕ 10 GA (3.500 MM) Aluminum No. Of Pins : 15 Operation Type : ƕ Manual with Wrench ƕ Quick Draw® and Quick Draw 90® Hydraulic Drivers, Battery Driver, Ram And Pump Hydraulic Drivers Aluminum Replacement Part : 34442 Punch, 35197 Die Unit, 34421 Draw Stud, 04638 Square Counter Nut, 34733 Drive Nut Size : 1.127 IN X 1.309 IN X 0.469 IN (28.600 MM X 33.300 MM X 11.900 MM) Type : Electronic Connector Panel Weight : 1.500 LB (0.680 KG)
很抱歉,暂时无法提供与“231”相匹配的价格&库存,您可以联系我们找货
  • 1+9719.724821+1263.53278
