77M-G
77M-G
    GREENLEECOMMUNICATIONS(格林利)
77M-G 数据手册
www.greenlee.com 701K-G Professional TONE TRACING KIT Trace Faster • Use two distinct tone signatures to trace telephone, data, and security cables faster Work Easier • LED brightness indicates received signal strength • Three listening modes: speaker, headset, or butt-in telephone Stay Safe • Enhanced voltage protection (up to 150 V DC) Designed and assembled in USA. USA PHONE 800.435.0786 FAX 800.451.2632 CANADA PHONE 866.384.8813 FAX 800.524.2853 INT’L PHONE +1.815.397.7070 FAX +1.815.397.9247 701K-G PROFESSIONAL TONE TRACING KIT For product videos, demonstrations and more, scan this QR code or visit: www.youtube.com/GreenleeDEMO FEATURES • Industry standard tracing for voice, data, and video wiring • Headset and Adjustable Gain Control (200EP-G) • LED Worklight - view behind furniture, inside racks, and other dim lighting conditions. • LED Tone Proximity Indicator illuminates brighter the closer you get to the correct pair (closer to the tone). • Detect Faults – one or two line telephone service, voltage/polarity and shorts/continuity (77HP-G) • Distinct Tracing Signatures – two warble tones available for easier tracing. • Enhanced Voltage Protection – up to 150 V DC. • Metal or Plastic Tips – Choose the best tip for the job. • Includes: modular plug, alligator test leads, RJ11/45 socket adaptor, 77HP-G Tone Generator, and 200EP-G Tracing Probe. • Designed and assembled in USA. SPECIFICATIONS Probe Specifications (200EP-G) Gain (nominal): Input Impedance (nominal): Metal Tip Resistance: Plastic Tip Resistance: Headset: Battery: Battery Life (nominal): Length: Width: Depth: Weight: Operating/Storage Temperature: 30 db 100 MΩ 0Ω 300Ω 3.5 mm sterio plug; 8 ohms minimum One 9 VDC (NEDA 1604, JIS 006P, or IEC 6LR61) >50 hours 231 mm (9.0”) 55 mm (2.2”) 28 mm (1.1”) 145 g (5.2 oz) 0 °C to 50 °C (32 °F to 122 °F) Tone Specifications (77HP-G/6A) Talk Battery (into 600Ω): Output Power (into 600Ω): Resistive Short Visual Indication: Resistive Short Audio Indication: Output Frequency (nominal) Voltage Protection (into 600Ω): Battery: Battery Life: Length: Width: Height: Weight (max): Operating Temperature: Storage Temperature: 4.6 VDC +10 dBm
77M-G 价格&库存
很抱歉,暂时无法提供与“77M-G”相匹配的价格&库存,您可以联系我们找货
