438-5H
438-5H
    GREENLEECOMMUNICATIONS(格林利)
438-5H 数据手册
FRED CUNNINGHAM Electrician F I S H I N G , C A B L E P U L L I N G & M AT E R I A L H A N D L I N G No matter where or how far you need to fish and pull cable, Greenlee has the tools to get the job done. • Cable pullers reduce strain and down-time from injuries • Cable feeder automatically pays out cable from reels to reduce physical strain • EZ Reach™ products designed to go where standard fish tapes can’t • Effectively fish through drop ceilings, insulation-packed walls and below carpet to improve fishing speed EZ Reach™ Stix 90 EZ Reach™ Tape USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com Silver Streak® Stainless Steel Fish Tapes CAT. NO. UPC NO. DESCRIPTION 438-10SS 06408 100' x 1/8" x .060 (30.5 m x 3.2 mm x 1.5 mm) Stainless Steel Fish Tape with Case 438-20SS 06410 200' x 1/8" x .060 (61 m x 3.2 mm x 1.5 mm) Stainless Steel Fish Tape with Case SPECIFICATIONS Capacity 1/8" (3.2 mm) tape width – 400 lbs. (1.7 kN) maximum design strength. 438-10SS Weight 438-10SS – 5 lbs. (2.3 kg) 438-20SS – 7 lbs. (3.2 kg) Nylon Fish Tapes 436-5 (12" Case) • High-impact nylon, one-piece handle for maximum durability, long life, and easy comfortable use. • Co-extruded curl resistant nylon fish tape that fishes equally well in large and small conduit. • Heavy-duty winder case. CAT. NO. UPC NO. DESCRIPTION 436-5 27396 50' x 3/16" (15.2 m x 4.8 mm) diameter Nylon Fish Tape in Winder Case 436-10 27397 100' x 3/16" (30.5 m x 4.8 mm) diameter Nylon Fish Tape in Winder Case R436-5 36850 50' x 3/16" (15.2 m x 4.8 mm) diameter Nylon Fish Tape without Winder Case R436-10 36849 100' x 3/16" (30.5 m x 4.8 mm) diameter Nylon Fish Tape without Winder Case 01664 01664 Replacement tip NOTE: Requires Greenlee K05 or K09 series crimper to install. 39790 39790 One Piece Handle 39791 39791 12" diameter Replacement Case F I S H I N G , C A B L E P U L L I N G & M AT E R I A L H A N D L I N G • SILVER STREAK® comes with either 100' (30.5 m) or 200' (61 m) of stainless steel fish tape. It’s rust and corrosion-resistant so it lasts longer and rewinds easier than ordinary tape. It won’t leave a nasty residue, either. • Equipped with SPEED FLEX™ leader, silver-soldered onto the fish tape. Streamlined fish tape/leader connection and lightweight, flexible leader design combine to enable user to fish farther, faster. • High-impact nylon, one-piece handle for maximum durability, long life, and easy, comfortable use. • Large handle grip for greater user control. • Self-tensioning case for easy tape winding. (No tension trigger.) SPECIFICATIONS Capacity 3/16" (4.8 mm) diameter – 250 lbs. (1.1 kN) maximum design strength Weight 436-5 – 2 lbs. (0.9 kg) 436-10 – 3 lbs. (1.4 kg) R436-5 – 1 lb. (0.5 kg) R436-10 – 2 lbs. (0.9 kg) NOTE: Rope is a very critical link in the cable pulling system. See pages 102 & 103 for proper pulling rope selection. 91 USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com F I S H I N G , C A B L E P U L L I N G & M AT E R I A L H A N D L I N G Fiberglass Fish Tapes • 12" (305 mm) case has high-impact nylon, one-piece handle for maximum durability, long life, and easy, comfortable use. • Non-conductive fiberglass tape with low friction coating. • Has unique non-coiling properties that enable it to fish in large and small conduit equally well, even with wire or cable in place. • Exclusive, unique, lightweight reel for easy positive feed out and rewind. • Excellent for installation of telecommunications and data communication cables in overhead plenums, above suspended ceilings and under floors. • Fiberglass fish tape is the fastest manual fish tape available. It is intended for fishing only. Rope or line is recommended for pulling. 540-50, 540-100 (12" Case) CAT. NO. UPC NO. DESCRIPTION 540-50 35742 50' x .175" (15.2 m x 4.4 mm) Fiberglass Fish Tape in Winder Case 540-100 35743 100' x .175" (30.5 m x 4.4 mm) Fiberglass Fish Tape in Winder Case 542-150 35745 150' x 3/16" (45.7 m x 4.8 mm) Fiberglass Fish Tape in Reel Stand 542-200 35746 200' x 3/16" (61 m x 4.8 mm) Fiberglass Fish Tape in Reel Stand 542-250 35747 250' x 3/16" (76.2 m x 4.8 mm) Fiberglass Fish Tape in Reel Stand R540-100 35744 100' x 1/8" (30.5 m x 3.2 mm) Fiberglass Fish Tape without Case 05156 05156 150' x 3/16" (45.7 m x 4.8 mm) Fiberglass Fish Tape without Case 05157 05157 200' x 3/16" (61 m x 4.8 mm) Fiberglass Fish Tape without Case 05158 05158 250' x 3/16" (76.2 m x 4.8 mm) Fiberglass Fish Tape without Case 10565 10565 .175" (4.4 mm) pulling eye repair kit, includes (1) pulling eye and adhesive. 35750 35750 Accessory Kit for 3/16" (4.7 mm). Includes flexible pulling leader, flexible pushing leader, pulling eye, splice ferrule and threaded ferrule 35908 35908 1/8" (3 mm) Repair Kit – includes threaded end ferrule, splice ferrule and pulling eye. 35909 35909 3/16" (4.7 mm) Repair Kit 35919 35919 1/8" (3 mm) Pulling Eye 35930 35930 3/16" (4.7 mm) Pulling Eye 39790 39790 One piece handle 39791 39791 12" (305 mm) Diameter Replacement Case 39799 39799 Retrofit Kit to convert 540-50/35742 Fish Tape to onepiece design; includes one-piece handle and retaining strap, winder case and assembly screws 39800 39800 Retrofit Kit to convert 540-100/35743 Fish Tape to onepiece design; includes one-piece handle and retaining strap, winder case and assembly screws 542 SPECIFICATIONS 92 Capacity 540 Series – .175" (4.4 mm) dia. – 400 lbs. (1.7 kN) maximum design strength 542 Series – 3/16" (4.7 mm) dia. – 300 lbs. (1.3 kN) maximum design strength Weight 540-50 – 1.8 lbs. (0.8 kg) 540-100 – 2.1 lbs. (1 kg) R540-100 – 1.2 lbs. (0.6 kg) 542-150 – 15 lbs. (6.8 kg) 542-200 – 16 lbs. (7.2 kg) 542-250 – 17 lbs. (7.7 kg) USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com Steel Fish Tapes 438-10, 438-20, 538-10 (12" Case) 438-5 (8" Case) CAT. NO. UPC NO. DESCRIPTION 438-5 29045 65' x 1/8" x .060" (19.8 m x 3.2 mm x 1.5 mm) Steel Fish Tape in Winder Case 438-5H 07500 50' x 1/8" x .045" (15.2 m x 3.2 mm x 1.1 mm) Steel Fish Tape in Winder Case 438-10 28256 125' x 1/8" x .060" (33 m x 3.2 mm x 1.5 mm) Steel Fish Tape in Winder Case 438-20 29046 240' x 1/8" x .060" (73 m x 3.2 mm x 1.5 mm) Steel Fish Tape in Winder Case R438-5 29047 50' x 1/8" x .060" (15.2 m x 3.2 mm x 1.5 mm) Steel Fish Tape without Winder Case R438-10 28257 100' x 1/8" x .060" (30.5 m x 3.2 mm x 1.5 mm) Steel Fish Tape without Winder Case R438-20 29048 200' x 1/8" x .060" (61 m x 3.2 mm x 1.5 mm) Steel Fish Tape without Winder Case 538-10 30394 100' x 1/4" x .060" (30.5 m x 6.4 mm x 1.5 mm) Steel Fish Tape in Winder Case R538-10 30395 100' x 1/4" x .060" (30.5 m x 6.4 mm x 1.5 mm) Steel Fish Tape without Winder Case R538-20 30396 200' x 1/4" x .060" (61 m x 6.4 mm x 1.5 mm) Steel Fish Tape without Winder Case R438B 29367 Swivel Ball Head for use on steel fish tapes R438-BM 05853 Ball Tip Male Half 439-1 30859 12" (305 mm) Flexible Fish Tape Leader 39790 39790 One Piece Handle 39791 39791 12" (305 mm) Diameter Replacement Case SPECIFICATIONS Capacity 1/8" (3.2 mm) and 1/4" (6.4 mm) tape width – 400 lbs. (1.7 kN) maximum design strength. F I S H I N G , C A B L E P U L L I N G & M AT E R I A L H A N D L I N G • High-impact nylon, one-piece handle for maximum durability, long life, and easy, comfortable use. • Large handle grip for greater user control. • Self-tensioning case for easy tape winding. (No tension trigger.) • Wide, impact-resistant rewinder case with viewports to ensure tape fit and retaining strap on inside to hold tape secure. • Dirt-free tape finish keeps hands cleaner during use. Weight 438-10 – 5 lbs. (2.3 kg) R438-10 – 3 lbs. (1.4 kg) R538-10 – 6 lbs. (2.7 kg) 438-20 – 7 lbs. (3.2 kg) R438-20 – 6 lbs. (2.7 kg) R538-20 – 11 lbs. (5 kg) 438-5H R438-5 – 2 lbs. (0.9 kg) 538-10 – 8 lbs. (3.6 kg) 93 USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com F I S H I N G , C A B L E P U L L I N G & M AT E R I A L H A N D L I N G Flex-O-Twist™ Flexible Steel Fish Tapes 539-50, 539-100 (12" Case) • High-impact nylon, one-piece handle for maximum durability, long life, and easy, comfortable use. • Made of wound multi-strand 3/16" (4.8 mm) diameter steel cable for strength and flexibility. • Flexible…slips through lateral and vertical bends in the same run. • Heavy-duty winder case. CAT. NO. UPC NO. DESCRIPTION 539-50 30162 50' x 3/16" (15.2 m x 4.8 mm) diameter Flexible Steel Fish Tape in Winder Case 539-100 34002 100' x 3/16" (30.5 m x 4.8 mm) diameter Flexible Steel Fish Tape in Winder Case 439-100 29518 100' x 3/16" (30.5 m x 4.8 mm) diameter Flexible Steel Fish Tape without Winder Case 39790 39790 One Piece Handle 39791 39791 12" (305 mm) diameter Replacement Case SPECIFICATIONS Capacity 3/16" (4.8 mm) tape width – 500 lbs. (2.2 kN) maximum design strength. Weight 539-50 – 6 lbs. (2.7 kg) 539-100 – 10 lbs. (4.5 kg) 34023 – 4 lbs. (1.8 kg) 34024 – 6 lbs. (2.7 kg) SpeedFlex™ Flexible Fish Tape Leader • Silver-solder joint attaches to any 1/8" (3.2 mm) x .060" (1.5 mm) steel fish tape to provide a slim profile that fishes farther, faster. • High-strength stainless steel cable is used for reliability and long life. • Beveled edges on the leader reduce the possibility of hangups when pulling wire. • Up to (6) #10 wires can be attached to the large pulling eye. CAT. NO. UPC NO. DESCRIPTION 439-2 14392 12" (305 mm) SPEED FLEX Leader (solder joint) SPECIFICATION Weight 1.3 lbs. (0.6 kg) Flex-O-Twist™ Flexible Fish Tape Leader • Helps guide 1/8" steel tapes through sharp bends. • Thread on the end of the fish tape in place of the swivel ball head. CAT. NO. UPC NO. DESCRIPTION 439-1 30859 12" (305 mm) Flexible Fish Tape Leader SPECIFICATION Weight 94 1.3 lbs. (0.6 kg) NOTE: Rope is a very critical link in the cable pulling system. See pages 102 & 103 for proper pulling rope selection. USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com EZ Reach™ Fish Tape CAT. NO. UPC NO. DESCRIPTION 438-2X 01696 25' EZ Reach Tape SPECIFICATION Dimensions Steel tape 25' (7.6 m) long X 1/4" (6.4 mm) wide X .030 (.8 mm) thick. EZ Reach™ Fish Stix • High visible green color rods can be easily threaded together and seen when working above ceilings, down walls, or under raised floors. • 1/4" (6.4 mm) diameter fiberglass rods provide added rigidity when multiple sections are connected. • 200 lbs (0.9 kN) minimum pulling strength for long lasting durability and peace of mind. • Two different threaded tips available to accommodate various bundles of wire or cable. CAT. NO. UPC NO. DESCRIPTION 540-12 10504 EZ Reach™ Stix 12' (3.6 m) kit with bullet nose and “J” hook threaded tips, packaged in clear plastic tube. 540-24 10506 EZ Reach™ Stix 24' (7.3 m) kit with bullet nose and “J” hook threaded tips, packaged in clear plastic tube. SPECIFICATION 540-12 Total Length Weight Material 540-24 Total Length Weight Material 12' (3.6 m) – (3) 4' (1.2 mm) sections 1.04 lbs. (.5 kg) 1/4" (6.4 mm) dia. fiberglass rod F I S H I N G , C A B L E P U L L I N G & M AT E R I A L H A N D L I N G • Flat steel tape reaches easily above ceilings, under carpets, and through walls to install wire. • 25' (7.6 m) long, extending your reach where a traditional fish tape can’t. • Winder case with crank handle for easy compact storage. 24' (7.3 m) (3) 6' (1.8 mm) and (2) 3' (.9 m) sections 1.94 lbs. (.9 kg) 1/4" (6.4 mm) dia. fiberglass rod 95 USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com F I S H I N G , C A B L E P U L L I N G & M AT E R I A L H A N D L I N G Vacuum/Blower Power Fishing System • Rugged, self-contained unit includes everything you need to blow or vacuum fish line, poly line or measuring tape. • Durable tank and accessory storage box are corrosion, chemical and impact resistant polyethylene. • Designed for the jobsite, 10' (3.05 m) long hose, large heavy-duty wheels and removable accessory box. • Large 11 gallon (41.6 l) tank makes the 690 excellent for vacuuming water and debris. NRTL/C B H K 5 37918 ® GREENLEE 3/4" I 200 17 lbs. ® CAT. NO. UPC NO. DESCRIPTION 690 31339 Vacuum/Blower Power Fishing System – 120 VAC 16646 16646 Accessory – Adapter for 5" - 6" conduit 18877 18877 Accessory – Vacuum Crevice Tool 18879 18879 Accessory – Vacuum Dust Brush 618 16517 Accessory – Piston for 5" Conduit – IMC, Rigid 619 16951 Accessory – Piston for 6" Conduit – EMT 690/ 31339 KEY CAT. NO. UPC NO. DESCRIPTION A 595 * 32433 Fish Line – 85 lbs. (378 N) pulling strength; 2,150' (655 m) long 1 B * Piston for 1/2" Conduit 1 B * Piston for 3/4" Conduit 1 B * Piston for 1" Conduit 1 B * Piston for 1-1/4" Conduit 1 B * Piston for 1-1/2" Conduit 1 B 613 16511 Piston for 2" Conduit 1 B 614 16512 Piston for 2-1/2" Conduit – IMC, Rigid 1 B 621 19107 Piston for 2-1/2" Conduit – EMT 1 B 615 16513 Piston for 3" Conduit – IMC, Rigid 1 B 622 19109 Piston for 3" Conduit – EMT 1 B 616 16514 Piston for 3-1/2" Conduit – IMC, Rigid 1 B 646 24326 Piston for 3-1/2" Conduit – EMT 1 B 617 16515 Piston for 4" Conduit – IMC, Rigid 1 B 623 19110 Piston for 4" Conduit – EMT 1 C 25644 25644 Adapter Cone 1-1/4"-2-1/2" Conduit 1 LINE PACKAGES COMBINATION PISTON AND STRING A F E G C J D D 25646 25646 Adapter Cone 1/2"-1" Conduit 1 E 25645 25645 Adapter Cone 3"-4" Conduit 1 F 34027 34027 Storage Box 1 G 23360 23360 Adapter Nozzle for tape and line 1 H 32116 32116 Blower and Vacuum Unit 1 I 34392 34392 Tank with casters 1 J 16521 16521 Flexible Hose 1-1/2" x 10' (38.1mm x 3.05 m) 1 31315 31315 Outer Filter Bag 1 31314 31314 Inner Filter Bag 1 10 SPECIFICATIONS Capacity 1/2" - 4" conduit (5" and 6" with optional foam pistons) see page 98 K 37917-10 37917-10 1/2" Conduit x 150' (46 m) Line Pkg. Power Source 690: 120 VAC K 37918-5 37918-5 3/4" Conduit x 200' (61 m) Line Pkg. 5 Weight 50 lbs. (22.7 kg) K 37920-5 37920-5 3/4" Conduit x 450' (137 m) Line Pkg. 5 Air Flow 120 cfm K 37921-5 37921-5 1" Conduit x 200' (61 m) Line Pkg. 5 Pressure Will lift 110" (2794 mm) of water K 37923-5 37923-5 1" Conduit x 450' (137 m) Line Pkg. 5 * See page 100 for replacement conduit pistons. 96 NOTE: Rope is a very critical link in the cable pulling system. See pages 102 & 103 for proper pulling rope selection. USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com 690 Tank Retrofit Kits Adapt a new plastic tank to older style power unit and use your steel accessory box. Adapt a new plastic tank and accessory box to your older style power unit. ORDER INCLUDES PB or RP 25811 Plastic tank assembly (all hardware included) without plastic accessory box. VM or VN 32114 PB or RP 34392 34027 35001 VM or VN 34392 34027 Plastic tank assembly (all hardware and bracket for old steel accessory box included). Plastic accessory box not included. Plastic tank assembly (all hardware included) without accessory box. Plastic accessory box only (does not include accessories). Catch adapter kit, includes: (3) 52744 catch, (3) 32372 catch adapter, (6) 51427 screw, (6) 50364 screw, (12) 53370 lockwasher. Plastic tank assembly (all hardware included). Plastic accessory box only (does not include accessories). • Adapts newer style plastic tank to older units. Li’l Fisher™ 390 Power Fishing System R GG E, F F D,D,E, 5 37918 ® GREENLEE 3/4" 200 17 lbs. ® LINE PACKAGES CAT. NO. UPC NO. DESCRIPTION 390 38594 392 39051 Li’l Fisher™ Vacuum/Blower Power Fishing System – Includes only unit and hose Power Fishing System Accessory Kit KEY CAT. NO. UPC NO. DESCRIPTION 392 A 595 32433 Fish Line – 85 lbs. (378 N) pulling strength; 2,150' (655 m) long 1 B * Piston for 1/2" Conduit 1 B * Piston for 3/4" Conduit 1 B * Piston for 1" Conduit 1 B * Piston for 1-1/4" Conduit 1 B * Piston for 1-1/2" Conduit 1 B 613 16511 Piston for 2" Conduit 1 C 23360 23360 Adapter Nozzle for Measuring Tape 1 D 37917-10 37917-10 1/2" Conduit x 150' (46 m) Line Pkg. 10 E 37918-5 3791 3/4" Conduit x 300" (91 m) Line Pkg. 5 F 37921-5 37921-5 1" Conduit x 200' (61 m) Line Pkg. 5 G 39063 39063 Accessory Container Lid 1 H 54284 54284 Accessory Container 1 J 25646 25646 1/2”-1” Cone adapter 1 K 25644 25644 1-1/4”-2-1/2” Cone adapter 1 COMBINATION PISTON AND STRING ® ® BB ® R F I S H I N G , C A B L E P U L L I N G & M AT E R I A L H A N D L I N G NEED SERIAL NUMBER PREFIX ON YOUR UNIT HH KK 59 5 JJ CC Blowing a piston through conduit using 390 Li’l Fisher™ Power Fishing System. Can be used with fish line, poly line or measuring tape. AA SPECIFICATIONS *See page 100 for replacement conduit pistons. Capacity 1/2" - 2" conduit with optional Accessory Kit (2-1/2" - 4" with optional foam pistons – see pg. 98) Liquid Capacity – 1.75 gal. (6.5 l) Use 690 Power Fishing System for greater liquid capacity requirements. Power Source 120 VAC Weight 390 - 19 lbs. (8.6 kg) Air Flow 101.2 cfm (2.83 cMm) Vacuum Lift 137.1" (3482 mm) of H20 Blowing a piston through conduit using 390 Li’l Fisher™ Power Fishing System using 691 Blow Gun with 595 Mighty Mouser ® Fish Line. Vacuuming a piston through conduit using 390 Li’l Fisher™ Power Fishing System. Can be used with fish line, poly line or measuring tape. NOTE: Rope is a very critical link in the cable pulling system. See pages 102 & 103 for proper pulling rope selection. 97 USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com Portable Blower Power Fishing System F I S H I N G , C A B L E P U L L I N G & M AT E R I A L H A N D L I N G • Powerful, will blow line or measuring tape in up to 6" conduit. • Portable, lightweight blower has shoulder strap to make it easy to carry and allow the operator to have both hands free. • Efficient, includes the Mighty Mouser ® blow gun for fast, easy line blowing. CAT. NO. UPC NO. DESCRIPTION 591 32432 Portable Blower Power Fishing System 618 16517 Accessory – Piston for 5" Conduit – IMC, Rigid 619 16951 Accessory – Piston for 6" Conduit – EMT SPECIFICATIONS Capacity 1/2" - 4" conduit (5" and 6" with optional pistons) see page 100 Power Source 120 VAC Weight J C 59 5 5 37918 ® GREENLEE 3/4" B F 200 17 lbs. ® LINE PACKAGES E COMBINATION PISTON AND STRING 34 lbs. (15.4 kg) KEY CAT. NO. UPC NO. DESCRIPTION 592 591 A 691 32095 Mighty Mouser® Blow Gun 1 1 B 595 32433 Fish Line – 85 lbs. (378N) pulling strength; 2,150' (655 m) long 1 1 C * Piston for 1/2" Conduit 1 1 C * Piston for 3/4" Conduit 1 1 C * Piston for 1" Conduit 1 1 C * Piston for 1-1/4" Conduit 1 1 C * Piston for 1-1/2" Conduit 1 1 C 613 16511 Piston for 2" Conduit 1 1 C 614 16512 Piston for 2-1/2" Conduit – IMC, Rigid 1 1 C 621 19107 Piston for 2-1/2" Conduit – EMT 1 1 C 615 16513 Piston for 3" Conduit – IMC, Rigid 1 1 C 622 19109 Piston for 3" Conduit – EMT 1 1 C 616 16514 Piston for 3-1/2" Conduit – IMC, Rigid 1 1 C 646 24326 Piston for 3-1/2" Conduit – EMT 1 1 C 617 16515 Piston for 4" Conduit – IMC, Rigid 1 1 C 623 19110 Piston for 4" Conduit – EMT 1 1 D 25644 25644 Adapter Cone 1-1/4"-2-1/2" Conduit 1 1 E 25646 25646 Adapter Cone 1/2"-1" Conduit 1 F 25645 25645 Adapter Cone 3"-4" Conduit G 32104 32104 Flexible Hose 1-1/2" dia. x 1' (38.1 mm x 305 mm) 1 1 H 33451 33451 Hose Clamp 1 1 1 N ® ® ® G, H D A 592 Mighty Mouser ® Blow Gun Kit J L F A D G, H E M K 5 37918 ® 59 5 GREENLEE 3/4" 200 17 lbs. 1 1 J 32662 32662 Storage Box K 23360 23360 Adapter Nozzle for Tape and Line 1 L 590 32422 Portable Blower 1 M 32431 3243 Flexible Hose 1-1/2" x 4' (38.1 mm x 1.2 m) 1 N 37917-10 37917-10 1/2" Conduit x 150' (46 m) Line Pkg. 10 10 N 37918-5 37918-5 3/4" Conduit x 200' (61 m) Line Pkg. 5 5 N 37920-5 37920-5 3/4" Conduit x 450' (137 m) Line Pkg. 5 5 N 37921-5 37921-5 1" Conduit x 200' (61 m) Line Pkg. 5 5 N 37923-5 37923-5 1" Conduit x 450' (137 m) Line Pkg. 5 5 1 ® LINE PACKAGES COMBINATION PISTON AND STRING B ® ® ® N C 591 Portable Blower Power Fishing System *See page 100 for replacement conduit pistons. 98 USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com • This compact, self-contained Lexan® thermoplastic blow gun holds a 2,150' (655 m) package of 85 lb. (378 N) breaking strength fish line. • Compact self-contained unit leaves one hand free for more efficient operation. • Mighty Mouser® Blow Gun and Accessories all fit into compact sturdy metal case. CAT. NO. UPC NO. DESCRIPTION 592 691 595 618 619 32565 32095 32433 16517 16951 Mighty Mouser ® Blow Gun Kit for 1/2" - 4" Conduit in metal box Mighty Mouser ® Blow Gun only Fish Line – 85 lbs. (378 N) pulling strength; 2,150' (655 m) long. Piston for 5" Conduit – IMC, Rigid Piston for 6" Conduit – EMT SPECIFICATIONS Capacity Power Source Weight 1/2" - 4" conduit, through 6" with additional optional accessories Use with blower power fishing systems 592 – 20 lbs. (9 kg) 691 – 1.7 lbs. (0.8 kg) F I S H I N G , C A B L E P U L L I N G & M AT E R I A L H A N D L I N G Mighty Mouser® Blow Gun Kit 99 USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com F I S H I N G , C A B L E P U L L I N G & M AT E R I A L H A N D L I N G Conduit Pistons • Use with blower or vacuum power fishing system to pioneer the line through the conduit run. • Flexible foam body for an air-tight seal. • Color-coded end disk with embossed size markings for fast, easy selection. • Strong steel center rod with loops on both ends. • Pistons available for all types and sizes of conduit 1/2" through 6". INDIVIDUAL PISTONS PISTON SETS CAT. NO. S2613 UPC. NO. 26777 34317 34317 CONDUIT SIZES AND TYPE 1/2", 3/4", 1", 1-1/4", 1-1/2" and 2" EMT, IMC and Rigid 2-1/2", 3", 3-1/2" and 4" EMT CAT. NO. 608-5 609-5 610-5 611-3 612-2 613 614 621 615 622 616 646 617 623 618 619 UPC NO. 08263 08264 08265 08266 08267 16511 16512 19107 16513 19109 16514 24326 16515 19110 16517 16951 CONDUIT SIZE 1/2" 3/4" 1" 1-1/4" 1-1/2" 2" 2-1/2" 2-1/2" 3" 3" 3-1/2" 3-1/2" 4" 4" 5" 6" CONDUIT TYPE All All All All All All IMC, Rigid EMT IMC, Rigid EMT IMC, Rigid EMT IMC, Rigid EMT All All COLOR Green Green Green Green Green Green Green Yellow Green Yellow Green Yellow Green Yellow Green Green Fish Line • Strong, lightweight nylon. • 595 – Center feed for fast payout without tangling. Use with Mighty Mouser ® blow gun. • 604, 605, 606 and 607 – Specially wound to payout fast from outside without tangles. • Mildew resistant, can be pulled into the run with the wire to provide a means to add wires later. CAT. NO. UPC NO. STRENGTH LBS. N 595 604 605 606 607 32433 23368 16504 16505 16506 85 85 45 72 90 LENGTH 378 378 200 320 400 FT m 2150 2200 2750 1700 1350 655 670 838 517 411 Line Packages • Combination piston and string all-in one. • Blow or vacuum through, leaving a lightweight line strong enough to pull a rope. BOXED CONDUIT LENGTH SIZE FT. m COLOR 100 1/2" 1/2" 3/4" 3/4" 3/4" 3/4" 1" 1" 1" 1" 75 150 75 200 300 450 75 200 300 450 23 46 23 61 91 137 23 61 91 137 Red Red Yellow Yellow Yellow Yellow White White White White BAGGED CAT. NO. UPC NO. PER BOX QTY. CAT. NO. 37904-50 37907-50 37905-50 37908-50 37909-25 37910-25 37906-50 37911-50 37912-25 37913-25 06260 06263 06261 06264 06265 06266 06262 06267 06268 06269 50 50 50 50 25 25 50 50 25 25 37914-10 37917-10 37915-10 37918-5 37919-5 37920-5 37916-10 37921-5 37922-5 37923-5 UPC NO. QTY. PER BAG 06270 06274 06272 06275 06276 06277 06273 06278 06279 06280 10 10 10 5 5 5 10 5 5 5 USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com Poly Line Ready-to-use, pre-punched hole in lid with resealable cap. Use with power fishing systems directly from the container. Resists tangling when dispensing. Rot and mildew resistant. Handy reusable plastic dispenser pail with handle keeps the line dry. Use to pull rope through conduit. CAT. NO. UPC NO. DESCRIPTION 430 431 37959 430R 21481 21482 37959 37835 Poly Line 6500' (1981 m) Poly Line 5200' (1585 m) Poly Line 2200' (670 m) Poly Line Refill 6500' (1981 m) SPECIFICATIONS Size 430 – 6500' (1981 m), 431 – 5200' (1585 m), 37959 – 2200' (670 m) Capacity 430 – 210 lbs. (934 N) average breaking strength 431 – 240 lbs. (1 kN) average breaking strength 37959 – 500 lbs. (2.2 kN) average breaking strength Weight 430 – 11 lbs. (5 kg), 431 – 12 lbs. (5.4 kg) Rope and Pay-Out Reel 409 Rope shown on 405 Reel Stand — sold separately • Use to hand pull wire or cable. • Light enough to be vacuumed or blown into the conduit run with a power fishing system. • Rot and mildew resistant. • Can be pulled into the run along with cable or wire and left for future additions to the run. CAT. NO. UPC NO. DESCRIPTION 405 409 21546 21468 Reel Stand Polypro Rope 3/16" (4.8 mm) x 600' (182 m) SPECIFICATIONS Size 3/16" (4.8 mm) x 600' (182 m) Capacity 720 lbs. (3.2 kN) average breaking strength Weight 620: 10 lbs. (4.5 kg), 405: 5.2 lbs. (2.4 kg), 409: 5 lbs. (2.3 kg) Kevlar ® High Strength Conduit Measuring Tape F I S H I N G , C A B L E P U L L I N G & M AT E R I A L H A N D L I N G • • • • • • • Pull small cables or install pull rope for large cable pulling jobs. • Made of Kevlar ®, will not rot or deteriorate. Can be left in ducts indefinitely for future use. • Low stretch properties make measurements accurate. • Printed measurements every foot from zero to 3000' (914 m). • Use 406 Dispenser (see page 102). Kevlar is a registered trademark of E. I. DuPont, Inc. CAT. NO. UPC NO. DESCRIPTION 39243 39244 39245 39243 39244 39245 Conduit Measuring Tape 1/4" x 3000' (6.4 mm x 914 m) Conduit Measuring Tape 3/8" x 3000' (9.5 mm x 914 m) Conduit Measuring Tape 1/2" x 3000' (12.7 mm x 914 m) SPECIFICATIONS Size Capacity Weight 3000' (914 m) 39243 – 1250 lbs. (5.56 kN) average breaking strength 39244 – 1800 lbs. (8.01 kN) average breaking strength 39245 – 2500 lbs. (11.12 kN) average breaking strength 39243: 10.5 lbs. (4.8 kg), 39244: 14.5 lbs. (6.6 kg), 39245: 18 lbs. (8.2 kg) NOTE: Rope is a very critical link in the cable pulling system. See pages 102 & 103 for proper pulling rope selection. 101 USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com F I S H I N G , C A B L E P U L L I N G & M AT E R I A L H A N D L I N G Polyester Measure/Pulling Tapes • Durable and stretch resistant tape for easily pulling and installing wire and fiber optic cables within PVC and HDPE ducts. • Factory lubricated to reduce burn-through in innerduct. • Easy to read footage markings for quick and accurate measurements. • Available in various tensile strengths for use in any application. UPC NO. DESCRIPTION 4435 4436 4437 10445 10446 10447 Polyester Measure/Pulling Tape 1,250 lbs. (5.56 kN) Polyester Measure/Pulling Tape 1,800 lbs. (8.01 kN) Polyester Measure/Pulling Tape 2,500 lbs. (11.12 kN) SPECIFICATIONS Cat. No. 4435 4436 4437 Average Breaking Strength 1,250 lbs. (5.56 kN) 1,800 lbs. (8.01 kN) 2,500 lbs. (11.12 kN) Length 3,000' (914 m) 3,000' (914 m) 3,000' (914 m) Approx. Width 1/2" (12.7 mm) 5/8" (15.9 mm) 3/4" (19.1 mm) Conduit Measuring Tape and Dispenser 435 Measuring Tape shown on 434 Dispenser – sold separately. • • • • Fish and measure conduit runs in one operation. Permanently printed measurements every foot from zero to 3000' (914 m). Made of strong, waterproof polyester. Pay-out dispenser has anti-skid pads, handle and built-in cutter. CAT. NO. UPC NO. DESCRIPTION 435 434 21562 21875 Conduit Measuring Tape 3/16" x 3000' (4.8 mm x 914 m) Pay-Out Dispenser for 435 Conduit Measuring Tape SPECIFICATIONS Size Capacity Weight 3000' (914 m) 130 lbs. (578 N) average breaking strength 435: 18.4 lbs. (8.3 kg), 434: 3.5 lbs. (1.6 kg) Cable Pulling Rope Selection and Safety Tips Rope is a very critical link in the cable pulling system. The following steps should be observed in the selection and use of cable pulling rope. 1. Select a rope with an average breaking strength at least four times the rated capacity of your puller (rope safety factor). A safety factor of 4:1 minimum or greater than 4:1 is REQUIRED for pulling inside of raceways with a minimum of rope length exposed. Higher safety factors are recommended if the pulling rope is exposed! Required safety factors are for new rope in good condition without kinks or splices. When pulling, avoid sharp corners, edges, wedging or dragging over rough ground. Dirt and grit picked up by the rope can work into the strands reducing its pulling capacity. If there is any question, discard the used rope. 2. Use only low stretch Double-Braided Polyester for high force cable pulling. High stretch ropes store energy much like a stretched rubber band. If, for any reason, there is a failure of the rope, pulling grip, conductors, or any other component in the pulling system, this “stored-up” energy will suddenly be unleashed. The whipping action of a rope can cause considerable damage, serious injury or death. 102 CAT. NO. 3. Inspect rope thoroughly before using. Make sure there are no cuts or frays in the rope. Remember the rope is only as strong as its weakest point. INSPECT THOROUGHLY BEFORE USING! CUT ROPE WORN, FRAYED ROPE 4. When designing the pull, keep rope confined in conduit wherever possible. Should the rope break, or any other part of the pulling system fail, releasing the stored energy in the rope, the confinement in the conduit will work against the whipping action of the rope by playing out much of this energy within the conduit. 5. Do not stand in direct line with the pulling rope. ROPE SAFETY FACTOR = ROPE AVERAGE BREAKING STRENGTH MAXIMUM PULL FORCE DEVELOPED BY YOUR CABLE PULLER USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com Double-Braided Composite Rope for high force cable pullers ROPE DIAMETER FOR THE 640 PULLER 9/16" (14.3 mm) ROPE LENGTH CAT. NO. UPC NO. MAXIMUM RATED CAPACITY AVERAGE BREAKING STRENGTH WEIGHT LBS. kg ROPE STAND 300' 91 m 600' 182 m 1,200' 365 m 35283 35284 35285 35283 35284 35285 4,000 lbs. 4,000 lbs. 4,000 lbs. 17.8 kN 17.8 kN 17.8 kN 16,000 lbs. 16,000 lbs. 16,000 lbs. 71.1 kN 71.1 kN 71.1 kN 28 63 130 12.7 28.6 59 644 644 † 300' 91 m 600' 182 m 1,200' 365 m 35098 35100 35101 35098 35100 35101 6,500 lbs. 6,500 lbs. 6,500 lbs. 28.9 kN 28.9 kN 28.9 kN 26,000 lbs. 26,000 lbs. 26,000 lbs. 115.6 kN 115.6 kN 115.6 kN 58 113 230 26.3 51.3 104.3 644 654 † 300' 91 m 600' 182 m 1,200' 365 m 34136 34137 34138 34136 34137 34138 8,000 lbs. 8,000 lbs. 8,000 lbs. 35.6 kN 35.6 kN 35.6 kN 32,000 lbs. 32,000 lbs. 32,000 lbs. 142.3 kN 142.3 kN 142.3 kN 90 178 359 40.8 80.7 163.3 654 654 † FOR THE 6001 PULLER 3/4" (19.1 mm) FOR THE 6800 PULLER 7/8" (22.2 mm) † This rope does not fit on a rope stand. Use reel jacks and a spindle to dispense. See pages 136. Multiplex Cable Pulling Rope for low force cable pullers • • • • • • ROPE DIAMETER FOR THE 805 PULLER 3/8" (9.5 mm) Strong, white polyester braided rope with green tracer. Rot and mildew resistant. Packed on sturdy reel. Factory spliced eyes at both ends. Low stretch. Select a rope with a maximum rated capacity that meets or exceeds the cable puller’s maximum pulling force. ROPE LENGTH CAT. NO. UPC NO. MAXIMUM RATED CAPACITY AVERAGE BREAKING STRENGTH WEIGHT LBS. kg ROPE STAND 100' 300' 600' 1,200' 34121 34122 34123 34124 34121 34122 34123 34124 800 lbs. 800 lbs. 800 lbs. 800 lbs. 3700 lbs. 3700 lbs. 3700 lbs. 3700 lbs. 16.4 kN 16.4 kN 16.4 kN 16.4 kN 5.6 14.3 31.0 60.0 2.5 6.5 14.3 27.2 405 406 644 644 300' 91 m 600' 182 m 1,200' 365 m 480 481 482 31529 31530 31531 1,200 lbs. 5.3 kN 1,200 lbs. 5.3 kN 1,200 lbs. 5.3 kN 6400 lbs. 28.4 kN 6400 lbs. 28.4 kN 6400 lbs. 28.4 kN 21 50 104 9.5 22.7 47.2 406 644 † 300' 600' 1,200' 300' 600' 1,200' 483 484 485 6005 6015 6025 31532 31533 31534 29910 30031 30039 2,000 lbs. 2,000 lbs. 2,000 lbs. 2,000 lbs. 2,000 lbs. 2,000 lbs. 10,000 lbs. 10,000 lbs. 10,000 lbs. 12,500 lbs. 12,500 lbs. 12,500 lbs. 34 75 142 58 113 230 15.4 34 64.4 26.3 51.3 104.3 644 644 † 644 654 † 30 m 91 m 182 m 365 m 3.6 kN 3.6 kN 3.6 kN 3.6 kN F I S H I N G , C A B L E P U L L I N G & M AT E R I A L H A N D L I N G • Custom made to Greenlee specifications to provide 4 : 1 Safety Factor required for cable pulling. • Double-braided inner core with an extra double-braided outer jacket for added strength and less stretch; white with green tracer. • Rot and mildew resistant. • Factory spliced eyes at both ends. • Lowest stretch. • Select a rope with a maximum rated capacity that meets or exceeds the cable puller’s maximum pulling force. FOR THE 446 PULLER 1/2" (12.7 mm) FOR THE 2001 PULLER 5/8" (15.9 mm) 3/4" (19.1 mm) 91 m 182 m 365 m 91 m 182 m 365 m 8.9 kN 8.9 kN 8.9 kN 8.9 kN 8.9 kN 8.9 kN 44.4 kN 44.4 kN 44.4 kN 55.6 kN 55.6 kN 55.6 kN † This rope does not fit on a rope stand. Use reel jacks and a spindle to dispense. See pages 136. NOTE: Rope is a very critical link in the cable pulling system. See pages 102 & 103 for proper pulling rope selection. 103 USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com F I S H I N G , C A B L E P U L L I N G & M AT E R I A L H A N D L I N G Rope Stands • Use to organize and rewind rope. • Welded steel with washer and spring clip to hold rope reel on stand. ROPE STAND ROPE LENGTH 405 Rope Stand 250' (76 m) Rope 600' (182 m) Rope 406 Rope Stand 300' (91 m) Rope 600' (182 m) Rope 1,000' (305 m) Rope 3,000' (914 m) Conduit Measuring Tape Measuring Tape Cat./UPC No. 644 Rope Stand 300' (91 m) 600' (182 m) 1,200' (365 m) 5,000' (1524 m) 654 Rope Stand 300' (91 m) 600' (182 m) 654 405 UPC 3/16" NO. 4.8 mm 21546 ✓ ✓ 21550 ✓ 3/8" 6.4 mm 9.5 mm 12.7 mm ✓ ✓ 3/4" 7/8" 14.3 mm 15.9 mm 19.1 mm 22.2 mm ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ 39243 39244 39245 ✓ ✓ ✓ 15316 ✓ 34362 ✓ ✓ ✓ SPECIFICATIONS Weight 405 – 5.2 lbs. (2.4 kg); 406 – 7.8 lbs. (3.5 kg); 644 – 11 lbs. (5 kg); 654 – 32.1 lbs. (14.6 kg) Cable Puller Selection Guide CAT. NO. DESCRIPTION PAGE NO. PULLING FORCE CONT MAX WEIGHT PULLER CHAIN DIMENSIONS SPEED LENGTH WIDTH HEIGHT NO LOAD 11-1/2" (292.1 mm) 26" (660.4 mm) 8-1/2" (215.9 mm) 9 fpm 8 fpm 7.5 fpm 7 fpm 8 lbs 20-3/4" (527 mm) 22-1/2" (571.5 mm) 12" (304.8 mm) 16.5 fpm 11 fpm 7.5 fpm 6 fpm 104 2500 lbs 4000 lbs 68 lbs 8 lbs 21" (533.4 mm) 21" (533.4 mm) 12" (304.8 mm) 35 fpm 16 fpm 6 fpm 103 1400 lbs 2000 lbs 52 lbs 2001 Easy Tugger™ Power Cable Puller 6 lbs 15" (381 mm) 19" (482.6 mm) 9-1/2" (241.3 mm) 22 fpm 805 Fiber Optic Cable Puller 102 3 lbs 8" (203.2 mm) 18" (457.2 mm) 11-1/4" (285.8 mm) up to 75 fpm 766 Manual Wire Puller 102 52" (1320.8 mm) 18" (457.2 mm) 10" (254 mm) 6800 Ultra Tugger™ 107 6500 lbs 8000 lbs 86 lbs Power Cable Puller 106 4500 lbs 6500 lbs 87 lbs 6001 Super Tugger ® Power Cable Puller 640 Tugger ® Power Cable Puller 600 lbs 800 lbs 33 lbs 1500 lbs 35 lbs † – 766 comes with 200 ft. of aircraft-type steel swaged cable. 2001 Easy Tugger™ Cable Puller Typical Set-Ups 104 ROPE DIAMETER 1/2" 9/16" 5/8" 1/4" 800LBS 2000LBS 4000LBS 6000LBS 8000LBS up to 35 fpm 11fpm up to 35 fpm 6 fpm POWER REQUIRED ROPE 1-1/2 HP electric 7/8" double braid 1-1/2 HP electric 3/4" double braid 1 HP electric 9/16" double braid 1/2 HP electric 5/8" multiplex 1/2 HP electric 3/8" multiplex † USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com 640 Tugger ® Cable Puller Add 6080 Mobile “T” Boom and 640 Tugger Puller Down Pull with 640 Tugger Puller and 649 Pipe Adapter Sheave through exposed conduit. 6000 Super Tugger® Cable Puller Set-ups are shown without force gauge. Place the force gauge so the operator has an unobstructed view of the meter and quick access to its ON/OFF switch. Always use a force gauge. Down Pull through exposed conduit with 6001 Super Tugger Puller and 6049 Pipe Adapter Sheave. SECURE TO PREVENT POSSIBLE MOVEMENT. Attach 6080 Mobile "T" Boom and 6001 Super Tugger Puller. Pull. Other Set-Ups Up pull using Pipe Adapter Sheave. SECURE TO PREVENT POSSIBLE MOVEMENT. Horizontal pull with 6001 Super Tugger Puller and 6049 Pipe Adapter Sheave. 6037 Floor Mount F I S H I N G , C A B L E P U L L I N G & M AT E R I A L H A N D L I N G Set-ups are shown without force gauge. Place the force gauge so the operator has an unobstructed view of the meter and quick access to its ON/OFF switch. Always use a force gauge. Pull from power line. Overhead pull using Flexible Pipe Adapter, Pipe Adapter Sheave and Mobile "T" Boom. Illustrated are typical pulling setups. Actual applications may require variations from these examples. Select components with maximum rated capacities that meet or exceed the cable pullers maximum pulling force. SECURE TO PREVENT POSSIBLE MOVEMENT. NOTE: Rope is a very critical link in the cable pulling system. See pages 102 & 103 for proper pulling rope selection. 105 USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com F I S H I N G , C A B L E P U L L I N G & M AT E R I A L H A N D L I N G Ultra Cable Feeder™ 106 • Feeds cable at variable speeds to match the speed of cable puller. • Accommodates cable ranging in size up to 3.5" (88.9 mm) in diameter. • Sets up easily and can be operated by just one person. • Dual motors drive each wheel for traction on both sides of the cable. • Comes with pendant and toggle switch. An optional foot switch is available to control feeding. • Two cable loading methods: top-loading and end-loading. CAT. NO. UPC NO. DESCRIPTION 6810 445 05645 50302 05564 24821 05645 50302 Ultra Cable Feeder with Hand Switch Optional Foot Switch Tee (included) Hitch (included) SPECIFICATIONS Power Supply 115 VAC, 15 amps, 60 Hz Speed 4-36 feet per minute (1.2-11 meters per minute) Maximum Tractive Force Single Cable: 200 lbs. (.9 kN) All Cables: 800 lbs. (3.5 kN) Cable Capacity Quantity Size 8 x 250 MCM (120 mm2) 6 x 500 MCM (240 mm2) 5 x 750 MCM (300 mm2) Reel Weight Capacity 25,000 lbs. total (11,300 kg) Size 41" long x 27.5" wide x 37.5" high (1040 mm x 699 mm x 953 mm) Weight 285 lbs. (130 kg) Tire Pressure 22 psi (1.5 bar) NOTE: Rope is a very critical link in the cable pulling system. See pages 102 & 103 for proper pulling rope selection. USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com NRTL/C Nothing Pulls Like The Ultra Tugger™ • Pulls up to 8,000 (35.8 kN) lbs. • Versi-Boom™ System allows you to make versatile and fast set-ups and pull 10' (3 mm) or 20' (6 mm) of extra cable easily. • Uses standard 3" rigid steel conduit for boom. • Direct gear drive. • Lightweight. • Portable. • Optional deluxe force gauge. The Versi-Boom™ Plus System can reach into a man-hole, yet allow the operator to run the puller from above. In this application, the operator is making a downward pull from the box using the Ultra Tugger with the floor mount anchored to the floor. The equipment used is available in packages 6800 and 6805. 6802: Basic Package without rope In this application, the operator is making a downward pull from the box using the Ultra Tugger with the chain mount mounted onto the conduit. The equipment used is available in package 6801. Rope is not included. 6805: Deluxe Package with wheeled carriage without rope CAT. NO. 6800 UPC NO. 00985 6800-22 6801 03196 00986 6802 00987 6802-22 6805 03197 00993 6805-22 03198 DESCRIPTION Ultra Tugger™ Cable Puller with Standard Force Gauge, and Floor Mount. Same as 6800 except 220 VAC 50 HZ. Ultra Tugger™ Cable Puller with Standard Force Gauge, and Conduit Chain Mount. Ultra Tugger™ Cable Puller with Standard Force Gauge, Pipe Adapter Sheave, Floor Mount, Versi-Boom™ System and “T” Stand without the Versi-Boom™ excludes Extensions and Elbow, Wheeled Carriage, Screw-on Couplers, or Rope. Same as 6802 except 220 VAC 50 HZ. Same as the 6802 plus the Versi-Boom™ Plus Extension and Elbow, Wheeled Carriage and 3", 3-1/2" and 4" Screw-on Couplers without Rope. Same as 6805 except 220 VAC 50 HZ. SPECIFICATIONS Weight 86 lbs. (39 kg) Dimensions Length – 11.5 in. (292.1 mm), Width – 26 in. (660.4 mm), Height – 8.5 in. (215.9 mm) Drive Motor 1-1/2 Horsepower Power Source 6800, 01, 02, and 05 120 V 20 A Power Source 6800-22, 6802-22 and 6805-22 220 VAC 50 HZ Pulling Force Maximum – 8,000 lbs. (35.8 kN), Continuous – 6,500 lbs. (28.9 kN) Pulling Speed – No Load: 9 fpm, At 2000 lbs. (8.8 kN): 8 fpm, Feet (Meters) At 4000 lbs. (17.9 kN): 7.5 fpm, At 6000 lbs. (26.7 kN): Per Minute 7 fpm, At 8000 lbs (35.8 kN): 6 fpm Power Source 120 V 20 A Rope – Average Breaking Strength or More 7/8 diameter (22.2 mm); Double-Braided Polyester Composite – Rated at 32,000 lbs. (142 kN) In this application, the operator is making an upward pull from the box using the Ultra Tugger and Versi-Boom System attached to the “T” stand. The equipment used is available in packages 6802 and 6805. In this application, the operator is making an upward pull from the box using the Ultra Tugger with the pipe adapter sheave mounted onto the conduit. The equipment used is available in packages 6802 and 6805. 6800: Floor Mount Package In this application, the operator is making an upward pull from the box using the Ultra Tugger and Versi-Boom System attached to the mobile carriage. The equipment used is available in package 6805. Rope is not included. F I S H I N G , C A B L E P U L L I N G & M AT E R I A L H A N D L I N G Ultra Tugger™ Cable Puller: 8000 lb. (35.8kN) rated In this application, the operator is making an upward pull from the box using the Ultra Tugger and Versi-Boom Plus System attached to the mobile carriage. The equipment used is available in package 6805. Rope is not included. 6801: Conduit or Pole Mount Package 107 F I S H I N G , C A B L E P U L L I N G & M AT E R I A L H A N D L I N G USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 Ultra Tugger™ Cable Puller: 8000 lb. (35.8kN) rated (continued) Ultra Tugger™ with Force Gauge Nose Unit Pipe Adapter Sheave Elbow Unit Floor Mount Chain Mount Wheeled Carriage “T” Stand Boom Mount 4' Boom Slip-in Coupling Screw-on Coupling Adapter Screw-on 3' Boom CAT.NO. 08000 01069 00862 00863 00864 00865 00866 00867 00870 00871 00835 00791 00811 00815 00820 00799 00782 00783 00784 34136 34137 654 3048 603 UPC NO. 08000 01069 00862 00863 00864 00865 00866 00867 00870 00871 00835 00791 00811 00815 00820 00799 00782 00783 00784 34136 34137 34362 23362 23405 DESCRIPTION Ultra Tugger™ Force Gauge Pipe Adapter Sheave Elbow Unit Nose Unit Floor Mount Chain Mount “T” Stand Wheeled Carriage Boom Mount 3' (.9 m) Boom Tube 4' (1.2 m) Boom Tube 3" Slip-in Coupling 3-1/2" Slip-in Coupling 4" Slip-in Coupling Adapter for Screw-on Coupling 3" Screw-on Coupling 3-1/2" Screw-on Coupling 4" Screw-on Coupling 7/8" x 300' (22.2 mm x 91 m) Rope 7/8" x 600' (22.2 mm x 182 m) Rope Rope Stand Storage Box Casters – 2 Rigid, 2 Swivel 6800 6801 6802 6805 ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ Deluxe Force Gauge and Optional Strip Chart • Measures tension on the rope, to an accuracy of ± 5%. • Accuracy is not affected by initial rope size, or the change in rope size as it is loaded. • 0-10 VDC Analog output to optional strip chart recorder for permanent record of pulling force. • Switchable 120VAC receptacle for chart recorder. • Use with pulling rope up to 7/8" diameter (22.2 mm) maximum. Also use with Kevlar ® tape. SPECIFICATIONS Deluxe Force Gauge Accuracy ± 5%. CAT. NO. UPC NO. DESCRIPTION 00967 00967 Deluxe Force Gauge 33901 33901 Strip Chart Recorder 00966 00966 Cord Patch 86328 86328 Paper for Chart Recorder 33901 - Strip Chart Recorder is sold separately from the Deluxe Force Gauge. 108 greenlee.com USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com Ultra Tugger™ Speed Booster SPECIFICATIONS CAT. NO. UPC NO. DESCRIPTION 03561 03561 Ultra Tugger™ Speed Booster 04884 04884 Ultra Tugger™ Cord and Plug kit Capacity 0 to 2,500 lbs. (11.1 kN) pulling force in high speed mode. Dimensions Height: 9.5" (241.3 mm); Width: 13" (330.2 mm); Depth: 15.5" (393.7 mm) Weight 46 lbs. (20.9 kg) Pulling Speed No Load – 18 fpm (5.5 m); At 2000 lbs. (8.8 kN) – 16 fpm (4.9 m) Power 115 VAC, 15A Input; 115/230 VAC, 15/6A Output Ultra Tugger™ Slip-in Couplings 3-1/2" • Use to attach the Versi-Boom™ to the conduit. • Couplings slip into the conduit and pin to the Versi-Boom™. • For use with the Versi-Boom™ System only. 5" 4" 3" 2-1/2" Included in most packages Optional SPECIFICATIONS Size 2-1/2"- 5" EMT, IMC or Rigid Weight 00804 – 6 lbs. (2.7 kg) 00811 – 7 lbs. (3.2 kg) 00815 – 9 lbs. (4.1 kg) 00820 – 11 lbs. (5 kg) 00827 – 13 lbs. (5.8 kg) CAT. NO. UPC NO. SIZE WEIGHT 00804 00811 00815 00820 00827 00804 00811 00815 00820 00827 2.5" 3" 3.5" 4" 5" 6 lbs (2.7 kg) 7 lbs (3.2 kg) 9 lbs (4.1 kg) 11 lbs (5 kg) 13 lbs (5.8 kg) F I S H I N G , C A B L E P U L L I N G & M AT E R I A L H A N D L I N G • The Ultra Tugger™ Speed Booster increases the speed of the Ultra Tugger™ to pull approximately twice as fast as normal, up to 2,500 lbs. (11.1 kN). • For use with the Greenlee Ultra Tugger™ cable puller only. • Increases productivity on lower force runs and during the initial phase of a high force pull. • Automatically switches to low speed at 2,500 lbs (11.1 kN) to protect the puller motor. • Ultra Tugger™ adapter cord and plug included. Ultra Tugger™ Screw-on Couplings 3" 3-1/2" Included in the 6805 package. 4" 2" Adapter 2-1/2" Optional SPECIFICATIONS Size 2-1/2"- 4" EMT, IMC or Rigid Weight 00868 – 22 lbs. (10.0 kg) 00781 – 3 lbs. (1.36 kg) • Use to attach the Versi-Boom™ to the conduit when pulling from overhead. • The coupling and adapter threads onto the conduit and pins to the Versi-Boom™. • The Screw-on coupling and adapter must be used together. One adapter fits all of the screw-on couplings. CAT. NO. UPC NO. DESCRIPTION 00868 00868 03661 00781 03661 00781 Screw-on Coupler Set for 2-1/2", 3", 3-1/2", and 4" conduit. Optional Screw-on Coupling for 2" conduit. Optional Screw-on Coupling for 2-1/2" conduit. NOTE: Rope is a very critical link in the cable pulling system. See pages 102 & 103 for proper pulling rope selection. 109 USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com F I S H I N G , C A B L E P U L L I N G & M AT E R I A L H A N D L I N G Super Tugger® Cable Puller: 6500 lb. (28.9 kN) rated • Pull up to 6,500 lbs. (28.9 kN) with less than 27 lbs. (120 N) of operator effort. • Unique floor mounting attachment for quick, reliable setup. • Leaf type mounting chains won’t twist when tightening. • Heat treated steel serrated gripper feet for secure mounting to conduit. • Force Gauge included to constantly monitor the pull. • Right angle sheave allows the operator to stand out of the direct line of force. • Audio alarm high force warning and circuit breaker shut off at maximum force for added safety. • Tapered capstan and patented rope guidance system for better control of the rope when feeding onto the capstan. • Patented. CAT. NO. UPC NO. DESCRIPTION 6001 29627 6001-22 31466 6000 29909 6000-22 31467 6003 36241 6006 30435 6006-22 35098 35100 35101 34136 34137 34138 445 35346 33344 35098 35100 35101 34136 34137 34138 24821 35346 CAT. KEY NO. Super Tugger® Cable Puller Power Unit. Includes force gauge and vise chains. Same as 6001 except 220 VAC 50 HZ. Super Tugger® Complete Puller Package. Includes 6001 Super Tugger® cable puller power unit, pipe adapter sheave, flexible pipe adapter, 12" hook type cable sheave, mobile extension boom, 2", 2-1/2", 3", 3-1/2", 4" extension bushings, 3/4" x 300' (19.1 mm x 91 m) double-braided polyester rope, rope reel stand, floor mount, and steel storage box with casters. Same as 6000 except 220 VAC 50 HZ. Super Tugger® Complete Puller Package. Includes 6001 Super Tugger® cable puller power unit, pipe adapter sheave, flexible pipe adapter, mobile extension boom, 2", 2-1/2", 3", 3-1/2", 4" extension bushings, floor mount and steel storage box with casters. Super Tugger® Complete Puller Package. Includes 6001 Super Tugger® cable puller power unit, pipe adapter sheave, flexible pipe adapter, 12" hook type cable sheave, mobile extension boom, 2", 2-1/2", 3" 3-1/2", 4" extension bushings, 3/4" x 600' (19.1 mm x 182 m) double-braided polyester rope, rope reel stand, floor mount, and steel storage box with casters. Same as 6006 except 220 VAC 50 HZ. Double-Braided Composite Rope 3/4" x 300' (19.1 mm x 91 m) Double-Braided Composite Rope 3/4" x 600' (19.1 mm x 182 m) Double-Braided Composite Rope 3/4" x 1,200' (19.1 mm x 365 m) Double-Braided Composite Rope 7/8" x 300' (22.2 mm x 91 m) Double-Braided Composite Rope 7/8" x 600' (22.2 mm x 182 m) Double-Braided Composite Rope 7/8" x 1,200' (22.2 mm x 365 m) Foot Switch 6001 Capstan Retrofit Kit includes rope ramp, pivotal arm and tapered capstan. For units with VB and VT serial prefixes. UPC NO. DESCRIPTION 6001 6000 6003 6006 6001-22 6001 Cable Puller Parts 29631 29631 Vise Chain Unit includes one each of the following five items below (Two complete Vise Chain sets are required) 35661 35661 (1) Vise Chain ✓ 29630 29630 (2) Vise Chain Handle ✓ 53965 53965 (3) Vise Chain Retaining Screw ✓ 35657 35657 (4) Washer ✓ 35660 35660 (5) Chain Positioner ✓ 37179 37179 120 VAC Force Gauge ✓ 35638 35638 220 VAC Force Gauge Cable Pulling Components A 6001 29627 Cable Puller B 6049 29826 Pipe Adapter Sheave C 6085 29912 Flexible Pipe Adapter D 6080 29964 Mobile T-Boom D 16782 16782 2" Extension Bushing D 16783 16783 2-1/2" Extension Bushing D 16784 16784 3" Extension Bushing D 16785 16785 3-1/2" Extension Bushing D 16786 16786 4" Extension Bushing E 3048 23362 Storage Box 695 30239 Casters F 6037 35605 Cable Puller Floor Mount G 35098 35098 3/4" x 300' (19.1 mm x 91 m) Double-Braided Composite Rope G 35100 35100 3/4" x 600' (19.1 mm x 182 m) Double-Braided Composite Rope H 644 15316 Rope Stand 654 34362 Rope Stand J 8012 00872 12" (304.8 mm) Hook Sheave ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ 110 ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ SPECIFICATIONS Pulling Force Maximum: 6,500 lbs. (28.9 kN) Continuous: 4,500 lbs. (20 kN) Dimensions Length: 20-3/4" (527 mm) Width: 22-1/2" (572 mm) Height: 12" (305 mm) Weight 6001, 6001-22: 108 lbs. (49 kg) 6003: 454 lbs. (206 kg) 6000, 6000-22: 550 lbs. (250 kg) 6006, 6006-22: 612 lbs. (278 kg) Pulling Speed – Feet (Meters) Per Minute No Load: 16.5 (5) At 2000 lbs.: (8.8 kN) – 11 (3.4) At 4000 lbs.: (17.9 kN) – 7.5 (2.3) At 6000 lbs.: (26.7 kN) – 6 (1.8) Power 1-1/2 HP (1.1 kW): 120 VAC 1-1/2 HP (1.1 kW): 220 VAC 50HZ Rope – Average Breaking Strength or More 3/4" (19.1 mm) Double-Braided Composite – Rated at 26,000 lbs. (115.6 kN) ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ E E B E B B    G G C H D D D H J A J A A C C F 6000 Super Tugger® Cable Pulling System F 6003 Super Tugger® Cable Pulling System F 6006 Super Tugger® Cable Pulling System NOTE: Rope is a very critical link in the cable pulling system. See pages 102 & 103 for proper pulling rope selection. USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com Tugger ® Cable Puller: 4000 lbs. rated An economical puller with enough power for most jobs. Lighter weight for easier mounting in tough applications. Leaf type mounting chains won’t twist when tightening. Unique floor mounting attachment for quick reliable setup. Right angle sheave allows the operator to stand out of the direct line of force. • Audio alarm high force warning and circuit breaker shut off at maximum force for equipment protection and added safety. • Tapered capstan and patented rope guidance system for better control of rope. CAT. NO. UPC NO. DESCRIPTION 640 640-22 642 35300 35763 29844 676 36242 686 17163 686-22 37171 35766 35283 23832 37171 35766 35283 35284 35284 35285 35285 445 35336 24821 35336 Tugger ® Cable Puller Power Unit. Includes vise chains. Same as 640 except 220 VAC 50 HZ. Tugger ® Puller Package. Includes 640 Tugger ® cable puller power unit, pipe adapter sheave, floor mount, 9/16" x 300' (14.3 mm x 91 m) double-braided polyester rope, rope reel stand and steel storage box. Tugger ® Puller Package without rope. Includes 640 Tugger ® cable puller power unit, pipe adapter sheave, flexible pipe adapter, mobile extension boom, 2", 2-1/2", 3", 3-1/2", 4" extension bushings, floor mount and steel storage box with casters. Tugger ® Puller Package. Complete. Includes 640 Tugger ® cable puller power unit, pipe adapter sheave, flexible pipe adapter, 12" hook type cable sheave, mobile extension boom, 2", 2-1/2", 3", 3-1/2", 4" extension bushings, 9/16" x 300' (14.3 mm x 91 m) double-braided polyester rope, rope reel stand, floor mount, and steel storage box with casters. Same as 686 except 220 VAC 50 HZ. Force Gauge for 120 VAC 640 cable puller. Force Gauge for 220 VAC cable puller. Double-Braided Composite Rope 9/16" x 300' (14.3 mm x 91 m) Double-Braided Composite Rope 9/16" x 600' (14.3 mm x 182 m) Double-Braided Composite Rope 9/16" x 1,200' (14.3 mm x 365 m) Foot Switch 640 Capstan Retrofit Kit includes rope ramp, pivotal arm and tapered capstan. For units with NZ serial prefixes. Optional Force Gauge SPECIFICATIONS F I S H I N G , C A B L E P U L L I N G & M AT E R I A L H A N D L I N G • • • • • Dimensions Length – 21" (533 mm), Width – 21" (533 mm), Height – 12" (305 mm) Pulling Force Maximum – 4,000 lbs. (17.9 kN) Continuous – 2,500 lbs. (11.1 kN) Weight 640, 640-22 – 82 lbs. (38 kg) 676 – 373 lbs. (170 kg) 642 – 330 lbs. (150 kg) 686, 686-22 – 427 lbs. (194 kg) Pulling Speed – Feet (Meters) Per Minute No Load – 35 (10.67), At 2000 lbs. (8.8 kN) – 16 (4.87) At 4000 lbs. (17.9 kN) – 6 (1.83) Power 1 HP (746 W) – 120 VAC, 1 HP (746 W) – 220 VAC 50HZ Rope – Average Breaking Strength or More 9/16" (14.3 mm) Double-Braided Composite: Rated at 16,000 lbs. (71.1 kN) NOTE: Rope is a very critical link in the cable pulling system. See pages 102 & 103 for proper pulling rope selection. 111 USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com F I S H I N G , C A B L E P U L L I N G & M AT E R I A L H A N D L I N G Tugger ® Cable Puller: 4000 lbs. rated (continued) 112 B B B E E E  C   C H D H J G F A F 686 Tugger Puller System CAT. NO. G A ® KEY A D ® 642 Tugger Puller System F ® 676 Tugger Puller System without Rope UPC NO. DESCRIPTION 640 642 676 686 29631 29631 Vise Chain Unit: includes one each of the following five items below Two complete Vise Chain sets are required 35661 35661 (1) Vise Chain ✓ 29630 29630 (2) Vise Chain Handle ✓ 53965 53965 (3) Vise Chain Retaining Screw ✓ 35657 35657 (4) Washer ✓ 35660 35660 (5) Chain Positioner ✓ 35300 Cable Puller ✓ ✓ ✓ ✓ ✓ 640 Cable Puller Parts Cable Pulling Components A 640 B 649 15323 Pipe Adapter Sheave ✓ C 35283 35283 9/16" x 300' (14.3 mm x 91 m) Double-Braided Composite Rope ✓ D 644 15316 Rope Stand ✓ E 3048 23362 Storage Box ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ 695 30239 Casters F 6037 35605 Cable Puller Floor Mount G 685 16780 Flexible Pipe Adapter ✓ ✓ H 6080 29964 Mobile T-Boom ✓ ✓ H 16782 16782 2" Extension Bushing ✓ ✓ H 16783 16783 2-1/2" Extension Bushing ✓ ✓ H 16784 16784 3" Extension Bushing ✓ ✓ H 16785 16785 3-1/2" Extension Bushing ✓ ✓ H 16786 16786 4" Extension Bushing ✓ ✓ J 651 15325 12" (304.8 mm) Hook Sheave ✓ NOTE: Rope is a very critical link in the cable pulling system. See pages 102 & 103 for proper pulling rope selection. USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com Easy Tugger® Cable Puller 2000 lb. (8.8 kN) rated Lightweight puller for fast pulling of branch circuits Economical 2,000 lb. (8.8 kN) capacity for pulling fiber optic cables. Faster, easier setup, only weighs 52 lbs. (24 kg). 2042 includes all attachments required for most setups. CAT. NO. UPC NO. DESCRIPTION 2001 2042 31038 32440 483 484 485 685 31532 31533 31534 16780 2049 445 32226 24821 Easy Tugger™ Cable Puller Power Unit – 120 VAC Easy Tugger™ Cable Pulling System. Includes 2001 Easy Tugger™ cable puller power unit, 2049 pipe adapter sheave, 483 5/8" x 300' (15.9 mm x 91 m) multiplex rope, 644 rope stand and 2448 storage box Multiplex Polyester Rope 5/8" x 300' (15.9 mm x 91 m) Multiplex Polyester Rope 5/8" x 600' (15.9 mm x 182 m) Multiplex Polyester Rope 5/8" x 1,200' (15.9 mm x 365 m) Flexible Pipe Adapter – Allows attachment of 2049 Pipe Adapter Sheave to conduit Pipe Adapter Sheave Foot Switch PARTS KEY A B C C CAT. NO. 2001 2049 483 UPC NO. 31038 32226 31532 644 2448 15316 23273 E D E DESCRIPTION Cable Puller power unit Pipe Adapter Sheave Multiplex Polyester Rope 5/8" x 300' (15.9 mm x 91m) Rope Stand Storage Box 2042 1 1 1 1 1 SPECIFICATIONS D A B Pulling Force Maximum – 2,000 lbs. (8.8 kN), Continuous – 1,400 lbs. (6.2 kN) Dimensions Length – 15" (381 mm), Width – 19" (483 mm), Height – 9-1/2" (241 mm) Weight 2001 – 52 lbs. (24 kg), 2042 – 275 lbs. (125 kg), 2001-22 – 52 lbs. (24 kg) Pulling Speed – Feet (Meters) Per Minute No Load – 22 (6.7), At 2000 lbs. (8.8 kN) – 11 (3.3) Power 1/2 HP (373 W) – 120 VAC Electric, 1/2 HP (373 W) – 220 VAC Electric 50HZ Rope – Average Breaking Strength or More 5/8" (15.9 mm) Multiplex: Rated at 8,000 lbs. (35.6 kN) NOTE: Rope is a very critical link in the cable pulling system. See pages 102 & 103 for proper pulling rope selection. F I S H I N G , C A B L E P U L L I N G & M AT E R I A L H A N D L I N G • • • • 113 USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com F I S H I N G , C A B L E P U L L I N G & M AT E R I A L H A N D L I N G Fiber Optic Cable Puller • Both speed and maximum pulling force can be set by the operator. • Electronically displays both actual speed and actual force while running. • Shuts down when maximum preset force is reached to prevent damage to the cable being pulled at 200-800 lb. (.9kN-3.5kN) adjustment range. • Features a gradual restart after automatic shut-down to prevent quick snap stressing. • Ports provided to link to optional strip recorder for permanently documenting pulling force or speed. • Dual grooved capstans provide excellent rope control. • Patented. 800 LBS. RATED NRTL/C 33656 33901 CAT. NO. UPC NO. DESCRIPTION 805 33678 Fiber Optic Puller. Includes puller mounting bracket, mounting chain and steel storage case. 34121 34121 Multiplex Polyester Rope 3/8" x 100' (9.5 mm x 30 m) 34122 34122 Multiplex Polyester Rope 3/8" x 300' (9.5 mm x 91 m) 34123 34123 Multiplex Polyester Rope 3/8" x 600' (9.5 mm x 182 m) 34124 34124 Multiplex Polyester Rope 3/8" x 1,200' (9.5 mm x 365 m) 33656 33656 Boom Mount for use with 441 feeding sheave 33629 33629 On/Off Foot Switch 33901 33901 Chart Recorder 86332 86332 Chart Recorder Cable 86328 86328 Paper for Chart Recorder (8.4 hr/roll) 29825 29825 Vise Chain Unit SPECIFICATIONS PULLING FORCE Maximum Adjustable up to 800 lbs. (3.5 kN) Continuous 600 lbs. (2.6 kN) DIMENSIONS PARTS CAT. NO. UPC NO. DESCRIPTION 29825 29825 Vise Chain Unit (includes the following 3 items) 805 27831 27831 (1) Vise Chain 1 Length 8" (203 mm), Width 18" (457 mm), Height 11-1/4" (286 mm) 29630 29630 (2) Vise Chain Handle 1 Weight 103 lbs. (46.7 kg) 29638 29638 (3) Chain Positioner 1 33659 33659 Mounting Bracket Pin 1 53449 53449 Mounting Bracket Pin Clip 1 PULLING SPEED – Feet (Meters) Per Minute No Load up to 75 (22.8), At 800 lbs. (3.5 kN): up to 35 (10.7) Power 1/2 HP (373 W): 120 VAC Rope – Average Breaking Strength or More: 3/8" (9.5 mm) Multiplex: Rated at 3,700 lbs. (16.4 kN) Hand Crank Wire Puller • Pull up to 1500 lbs. (6.7 kN) with only 30 lbs. (133 N) of crank handle force. • Two speed ratchet winder for fast, efficient operation. • Has 200' (61 m) of steel aircraft cable. • Completely self contained and ready to operate. CAT. NO. UPC NO. DESCRIPTION 766 18202 Hand Crank Wire Puller 50954 50954 200' (61 m) spool of steel cable 13955 13955 Shear Pin 28280 28280 Crank Handle Assembly SPECIFICATIONS 114 Pulling Force Maximum – 1500 lbs. (6.6 kN) Size 200' (61 m) pulling cable length Weight 38 lbs. (17.2 kg) Power Manual – 2 Speed Hand Crank Dimensions Length – 52" (1.32 m), Width – 18" (457 mm), Height – 10" (254 mm) NOTE: Rope is a very critical link in the cable pulling system. See pages 102 & 103 for proper pulling rope selection. USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com Flexible Adapter Sheaves for Tugger® and Super Tugger® UPC NO. 16780 29912 DESCRIPTION Flexible Adapter Sheave for use with 640 Tugger ® Cable Puller Flexible Adapter Sheave for use with 6001 Super Tugger ® Cable Puller 685 6085 • Use to attach to the conduit in conjunction with adapter sheave for easier setups. • Helps eliminate strain on hangers and boxes. • Select a sheave with a maximum rated capacity that meets or exceeds the cable puller’s maximum pulling force. SPECIFICATIONS Maximum Rated Capacity 685 – 4,000 lbs. (17.7 kN); 6085 – 6,500 lbs. (28.9 kN) Weight 685 – 26 lbs. (11.8 kg); 6085 – 31 lbs. (14.1 kg) DESCRIPTION Sheave Pin Sheave Pin Clip Sheave Vise Chain Unit Consists of the following (2) items: (1) Vise Chain (2) Vise Chain Handle Frame Pin 685 CAT. NO. 15360 50302 15358 30142 685 UPC NO. 15360 50302 15358 30142 6085 CAT. NO. 29803 50302 29616 30142 6085 UPC NO. 29803 50302 29616 30142 27831 29630 17313 27831 29630 17313 27831 29630 — 27831 29630 — Mobile Extension Boom Kits for Tugger ® and Super Tugger ® • Use in conjunction with Adapter Sheave for concealed wall panels. • Helps eliminate strain on hangers and boxes. • Wheels on mobile boom makes it easier to move to the next pull. • Extension bushing for 2"-4" conduit for mounting to the conduit inside the panel. • Select a boom kit with a maximum rated capacity that meets or exceeds the cable puller’s maximum pulling force. CAT. NO. UPC NO. DESCRIPTION 682 16779 Extension Boom Kit for 640 Tugger® Cable Puller. Includes mobile T-boom, flexible adapter sheave and 2"-4" conduit extension bushings. SPECIFICATIONS Maximum Pulling Capacity Weight 682 – 4,000 lbs. (17.7 kN) 682 – 86 lbs. (39 kg) CAT. NO. 685 6080 16782 16783 16784 16785 16786 UPC NO. 16780 29964 16782 16783 16784 16785 16786 DESCRIPTION Flexible Pipe Adapter Mobile T-Boom 2" Extension Bushing 2-1/2" Extension Bushing 3" Extension Bushing 3-1/2" Extension Bushing 4" Extension Bushing Extension Bushings for 640 Tugger® and 6001 Super Tugger® F I S H I N G , C A B L E P U L L I N G & M AT E R I A L H A N D L I N G CAT. NO. 685 6085 • Use to extend the end of the conduit by threading onto it. This will allow you to securely attach the Flexible Adapter. • Helps eliminate strain on hangers and boxes. SPECIFICATIONS Size 2" - 4" IMC or Rigid Weight 16782 – 2 lbs. (.9 kg) 16783 – 2.7 lbs. (1.2 kg) 16784 – 4.3 lbs. (2 kg) 16785 – 5.7 lbs. (2.6 kg) 16786 – 6.1 lbs. (2.8 kg) CAT. NO. 16782 16783 16784 16785 16786 UPC NO. 16782 16783 16784 16785 16786 DESCRIPTION Extension Bushing for 2" IMC or Rigid Extension Bushing for 2-1/2" IMC or Rigid Extension Bushing for 3" IMC or Rigid Extension Bushing for 3-1/2" IMC or Rigid Extension Bushing for 4" IMC or Rigid Foot Switch for Cable Pullers • Use with 640, 2001, 6001 or 6800 cable pullers to add foot control. • Foot pressure required to operate. CAT. NO. 445 UPC NO. 24821 SPECIFICATIONS Power Source 120 VAC DESCRIPTION Foot Switch Weight 9.5 lbs. (4.3 kg) 115 USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com F I S H I N G , C A B L E P U L L I N G & M AT E R I A L H A N D L I N G Adapter Sheaves for Tugger ® and Super Tugger ® • Attach directly to conduit for fast, easy setup to panel with exposed conduit. • Use in conjunction with flexible adapter sheave and T-boom for concealed wall panels. • Has various sheave positions to accommodate different setups. • Leaf type mounting chains won’t twist when tightening. • Pull extra cable for makeup. • Select a sheave with a maximum rated capacity that meets or exceeds the sheave puller’s maximum pulling force. CAT. NO. 649 6049 UPC NO. 15323 29826 DESCRIPTION Sheave Pin Sheave Pin Clip (2) Sheave Vise Chain Unit includes Vise Chain Vise Chain Handle Vise Chain Positioner DESCRIPTION Adapter Sheave for use with 640 Tugger® cable puller Adapter Sheave for use with 6001 Super Tugger ® cable puller 649 CAT.NO. 25161 50302 15358 30142 following 2 items 27831 29630 — UPC NO. 25161 50302 15358 30142 27831 29630 — 6049 CAT.NO. 29824 50302 29616 29825 following 3 items 27831 29630 29638 UPC NO. 29824 50302 29616 29825 27831 29630 29638 SPECIFICATIONS Maximum Rated Capacity 649 – 4,000 lbs. (17.7 kN) 6049 – 6,500 lbs. (28.9 kN) Weight 649 – 58 lbs. (27 kg) 6049 – 69 lbs. (32 kg) Hook-Type Sheaves for Easy Tugger™ and Tugger ® • • • • Strong, welded steel frames. Forged steel closure type hooks with 1" (25.4 mm) opening. 5" (127 mm) wide aluminum alloy sheaves with self-lubricating bearings. Select a sheave with a maximum rated capacity that meets or exceeds the cable puller’s maximum pulling force. CAT. NO. 650 UPC NO. 15324 651 15325 652 15326 653 15327 DESCRIPTION 6" (152.4 mm) dia. Hook Sheave with 1-1/2" (38.1 mm) minimum radius 12" (304.8 mm) dia. Hook Sheave with 3-5/16" (84.1 mm) minimum radius 18" (457.2 mm) dia. Hook Sheave with 7" (177.8 mm) minimum radius 24" (609.6 mm) dia. Hook Sheave with 9-13/16" (249.2 mm) minimum radius SHEAVE DIAMETER DESCRIPTION 650 651 652 653 6" (152.4 mm) 12" (304.8 mm) 18" (457.2 mm) 24" (609.6 mm) CAT. NO. UPC NO. CAT. NO. UPC NO. CAT. NO. UPC NO. CAT. NO. UPC NO. Sheave Pin Sheave Pin Clip (2) Sheave Sheave Bushing (2) Yoke Frame 16797 50302 15362 16798 16799 16797 50302 15362 16798 16799 16797 50302 15358 16798 16801 16797 50302 15358 16798 16801 16797 50302 15363 16798 16801 16797 50302 15363 16798 16801 16797 50302 15364 16798 16802 16797 50302 15364 16798 16802 SPECIFICATIONS Maximum Rated Capacity 4,000 lbs. (17.8 kN) Weight 650 – 8.8 lbs. (4 kg) 652 – 25 lbs. (11.3 kg) 651 – 15 lbs. (6.8 kg) 653 – 35 lbs. (15.9 kg) 116 NOTE: Rope is a very critical link in the cable pulling system. See pages 102 & 103 for proper pulling rope selection. USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com Hook Sheaves for any Greenlee cable puller 18" 12" SPECIFICATIONS CAT. NO. UPC NO. 8012 00872 8018 00873 8024 00874 For use with any Greenlee cable puller. Strong, welded steel frames. Forged steel closure type hooks with 1" (25.4 mm) opening. All three sheaves are aluminum alloy with self-lubricating bearings. SHEAVE DIAMETER DESCRIPTION Roll Pin Sheave Pin Sheave Pin Clip Sheave Unit Yoke Frame OUTSIDE DIAMETER 12" (304.8 mm) 18" (457.2 mm) 24" (609.6 mm) INSIDE RADIUS 3-7/8" (98.4 mm) 7" (177.8 mm) 9-7/8" (250.8 mm) 8012 12" (304.8 mm) CAT. NO. UPC NO. 50700 50700 00838 00838 50302 50302 00843 00843 00854 00854 WIDTH 5" (127 mm) 6" (152.4 mm) 6-1/2" (165.1 mm) 8018 18" (457.2 mm) CAT. NO. UPC NO. 50700 50700 00846 00846 50302 50302 00844 00844 00855 00855 WEIGHT 28 lbs (12.7 kg) 44 lbs (19.9 kg) 67 lbs (30.3 kg) 8024 24" (609.6 mm) CAT. NO. UPC NO. 50700 50700 00850 00850 50302 50302 00845 00845 00856 00856 MAXIMUM RATED CAPACITY 8,000 lbs. (35.8 kN) 8,000 lbs. (35.8 kN) 8,000 lbs. (35.8 kN) Right Angle Twin Yoke Sheave for Easy Tugger™ and Tugger ® • • • • • • 9-13/16" (249 mm) minimum radius. Strong welded steel yokes. Forged steel closure type hook with 1" (25.4 mm) opening. 5" (127 mm) wide aluminum alloy sheave with self-lubricating bearings. Yokes rotate independently to fit various setups. Use with any cable puller whose maximum pulling force is 4,000 lbs. (17.8 kN) or less. CAT. NO. 639 SPECIFICATION Maximum Rated Capacity Weight 45 lbs. (20.4 kg) 4,000 lbs. (17.8 kN) UPC NO. 17265 SHEAVE DESCRIPTION Sheave Pin Sheave Pin Clip Sheave Sheave Bushing Yoke Frame DESCRIPTION Right Angle Twin Yoke Sheave with 9-13/16" (249 mm) minimum radius 639 CAT. NO. 17266 50302 15364 16798 17299 UPC NO. 17266 50302 15364 16798 17299 QUANTITY 1 2 1 2 2 F I S H I N G , C A B L E P U L L I N G & M AT E R I A L H A N D L I N G • • • • 24" Triple Sheave Cable Guide for Easy Tugger™, Tugger ® and Super Tugger ® • • • • • Adjustable center sheave for 19-1/2" (495 mm) or 36" (914 mm) radius. Forged steel closure type hook with 1-1/2" (38.1 mm) opening. Aluminum frames for light weight. Steel yoke is pinned for easy removal. 21-7/8" (555 mm) high, 24" (610 mm) long, 7-3/8" (187 mm) wide with 5" (127 mm) wide sheaves. • Use with any cable puller whose maximum pulling force is 6,500 lbs. (28.9 kN) or less CAT. NO. 6036 UPC NO. 31569 SPECIFICATIONS Maximum Rated Capacity Weight 28 lbs. (12.7 kg) DESCRIPTION Triple Sheave Cable Guide 6,500 lbs. (28.9 kN) SHEAVE DESCRIPTION Sheave Axle Sheave Bolt Sheave Bolt Washer Sheave Pin Sheave Pin Clip Sheave Bushing Sheave 6036 CAT. NO. 31573 53091 51434 29600 50302 16798 15362 UPC NO. 31573 53091 51434 29600 50302 16798 15362 QUANTITY 3 6 6 1 2 6 3 117 USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com F I S H I N G , C A B L E P U L L I N G & M AT E R I A L H A N D L I N G Radius Cable Sheaves for Easy Tugger™, Tugger ® and Super Tugger ® • • • • Welded steel frame with a series of sheaves to form a large radius. Yokes with cast steel closure type hooks with a 1" (25.4 mm) opening. 5" (127 mm) wide aluminum alloy sheaves. Use with any cable puller whose maximum pulling force is 4,000 lbs. (17.8 kN) or less. CAT. NO. 636 637 638 631 UPC NO. 17255 17260 17263 21572 DESCRIPTION 16" (406.4 mm) Radius Cable Sheave with 4 sheave wheels 24" (609.6 mm) Radius Cable Sheave with 6 sheave wheels 36" (914.4 mm) Radius Cable Sheave with 8 sheave wheels 48" (1219 mm) Radius Cable Sheave with 10 sheave wheels SPECIFICATIONS Maximum Rated Capacity 4,000 lbs. (17.8 kN) Weight 631 – 115 lbs. (52 kg) 637 – 63 lbs. (29 kg) 636 – 49 lbs. (22 kg) 638 – 85 lbs. (39 kg) SHEAVE RADIUS DESCRIPTION Sheave Pin Sheave Pin Clip Sheave Bushing Sheave Yoke Frame Frame 636 16" (406.4 mm) CAT. NO. UPC NO. 17256 17256 50302 50302 16798 16798 15362 15362 17257 17257 17258 17258 QTY. 4 8 2 4 2 1 637 24" (609.6 mm) CAT. NO. UPC NO. 17256 17256 50302 50302 16798 16798 15362 15362 17257 17257 17261 17261 QTY. 6 12 2 6 2 1 638 36" (914.4 mm) CAT. NO. UPC NO. 17256 17256 50302 50302 16798 16798 15362 15362 17257 17257 17264 17264 QTY. 10 20 2 10 2 1 Tray-Type Sheaves 658 659 • • • • Steel frame easily attaches to cable tray up to 2" (50.8 mm) thick. Helps roll and guide tray pulls. Make tray pulls easier. 5" (127 mm) wide aluminum alloy sheaves with self lubricating bearings. CAT. NO. 658 659 UPC NO. 15332 19094 DESCRIPTION Tray-Type Sheave Tray-Type Sheave SPECIFICATIONS Size 658 – 12" (304.8 mm) long Weight 658 – 11 lbs. (5 kg) 659 – 22" (558.8 mm) long 659 – 17 lbs. (7.7 kg) Cable Rollers SPECIFICATIONS Weight 2018S – 8 lbs. (3.6 kg) 2024S – 10 lbs. (4.5 kg) 2030S – 13 lbs. (5.9 kg) 2036S – 15 lbs. (6.8 kg) 20249R – 41 lbs. (18.6 kg) 2018R – 11 lbs. (5 kg) 2024R – 12 lbs. (5.4 kg) 2030R – 13 lbs. (5.9 kg) 2036R – 14 lbs. (6.3 kg) 20369R – 53 lbs. (24 kg) • Installed up through the bottom of the tray for easy removal after the cable is installed. • Individual rollers keep rolling with each cable even after several cables have been installed in the tray. • Steel ball bearing rollers for long life and less friction. • Steel welded frame. • Adjustment slots and universal mounting brackets. CAT. NO. UPC NO. DESCRIPTION STRAIGHT CABLE ROLLERS 2018S 27383 Straight Cable Roller for 12" - 18" (304.8 - 457.2 mm) wide tray 2024S 27384 Straight Cable Roller for 20" - 24" (508 - 609.6 mm) wide tray 2030S 27386 Straight Cable Roller for 24" - 30" (609.6 - 762 mm) wide tray 2036S 27387 Straight Cable Roller for 30" - 36" (762 - 914.4 mm) wide tray RADIUS CABLE ROLLERS 2018R 27388 Radius Cable Roller for 12" - 18" (304.8 - 457.2 mm) wide tray 2024R 27389 Radius Cable Roller for 20" - 24" (508 - 609.6 mm) wide tray 2030R 27390 Radius Cable Roller for 24" - 30" (609.6 - 762 mm) wide tray 2036R 27391 Radius Cable Roller for 30" - 36" (762 - 914.4 mm) wide tray RIGHT ANGLE CABLE ROLLERS 20249R 27392 Right Angle Rollers 24" (609.6 mm) radius 90° 20369R 27393 Right Angle Rollers 36" (914.4 mm) radius 90° 118 QTY. 8 16 2 8 2 1 631 48" (1219 mm) CAT. NO. UPC NO. 17256 17256 50302 50302 16798 16798 15362 15362 17257 17257 21573 21573 CAT. NO. UPC NO. DESCRIPTION 28170 28170 J-Hook 3-3/8" A 2" Inside Straight Cable Rollers 3-3/8" 3-3/8" 5-5/8" 2" Inside Radius Cable Rollers CAT. NO. 2018S 2024S 2030S 2036S UPC NO. 27383 27384 27386 27387 5-5/8" Right Angle Rollers DIMENSION A 6-5/16" (160.3 mm) 12-1/2" (317.5 mm) 18-11/16" (474.7 mm) 24-7/8" (631.8 mm) NOTE: Rope is a very critical link in the cable pulling system. See pages 102 & 103 for proper pulling rope selection. USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com Haines Cable Tray Rollers UPC NO. 31931 DESCRIPTION SIZE Haines Roller 7" (177.8 mm) wide 6" (152.4 mm) dia. 31925 31925 Expandable Roller Half 31926 31926 Coupling 3-1/2" (88.9 mm) dia. 3" (76.2 mm) long 31927 31927 Mounting Clip Steel Conduit Use with 1-1/2" Rigid 31930 31930 Spindle (includes End Caps) 1-1/2" Rigid Conduit x 40" (1016 mm) long 31929 31929 End Cap Fits 1-1/2" Rigid Conduit Used to make 8" (203.2 mm) to 48" (1219.2 mm) wide roller Feeding Sheaves • Yoke frame slides into the end of conduit and holds sheave, allowing the cable being fed into the conduit to smoothly roll over the sheave. • 5" (127 mm) wide aluminum alloy sheave with self-lubricating bearings. • Split tube for easy removal after cable is installed. • See the Capacity Table (below) SPECIFICATIONS Rated Capacity See Capacity Table Below See instructions for details. Weight 441-2 – 9 lbs. (4.5 kg) 441-3-1/2 – 17 lbs. (7.7 kg) 441-2-1/2 – 11 lbs. (5 kg) 441-4 – 19 lbs. (8.6 kg) 441-3 – 14 lbs. (6.4 kg) 441-5 – 26 lbs. (11.8 kg) SHEAVE CONDUIT SIZE DESCRIPTION Sheave Pin Sheave Pin Clip (2) Sheave Frame 441-2 2" CONDUIT CAT. NO. UPC NO. 25160 25160 50302 50302 15362 15362 30184 30184 UNOCCUPIED MANHOLE ABOVE GROUND 441-2-1/2 2-1/2" CONDUIT CAT. NO. UPC NO. 25160 25160 50302 50302 15362 15362 30359 30359 UNOCCUPIED MANHOLE UNOCCUPIED MANHOLE CAT. NO. 441-2 441-2-1/2 441-3 441-3-1/2 441-4 441-5 441-3 3" CONDUIT CAT. NO. UPC NO. 25160 25160 50302 50302 15362 15362 30189 30189 UPC NO. 30183 30358 30188 30363 30347 30193 DESCRIPTION Feeding Sheave for 2" conduit Feeding Sheave for 2-1/2" conduit Feeding Sheave for 3" conduit Feeding Sheave for 3-1/2" conduit Feeding Sheave for 4" conduit Feeding Sheave for 5" Conduit 441-3-1/2 3-1/2" CONDUIT CAT. NO. UPC NO. 25160 25160 50302 50302 15362 15362 30364 30364 CAPACITY TABLE ANGLE OF PULL 441-2 15° 1750 lbs. 7.7 kN 30° 900 lbs. 4.0 kN 45° 650 lbs. 2.8 kN 60° 500 lbs. 2.2 kN 75° 450 lbs. 2.0 kN 90° 450 lbs. 2.0 kN 441-2-1/2 1900 lbs 8.4 kN 1000 lbs. 4.4 kN 700 lbs. 3.1 kN 550 lbs. 2.4 kN 500 lbs. 2.2 kN 500 lbs. 2.2 kN 441-4 4" CONDUIT CAT. NO. UPC NO. 25160 25160 50302 50302 15362 15362 30346 30346 441-3 6050 lbs. 26.9 kN 3150 lbs. 14.0 kN 2200 lbs. 9.7 kN 1800 lbs. 8.0 kN 1600 lbs. 7.1 kN 1550 lbs. 6.8 kN 441-3-1/2 6500 lbs. 28.9 kN 5050 lbs. 22.4 kN 3550 lbs. 15.7 kN 2900 lbs. 12.8 kN 2600 lbs. 11.5 kN 2500 lbs. 11.1 kN F I S H I N G , C A B L E P U L L I N G & M AT E R I A L H A N D L I N G • Highly economical system of 1-1/2" steel conduit spindles, high-impact ABS plastic rollers and simple clips. • Rollers snap in and out of clips fast and easy. • Mounting clips fit onto the top of most I-Beam and C-Channel trays, so existing wire isn’t disturbed. • 8" (203.2 mm) to 48" (1219.2 mm) wide rollers are available, using expandable roller halves and 3" (76.2 mm) PVC conduit. • Use Greenlee Cable-Cream™ (see p. 120) to lube spindle and roller. This lubricant is compatible with all cable insulation types. CAT. NO. 31931 441-5 5" CONDUIT CAT. NO. UPC NO. 25160 25160 50302 50302 15362 15362 30194 30194 441-4 6500 lbs. 28.9 kN 6500 lbs. 28.9 kN 5200 lbs. 23.1 kN 4200 lbs. 18.6 kN 3650 lbs. 16.2 kN 3500 lbs. 15.5 kN 441-5 6500lbs. 28.9 kN 6500 lbs. 28.9 kN 6500 lbs. 28.9 kN 6000 lbs. 26.6 kN 5500 lbs. 24.4 kN 5250 lbs. 23.3 kN 119 USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com F I S H I N G , C A B L E P U L L I N G & M AT E R I A L H A N D L I N G Cable Puller Floor Mount for 640 Tugger® and 6001 Super Tugger® • Unique floor mounting attachment for quick, reliable setups. • Heavy-duty welded steel construction for use with all Greenlee cable pullers (except Ultra Tugger™). • The only approved way to mount a cable puller to a concrete floor. Minimum 3,000 psi concrete required (205 bar). CAT. NO. UPC NO. DESCRIPTION 6037 35605 Cable Puller Floor Mount with four (4) 35607 wedge anchors 35607 35607 5/8" x 6" (15.9 mm x 152 mm) Wedge Anchor SPECIFICATIONS Maximum Rated Capacity 6,500 lbs. (28.9 kN) Weight 2.9 lbs. (1.4 kg) Nylon Cable Protector • Fits in the end of conduit to shield the cable from sharp edges as it is being fed through. • Rugged nylon resists abrasion. CAT. NO. UPC NO. DESCRIPTION 488-2 32928 Nylon Cable Protector for 2" and 2-1/2" conduit 488-3 32929 Nylon Cable Protector for 3" - 6" conduit. SPECIFICATIONS Weight 488-2 – .08 lbs. (36 g) 488-3 – .2 lbs. (90 g) Cable Guide • Position where cables are being pulled over sharp edges. CAT. NO. UPC NO. DESCRIPTION 489 32930 Cable Guide SPECIFICATIONS Weight 489 – .5 lbs. (227 g) Manhole Sheaves for Easy Tugger™, Tugger ® and Super Tugger ® • High strength aluminum alloy frame for easy setup. • Adjustable, a full range of sheave pin positions over the frame length to accommodate most manhole setups. • 18" (457 mm) diameter aluminum alloy sheaves with 7" (178 mm) minimum radius and 5" (127 mm) width. • Self-lubricating bearings for easier cable pulling. • Available in 3 sizes and capacities. • Select a sheave with maximum rated capacity that meets or exceeds the cable puller’s maximum pulling force. SPECIFICATIONS Maximum Rated Capacity 120 Weight CAT. NO. UPC NO. 671 – 4,000 lbs. (17.8 kN) 671 – 104 lbs. (47.2 kg) DESCRIPTION 671 15345 10' (3 m) Manhole Sheave 6072 – 6,500 lbs. (28.9 kN) 6072 – 190 lbs. (86.2 kg) 6072 31395 12' (3.7 m) Manhole Sheave NOTE: Rope is a very critical link in the cable pulling system. See pages 102 & 103 for proper pulling rope selection. USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com Cable Pulling Lubricant Selection Guide APPLICATION Temperature Range (°F) Temperature Range (°C) Base Average Coefficient of Friction* in PVC Conduit Average Coefficient of Friction* in EMT Conduit COMPATIBILITY (Cable Type) Rubber Neoprene Nylon PVC High-density or cross linked polyethylene Low-density polyethylene Semiconducting jacket Hypalon Cable-Cream™ Cable-Gel™ Winter-Gel™ Fiber-Gel™ 20°F - 190°F -6°C - 88°C Polymer 0.27 0.29 28°F - 190°F -2°C - 88°C Wax 0.11 0.17 32°F - 190°F 0°C - 88°C Polymer 0.19 0.27 -25°F - 190°F -31°C - 88°C Polymer 0.23 0.21 32°F - 190°F 0°C - 88°C Polymer 0.19 ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ *COF determined using IEEE testing procedures. The lower the COF number, the less friction experienced when pulling. Clear Lube™ R R LISTED • • • • • Designed for use within electrical or datacom cable pulls. Clear and colorless for quick, easy clean-up. Excellent lubricity for fast pulls (.27-.29 COF). Environmentally safe, non-hazardous, non-toxic and non-corrosive. Easy to apply either by hand, brush or pump. CAT. NO. UPC NO. DESCRIPTION CLR-Q CLR-1 CLR-5 10437 10438 10439 Clear Lube pulling lubricant, 1 quart (.95 l) Clear Lube pulling lubricant, 1 gallon (3.79 l) Clear Lube pulling lubricant, 5 gallon (18.93 l) F I S H I N G , C A B L E P U L L I N G & M AT E R I A L H A N D L I N G Clear Lube™ SPECIFICATIONS Temperature Range Remains stable over a wide range of temperatures, 20° F to 190° F (-6° C to 88° C) Polymer base with no silicon additives. Average coefficient of friction (IEEE, 375-2 test procedure), .27 in PVC and .29 in EMT. Three-year shelf life with no deterioration in lubricant. 121 USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com F I S H I N G , C A B L E P U L L I N G & M AT E R I A L H A N D L I N G Cable-Cream™ Cable Pulling Lubricant R R LISTED • • • • • • Advanced formula, light yellow cream makes pulling faster and easier. Compatible with all cable insulation types. Dries slowly to a thin, non-conductive, non-hardening residue. Adheres well to the cable without messy dripping. Reduces waste. Cleans up easily. Non-staining. Won’t break down or separate after exposure to freezing cold or blistering heat. • Environmentally safe/non-hazardous. CAT. NO. UPC NO. DESCRIPTION CRM-Q CRM-1 CRM-5 CRM-55 35207 35208 35209 35210 Cable-Cream™ One Quart Squeeze Bottle (.95 l) Cable-Cream™ One Gallon (3.79 l) Cable-Cream™ 5 Gallons (18.93 l) Cable-Cream™ 55 Gallons (208.18 l) SPECIFICATIONS Weight CRM-Q – 2.3 lbs. (1 kg) CRM-5 – 42 lbs. (19.1 kg) CRM-1 – 9.5 lbs. (4.3 kg) CRM-55 – 459 lbs. (208.2 kg) Viscosity 30,000 - 45,000 CPS PH Range 7.0 - 8.0 Cable-Gel™ Cable Pulling Lubricant R R LISTED • Polymer based lubricant offers lower friction and easier pulling. • Compatible with all cable insulation types. • Cleans up quickly. Non-staining. • Higher lubricity than competitive products. • • • • Will not cement itself to the pipe. Dries slowly. Can be applied by hand or pump. Will not breakdown or separate after exposure to heat or cold. • Environmentally safe/ non-hazardous. CAT. NO. UPC NO. DESCRIPTION GEL-Q GEL-1 GEL-5 GEL-55 35211 35212 35213 35214 Cable-Gel™ One Quart Squeeze Bottle (.95 l) Cable-Gel™ One Gallon (3.79 l) Cable-Gel™ 5 Gallons (18.93 l) Cable-Gel™ 55 Gallons (208.18 l) SPECIFICATIONS Weight GEL-Q – 2.3 lbs. (1 kg) GEL-5 – 45 lbs. (20.4 kg) GEL-1 – 8.5 lbs. (3.9 kg) GEL-55 – 498 lbs. (225.9 kg) Viscosity 8,000 - 12,000 CPS PH Range 7.0 - 8.0 Winter-Gel™ Cable Pulling Lubricant • Winter-Gel™ will not freeze until -25° F (-31° C). • Reduces friction for easy pulling. • Compatible with all cable insulation types. • • • • Cleans up quickly and easily. High lubricity. Can be used all year long. Environmentally safe. CAT. NO. UPC NO. DESCRIPTION WGEL-Q WGEL-1 WGEL-5 35215 35216 35217 Winter-Gel™ Pulling Lube One Quart Squeeze Bottle (.95 l) Winter-Gel™ Pulling Lube One Gallon (3.79 l) Winter-Gel™ Pulling Lube 5 Gallons (18.93 l) SPECIFICATIONS Weight 122 WGEL-Q – 2.3 lbs. (1 kg) WGEL-1 – 9 lbs. (4.1 kg) WGEL-5 – 44 lbs. (20 kg) Viscosity 10,000 - 14,000 CPS PH Range 7.0 - 8.0 USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com Fiber-Gel™ Cable Pulling Lubricant CAT. NO. FIBR-Q FIBR-1 FIBR-5 UPC NO. 02040 02041 02045 DESCRIPTION Fiber-Gel™ One Quart Squeeze Bottle (.95 l) Fiber-Gel™ One Gallon (3.79 l) Fiber-Gel™ 5 Gallons (18.93 l) SPECIFICATIONS Weight FIBR-Q – 2.3 lbs. (1 kg) FIBR-1 – 8.5 lbs. (3.9 kg) FIBR-5 – 45 lbs. (20.4 kg) Viscosity 2,000 - 3,000 CPS PH Range 7.0 - 8.0 Lube Spreader Swab • • • • Spreads a coat of wire lubricant in duct before installation of cable. Cleans mud, dirt, and light debris from duct before pulling. Tapered shape permits bi-directional use. Will not damage inner walls of duct. CAT. NO. 16854 16856 16857 16858 16859 17370 17571 UPC NO. 16854 16856 16857 16858 16859 17370 17571 DUCT SIZE INCH mm 2 50.8 2.5 63.5 3 76.2 3.5 88.9 4 102 5 127 6 152 MAXIMUM DISK SIZE INCH mm 1.75 44.5 2.25 57.2 2.75 69.9 3.25 82.6 3.75 95.3 4.75 120.7 5.75 146.1 MAXIMUM RATED CAPACITY LBS. kN 4800 21.3 4800 21.3 4800 21.3 4800 21.3 4800 21.3 4800 21.3 4800 21.3 WEIGHT LBS. kg .5 .23 .6 .27 1.5 .68 2.0 .91 2.5 1.13 3.5 1.59 4.0 1.81 F I S H I N G , C A B L E P U L L I N G & M AT E R I A L H A N D L I N G • Synthetic gel is specially designed for lightweight fast pulling of fiber optic cables. • Compatible with all cable jackets. • Cleans up easily. • Environmentally safe. • Operating range from 32° - 190° F (0°C - 88°C). • Compatible with pre-lubricated innerducts. • Dries slowly and leaves a long lasting lubricating film. Wire Duct Brush • Flat steel bristles for maximum cleaning of sand, grit and light obstructions from duct. • Pulling eye on one end and smaller twisted eye on the other end for tailing line allows bi-directional use. • Can be pulled to loosen dried material before using mandrels or spreader swabs. CAT. NO. 39274 39276 39278 39280 39282 39284 39286 UPC NO. 39274 39276 39278 39280 39282 39284 39286 DUCT SIZE INCH mm 2 50.8 2.5 63.5 3 76.2 3.5 88.9 4 102 5 127 6 152 MINIMUM DIAMETER INCH mm 1.87 47.5 2.38 60.5 2.87 72.9 3.38 85.9 3.87 98.3 4.87 123.7 5.87 149.1 MAXIMUM RATED CAPACITY LBS. kN 200 .89 200 .89 200 .89 200 .89 200 .89 200 .89 200 .89 WEIGHT LBS. kg .83 .38 .83 .38 .83 .38 .90 .41 .95 .43 1.15 .52 1.28 .58 NOTE: Rope is a very critical link in the cable pulling system. See pages 102 & 103 for proper pulling rope selection. 123 USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com F I S H I N G , C A B L E P U L L I N G & M AT E R I A L H A N D L I N G Flexible Mandrel • Useful for cleaning out mud, dirt, and light obstacles from ducts before installation of cable. • Can be used around tight bends due to convex contacts between disks. • Tapered profile allows pulling in either direction. Pulling eyes on both ends. • Polyurethane disks do not damage inner walls of duct. CAT. NO. 39265 39263 39261 39259 39257 39255 39288 UPC NO. 39265 39263 39261 39259 39257 39255 39288 DUCT SIZE INCH mm 2 50.8 2.5 63.5 3 76.2 3.5 88.9 4 102 5 127 6 152 MAXIMUM DISK SIZE INCH mm 1.88 47.7 2.19 55.6 2.81 71.4 3.25 82.5 3.75 95.3 4.69 119.1 5.81 147.5 MAXIMUM RATED CAPACITY LBS. kN 2330 10.3 2330 10.3 2330 10.3 4800 21.3 4800 21.3 4800 21.3 4800 21.3 WEIGHT LBS. kg 1 .45 1 .45 1.5 .68 3.5 1.59 4.5 2.04 6 2.72 8.5 3.85 Rope to Swivel Connectors • Rope to swivel connectors connect the cable pulling rope, up to 1" (254 mm) in diameter, to the pulling swivel. • Makes connecting the pulling rope and the pulling swivel easier. • Connectors feature a removable sheave for rope eye. • Select the connector with a maximum rated capacity that meets or exceeds the cable puller’s maximum pulling force. CAT. NO. UPC NO. MAX. RATED CAP. IN CONDUIT OR UNDERGROUND LBS. kN MAX. RATED CAPACITY OVERHEAD LBS. kN “E” DIAMETER IN. mm LENGTH IN. mm IN. mm “F” DIA IN. mm 13/32 10.32 USE ON SWIVEL 39107 39905 39905 5,000 22.2 3,000 13.3 2 50.8 4-11/16 119 7/16 11.12 39904 39904 7,000 31.1 4,200 18.6 2 50.8 4-11/16 119 1/2 12.7 1/2 12.7 39108 39903 39903 10,000 44.4 6,000 26.6 2 50.8 4-11/16 119 9/16 14.3 5/8 15.9 39109 39902 39902 10,000 44.4 6,000 26.6 2 50.8 4-11/16 119 11/16 17.5 11/16 17.5 39110 CAT. NO. UPC NO. DESCRIPTION 39849 39849 Replacement Sheave 39850 39850 Replacement Sheave Pin "E" “E” "F" “F” 124 USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com Swivels Helps eliminate winding and tangling of rope and cable during pull. Connects grip and pulling rope. All stainless steel body construction. Efficient thrust and roller bearing construction allows smooth rotation, even under full load. • Clevis pins are “shoulder bolt” style, so load on both sides of clevis is taken on the shoulder, not on the thread. • Select the swivel with a maximum rated capacity that meets or exceeds the cable puller’s maximum pulling force. B E A D F G CAT. NO. UPC NO. 39106 39107 39108 39109 39110 39111 39106 39107 39108 39109 39110 39111 MAXIMUM RATED CAPACITY LBS. kN 2,250 11.1 5,000 22.2 7,000 31.1 10,000 44.4 15,000 66.7 25,000 111.2 A DIAMETER INCH mm 7/8 1-1/4 1-3/8 1-5/8 2 2-1/2 22.2 31.8 34.9 41.3 50.8 63.5 B INCH C mm 2-5/8 66.7 3-1/16 77.8 3-9/32 83.3 3-15/16 100 4-11/16 119.1 5-11/16 144.5 D INCH mm INCH 3-1/2 4-1/8 4-17/32 5-7/16 6-9/16 8-7/16 88.9 104.5 115.1 138.1 166.7 214.3 7/16 17/32 5/8 3/4 15/16 1-3/16 E F DIAMETER mm INCH mm INCH mm 11.1 13.5 15.9 19.1 23.8 30.2 3/8 1/2 9/16 5/8 3/4 1 9.5 12.7 14.3 15.9 19.1 25.4 5/16 13/32 1/2 5/8 11/16 7/8 7.9 10.3 12.7 15.9 17.5 22.2 G INCH 31/32 1-9/32 1-3/8 1-23/32 2 2-25/32 WEIGHT REPLACEMENT * PIN KIT mm LBS. kg UPC NO. 24.6 32.5 34.9 43.7 50.8 70.6 .4 .16 1.0 .45 1.0 .45 2.0 .91 4.0 1.81 7.0 3.18 39112 39113 39114 39115 39116 39117 * Replacement Pin Kits contain two (2) Replacement Pins Breakaway Swivels BREAKAWAY PIN KITS D C F A E B • Acts as a mechanical fuse, breaking away at a preset load to prevent damage to expensive cable. • Breakaway pins can be replaced to change breakaway values. CAT. NO. 39294 39295 39296 39297 39302 39303 39304 39306 39308 UPC NO. 39294 39295 39296 39297 39302 39303 39304 39306 39308 BREAKING POINT LBS. 200 lbs. 400 lbs. 600 lbs. 675 lbs. 200 lbs. 400 lbs. 600 lbs. 800 lbs. 1000 lbs. BREAKING POINT kN 0.9 kN 1.8 kN 2.7 kN 3.0 kN 0.9 kN 1.8 kN 2.7 kN 3.6 kN 4.4 kN COLOR CODE WHITE YELLOW ORANGE BLACK WHITE YELLOW ORANGE GREY RED USE WITH 39290 5/8" Swivel 39298 7/8" Swivel BREAKAWAY SWIVEL BODY ONLY A B C D E F CAT. NO. UPC NO. INCH mm INCH mm INCH mm INCH mm INCH mm INCH mm 39290 39290 5/8 15.9 3-7/32 81.8 9/32 7.1 2-23/32 69.1 7/16 11.1 1/4 6.4 39298 39298 7/8 22.2 4-7/32 107.2 3/8 9.5 3-11/32 84.9 17/32 13.5 5/16 7.9 F I S H I N G , C A B L E P U L L I N G & M AT E R I A L H A N D L I N G C • • • • • Pins sold in bags of 10 only. • Breakaway values are ±15%. Rope Clevis • Removable bolt and rope sheave. • Removable grip eye bolt. • Select the clevis with a rating that meets or exceeds the cable puller’s maximum pulling force. • Removable sheave for rope eye. For forged eye grips 578 For forged eye grips 579 CAT. NO. 578 579 678 UPC NO. 31910 31905 19524 DESCRIPTION Rope Clevis Rope Clevis Rope Clevis SPECIFICATIONS For flexible eye grips 678 Maximum Rated Capacity 578 – 6,500 lbs. (28.9 kN) 579 – 10,000 lbs. (44.4 kN) 678 – 6,500 lbs. (28.9 kN) Weight 578 – 0.9 lbs. (408 g) 579 – 1.3 lbs. (589 g) 678 – 1.3 lbs. (589) NOTE: Rope is a very critical link in the cable pulling system. See pages 102 & 103 for proper pulling rope selection. 125 USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com F I S H I N G , C A B L E P U L L I N G & M AT E R I A L H A N D L I N G Set Screw Clamp Pulling Grips 629 624L Each grip has two opposed set screws that provide positive locking. Openings in wire grip should be 50% filled with wire to assure slip-proof grip. • Use to pull in 2" (50.8 mm) or larger conduit. • Type of pulls: heavy, long runs. • Type of grip: Flexible eye 1/4" (6.4 mm) diameter galvanized steel aircraft cable connected to 2 cable receptacles with 5/8" (15.9 mm) diameter opening and 2 clamping set screws. • Select pulling grips with a maximum rated capacity that meets or exceeds the cable puller’s maximum pulling force. CAT. NO. 629 UPC NO. 31855 624 624S 624L 52352 31908 31866 31867 52352 51208 51208 DESCRIPTION Pulling Grip with Clevis includes 624S, 624L and 678 clevis – 4 clamp Pulling Grip includes 624S and 624L – 2 clamp each Short Pulling Grip – 2 clamp Long Pulling Grip – 2 clamp Grip Set Screw (2 per clamp). 629 and 624 – 8 for each grip 624L and 624S – 4 for each grip Grip Allen Wrench SPECIFICATIONS Maximum Rated Capacity 629 – 6,500 lbs. (28.9 kN) 624 – 6,500 lbs. (28.9 kN) 624S – 3,250 lbs. (14.5 kN) 624L – 3,250 lbs. (14.5 kN) Weight 629 – 5 lbs. (2.3 kg) 624S – 2 lbs. (.9 kg) 624 – 3.5 lbs. (1.5 kg) 624L – 2.1 lbs. (1 kg) Set Screw Clamp Type Pulling Grip • Use to pull in 2" (50.8 mm) or larger conduit. • Type of pull: light and medium • Type of grip: Flexible eye 1/4" (6.3 mm) diameter galvanized steel aircraft cable connected to a cable receptacle with a 5/8" (15.9 mm) diameter opening and 2 clamping set screws. CAT. NO. 504 52352 51208 UPC. NO. 23665 52352 51208 DESCRIPTION Set Screw Clamp Type Pulling Grip Set Screw – 4 per clamp 3/8" Allen Wrench SPECIFICATIONS Size Receptacle – 5/8" (15.9 mm) Capacity 1,750 lbs. (7.7 kN) Weight 1.2 lbs. (.5 kg) Cable Preparation Instructions Strip cable approximately 3" (76 mm) of insulation off the end of the cable to be pulled. NOTE: The grip head should not be more than 60% filled nor less than 40% filled to assure that the set screw does not project above the surface of the grip body when the set screws are tightened down. The central core should be clipped away and the outer strands used in the grip head. Using the Allen Wrench provided, back out the set screws far enough to accommodate the stripped cables. Insert the bare wire strands into the grip head as far as they will go. Tighten both set screws in each grip law securely against the conductors. CAUTION: If the set screws set extend above the surface of the gripping head, damage to the conduit could result. To prevent this, wrap the head with electrical tape. 126 USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com Pulling Grip Selection Guide 1. SELECT THE TYPE OF GRIP NEEDED. SIZE RANGE MAX. RATED DIA. INCHES CAPACITY – LBS. (mm) (kN) USE TO PULL GRIP TYPE DESCRIPTION TYPE OF EYE Junior Grips Single weave galvanized steel mesh Flexible .19-1.24 (4.8-31.5) 708 (3.5) In conduit or tray – Building wire by hand. Light Duty Grips Single weave galvanized steel mesh Flexible .50-3.99 (12.7-101.3) 2940 (13.1) In conduit or tray – Light-duty applications, short easy runs. T-Type Grips Double weave galvanized steel mesh Flexible .50-3.99 (12.7-101.3) 6200 (27.6) In conduit or tray – Medium-duty applications K-Type Grips Double weave galvanized steel mesh Rotating forged .50-6.99 (12.7-177.5) 9600 (42.7) In conduit or tray – Heavy-duty applications, long hard runs. Multiple Strength Grips Triple to double to single weave galvanized steel mesh Rotating forged .25-3.99 (6.4-101.3) 9600 (42.7) Overhead transmission lines – Bare or insulated conductors, wire rope. Slack Grips Rod Closing Double weave galvanized steel mesh – rod closing – offset eye Flexible .50-3.99 (12.7-101.3) 2400 (10.7) Where end of conductor is not available. Can be pulled straight only, rod will not flex. 2. SELECT THE SIZE OF GRIP NEEDED. After determining the type of grip needed, measure the diameter of the cable being pulled. If pulling more than one cable “of the same diameter,” refer to chart below for required grip diameter range. If pulling more than one cable “of different diameters,” bundle cables together, measure the circumference and refer to the chart on bottom of this page for required grip diameter range. Once the cable diameter or required grip diameter is determined, refer to individual chart for type of grip chosen to locate Catalog/UPC number. CABLES WITH THE SAME DIAMETER IN ONE GRIP* 2 CABLES DIA. EACH IN./(mm) 3 CABLES DIA. EACH IN./(mm) 4 CABLES DIA. EACH IN./(mm) 5 CABLES DIA. EACH IN./(mm) 6 & 7 CABLES DIA. EACH IN./(mm) 8 CABLES DIA. EACH IN./(mm) 9 CABLES DIA. EACH IN./(mm) REQUIRED GRIP DIAMETER IN./(mm) .30-.38/(7.6-9.7) .25-.31/(6.4-7.9) .22-.27/(5.6-6.9) .19-.24 /(4.8-6.1) .17-.22/(4.3-5.6) .15-.19/(3.8-6.1) .14-.18/(3.6-4.6) .50-.61/(12.7-15.5) .38-.44/(9.7-11.2) .31-.36/(7.9-9.1) .27-.31/(6.9-7.9) .24-.29/(6.1-7.4) .22-.26/(5.6-6.6) .19-.23/(6.1-5.8) .18-.21/(4.6-5.3) .62-.74/(15.7-18.8) .44-.59/(11.2-15.0) .36-.49/(9.1-12.4) .31-.42/(7.9-10.7) .29-.38/(7.4-9.7) .26-.34/(6.6-8.6) .23-.31/(5.8-7.9) .21-.28/(5.3-7.1) .75-.99/(19.1-25.1) .59-.75/(15.0-19.1) .49-.63/(12.4-16.0) .42-.54/(10.7-13.7) .38-.48/(9.7-12.2) .34-.43/(8.6-10.9) .31-.39/(7.9-9.9) .28-.35/(7.1-8.9) 1.00-1.24/(25.4-31.5) .75-.90/(19.1-22.9) .63-.76/(16.0-19.3) .54-.65/(13.7-16.5) .48-.58/(12.2-14.7) .43-.52/(10.9-13.2) .39-.46/(9.9-11.7) .35-.42/(8.9-10.7) 1.25-1.49/(31.8-37.8) .90-1.07/(22.9-27.2) .76-.89/(19.3-22.6) .65-.77/(16.5-19.6) .58-.67/(14.7-17.0) .52-.60/(13.2-15.2) .46-.54/(11.7-13.7) .42-.49/(10.7-12.4) 1.50-1.74/(38.1-44.2) 1.07-1.22/(27.2-31.0) .89-1.02/(22.6-25.9) .77-.88/(19.6-22.4) .67-.77/(17.0-19.6) .60-.69/(15.2-17.5) .54-.62/(13.7-15.7) .49-.56/(12.4-14.2) 1.75-1.99/(44.5-50.5) 1.22-1.53/(31.0-39.9) 1.02-1.28/(25.9-32.5) .88-1.10/(22.4-27.9) .77-.96/(19.6-24.2) .69-.86/(17.5-21.8) .62-.77/(15.7-19.6) .56-.71/(14.2-18.00) 2.00-2.49/(50.8-63.2) 1.53-1.83 / (38.9-46.5) 1.28-1.53/(32.5-38.9) 1.10-1.32/(27.9-33.5) .96-1.16/(24.2-29.5) .86-1.03/(21.8-26.2) .77-.93/(19.6-23.6) .71-.85/(18.0-21.6) 2.50-2.99/(63.5-75.9) 1.83-2.14/(46.5-54.4) 1.53-1.79/(38.9-45.5) 1.32-1.54/(33.5-39.1) 1.16-1.35/(29.5-34.3) 1.03-1.20/(26.2-30.5) .93-1.08/(23.6-27.4) .85-.99/(21.6-25.1) 3.00-3.49/(76.2-88.6) 2.14-2.44 / (54.4-62.0) 1.79-2.05/(45.5-52.0) 1.54-1.76/(39.1-44.7) 1.35-1.54/(34.3-39.1) 1.20-1.37/(30.5-34.8) 1.08-1.24/(27.4-31.5) .99-1.13/(25.1-28.7) 3.50-3.99/(88.9-101.3) 2.44-2.75/(62.0-69.9) 2.05-2.30/(52.0-58.4) 1.76-1.98/(44.7-50.3) 1.54-1.74/(39.1-44.2) 1.37-1.55/(34.8-39.4) 1.24-1.39/(31.5-35.3) 1.13-1.27/(28.7-32.3) 4.00-4.49/(101.6-114.0) 2.75-3.06/(69.9-77.7) 2.30-2.56/(58.4-65.0) 1.98-2.20/(50.3-55.9) 1.74-1.93/(44.2-49.0) 1.55-1.72/(39.4-43.7) 1.39-1.55/(35.3-39.4) 1.27-1.41/(32.3-35.8) 4.50-4.99/(114.3-126.7) F I S H I N G , C A B L E P U L L I N G & M AT E R I A L H A N D L I N G How to select correct pulling grip: 1. Select the type of grip needed. 2. Select the size of grip needed (see below). 3. Select a grip with maximum rated capacity that meets or exceeds the cable puller’s maximum pulling force. * Split grips require the next larger size. NOTE: Rope is a very critical link in the cable pulling system. See pages 102 & 103 for proper pulling rope selection. 127 USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com MEASURE THE CIRCUMFERENCE OF THE WIRE BUNDLE. F I S H I N G , C A B L E P U L L I N G & M AT E R I A L H A N D L I N G CIRCUMFERENCE RANGE REQUIRED GRIP DIAMETER INCH mm INCH mm 1.57- 1.95 39.9- 49.5 .50- .61 12.7- 15.5 1.95- 2.36 49.5- 59.9 .62- .74 15.8- 18.8 2.36- 3.14 59.9- 79.8 .75- .99 19.1- 25.1 3.14- 3.93 79.8- 99.8 1.00-1.24 25.4- 31.5 3.93- 4.71 99.8-119.6 1.25-1.49 31.8- 37.8 4.71- 5.50 119.6-139.7 1.50-1.74 38.1- 44.2 5.50- 6.28 139.7-159.5 1.75-1.99 44.5- 50.5 6.28- 7.85 159.5-199.4 2.00-2.49 50.8- 63.2 7.85- 9.42 199.4-239.3 2.50-2.99 63.5- 75.9 9.42-11.00 239.3-279.4 3.00-3.49 76.2- 88.6 11.00-12.57 279.4-319.3 3.50-3.99 88.9-101.3 12.57-14.14 319.3-359.2 4.00-4.49 101.6-114.0 14.14-15.71 359.2-399.0 4.50-4.99 114.3-126.7 Basket Type Pulling Grip Sets • Handy set gives you the size range you need. • Have the correct grip on the job and save time. CAT. NO. UPC NO. DESCRIPTION 30758 30758 Building Wire Junior Grip Set – diameter range .25" - 1.24" (6.4 - 31.5 mm). Consists of 30588, 30590, 30592 and 30594, 30584, 30586. 597 31482 T-Type Grip Set – diameter range .75" - 1.99" (19 - 50.5 mm). Consists of 30576, 30578 and 31010. 598 31483 T-Type Grip Set – diameter range 1.50" - 2.99" (38.1 75.9 mm). Consists of 31010, 30580 and 31012. 599 31484 T-Type Grip Set – diameter range .75" - 2.99" (19 - 75.9 mm). Consists of 30576, 30578, 31010, 30580 and 31012. SPECIFICATIONS 30758 Capacity 30758 – (2) #14 to 4 1/0, .25" - 1.24" (6.4 - 31.5 mm) diameter 597 – 3-1/0 to 250 MCM, .75" - 1.99" (1.9 - 50.5 mm) diameter 598 – 3-350 MCM to 3-750 MCM, 1.50" - 2.99" (38.1 - 75.9 mm) diameter 599 – 3-1/0 to 3-750 MCM, .75" - 2.99" (1.9 - 75.9 mm) diameter Weight 30758 – 1.2 lbs. (.5 kg) 598 – 9.9 lbs. (4.5 kg) 597 – 6 lbs. (2.7 kg) 599 – 13 lbs. (5.9 kg) Junior Basket Type Pulling Grips • • • • CABLE DIAMETER RANGE 128 INCH mm Use to pull in: conduit or tray. Type of pulls: building wire manually. Type of grip: single weave galvanized steel mesh with flexible pulling eye. Select the grip with a maximum rated capacity that meets or exceeds the cable puller’s maximum pulling force. MAXIMUM RATED CAPACITY LBS. EYE LENGTH MESH LENGTH CAT. NO. UPC NO. kN INCH 30596 30596 .19 - .24 4.8 - 6.1 80 .3 3-1/4 mm 82.6 INCH 4-1/4 30584 30584 .25 - .36 6.2 - 9.1 90 .4 3-1/4 82.6 4-1/4 108 30586 30586 .37 - .49 9.2 - 12.6 180 .8 3-3/4 95.3 7 177.8 30588 30588 .50 - .61 12.7 - 15.50 260 1.1 4-1/4 108 30590 30590 .62 - .74 15.6 - 18.9 390 1.7 5 127 30592 30592 .75 - .99 19 - 25.3 560 2.4 5-3/4 30594 30594 1.00 - 1.24 25.4 - 31.5 780 3.4 6-1/2 8-1/2 mm 108 215.9 10 254 146 10 254 165.1 11-1/2 292.1 USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com Light-Duty Basket Type Pulling Grips CABLE DIAMETER RANGE CAT. NO. UPC NO. INCH Use to pull in: conduit or tray. Type of pulls: light-duty, short, easy runs. Type of grip: single weave galvanized steel mesh with flexible pulling eye. Select the grip with a maximum rated capacity that meets or exceeds the cable puller’s maximum pulling force. MAXIMUM RATED CAPACITY mm LBS. kN EYE LENGTH MESH LENGTH INCH mm INCH mm STANDARD 30536 30536 .50 - .61 12.7 - 15.5 560 2.5 5 127 16 406.4 30538 30538 .62 - .74 15.6 - 18.9 560 2.5 5 127 16 406.4 30540 30540 .75 - .99 19.0 - 25.3 800 3.5 6 152.4 20 508 30542 30542 1.00 - 1.24 25.4 - 31.5 1360 6 7 177.8 20 508 30544 30544 1.25 - 1.49 31.6 - 38 1360 6 7 177.8 21 533.4 30546 30546 1.50 - 1.99 38.1 - 50.7 1360 6 8 203.2 23 584.2 30548 30548 2.00 - 2.49 50.8 - 63.4 1700 7.5 9 228.6 25 635 30550 30550 2.50 - 2.99 63.5 - 76.1 2120 9.4 9 228.6 27 685.8 30552 30552 3.00 - 3.49 76.2 - 88.8 2940 13 10 254 30 762 30554 30554 3.50 - 3.99 88.9 - 101.3 2940 13 10 254 32 812.8 T-Basket Type Pulling Grips • • • • CABLE DIAMETER RANGE CAT. NO. UPC NO. INCH mm Use to pull in: conduit or tray. Type of pulls: medium-duty. Type of grip: double weave galvanized steel mesh with flexible pulling eye. Select the grip with a maximum rated capacity that meets or exceeds the cable puller’s maximum pulling force. MAXIMUM RATED CAPACITY EYE LENGTH LBS. kN INCH MESH LENGTH mm INCH mm SHORT 30558 30558 .50 - .61 12.7 - 15.5 900 4 8 203.2 21 533.4 30560 30560 .62 - .74 15.6 - 18.9 1120 4.9 8 203.2 24 610 30562 30562 .75 - .99 19.0 - 25.3 1360 6 9 228.6 24 610 30564 30564 1.00 - 1.49 25.4 - 38.0 1920 8.7 9 228.6 24 610 30566 30566 1.50 - 1.99 38.1 - 50.7 3280 14.5 11 279.4 24 610 30568 30568 2.00 - 2.49 50.8 - 63.3 3700 16.4 12 304.8 24 610 30570 30570 2.50 - 2.99 63.5 - 76.1 4900 21.7 12 304.8 24 610 30572 30572 3.00 - 3.49 76.2 - 88.8 4900 21.7 14 355.6 24 610 30574 30574 3.50 - 3.99 88.9 - 101.3 6200 27.5 14 355.6 26 660.4 914.4 F I S H I N G , C A B L E P U L L I N G & M AT E R I A L H A N D L I N G • • • • STANDARD 30576 30576 .75 - .99 19.0 - 25.3 1360 6 9 228.6 36 30578 30578 1.00 - 1.49 25.4 - 38.0 1920 8.7 9 228.6 36 914.4 31010 31010 1.50 - 1.99 38.1 - 50.7 3280 14.5 11 279.4 36 914.4 30580 30580 2.00 - 2.49 50.8 - 63.3 3700 16.4 12 304.8 36 914.4 31012 31012 2.50 - 2.99 63.5 - 76.1 4900 21.7 12 304.8 36 914.4 30582 30582 3.00 - 3.49 76.2 - 88.8 4900 21.7 14 355.6 36 31014 31014 3.50 - 3.99 88.9 - 101.3 6200 27.5 14 355.6 40 914.4 1016 NOTE: Rope is a very critical link in the cable pulling system. See pages 102 & 103 for proper pulling rope selection. 129 USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com F I S H I N G , C A B L E P U L L I N G & M AT E R I A L H A N D L I N G K-Basket Type Pulling Grips 130 • Use to pull in: conduit or tray. • Type of pulls: heavy-duty, long, hard runs. • Type of grip: double weave galvanized steel mesh with rotating forged eye. • Select the grip with a maximum rated capacity that meets or exceeds the cable puller’s maximum pulling force. CABLE DIAMETER RANGE CAT. NO. UPC NO. INCH MAXIMUM RATED CAPACITY mm LBS. kN EYE LENGTH INCH MESH LENGTH mm INCH ROTATING EYE DIA. mm INCH mm STANDARD 30442 30442 .50 - .61 12.7 - 15.5 1120 4.9 5 127 16 406.4 7/8 22.2 30998 30998 .62 - .74 15.6 - 18.9 1360 6 5 127 16 406.4 7/8 22.2 30460 30460 .75 - .99 19.0 - 25.3 1920 8.5 6 152.4 32 812.8 1 25.4 31000 31000 1.00 - 1.49 25.4 - 38.0 3280 14.5 7 177.8 33 838.2 1-3/8 34.9 30462 30462 1.50 - 1.99 38.1 - 50.7 3280 14.5 7 177.8 34 863.6 1-3/8 34.9 31002 31002 2.00 - 2.49 50.8 - 63.3 5440 24.1 9 228.6 36 914.4 1-5/8 41.2 30464 30464 2.50 - 2.99 63.5 - 76.1 6600 29.3 10 254 38 965.2 1-7/8 47.6 31004 31004 3.00 - 3.49 76.2 - 88.8 8200 36.5 10 254 39 990.6 1-7/8 47.6 30466 30466 3.50 - 3.99 88.9 - 101.5 9600 42.7 10 254 41 1041.4 1-7/8 47.6 31006 31006 4.00 - 4.49 101.6 - 114.2 9600 42.7 10 254 42 1066.8 1-7/8 47.6 30468 30468 4.50 - 4.99 114.3 - 126 9600 42.7 10 254 58 1473.2 1-7/8 47.6 30470 30470 5.00 - 5.99 127 - 152.3 9600 42.7 10 254 60 1524 1-7/8 47.6 Multiple Strength Basket Type Pulling Grips with Rotating Forged Eye • Use to pull overhead transmission lines, bare or insulated conductors and wire rope. • Type of pulls: heavy-duty, long distance. • Triple, to double, to single weave galvanized steel mesh with rotating forged eye. • Color coded for easy size identification. • Select the grip with a maximum rated capacity that meets or exceeds the cable puller’s maximum pulling force. CABLE DIAMETER RANGE MAXIMUM RATED CAPACITY COLOR CODE EYE LENGTH MESH LENGTH ROTATING EYE DIAMETER CAT. NO. UPC NO. INCH mm LBS. kN INCH mm INCH mm INCH mm 30474 30474 .25 - .49 12.7 - 15.5 1360 6 Dark Green 5 127 26 660.4 7/8 22.3 30476 30476 .50 - .74 15.6 - 18.9 2000 8.8 Brown 6 152.4 32 812.8 1 25.4 30478 30478 .75 - .99 19.0 - 25.3 2880 12.8 Light Blue 6 152.4 41 1041.4 1 25.4 30480 30480 1.00 - 1.24 25.4 - 31.5 4920 21.8 Gold 8 203.2 52 1320.8 1-3/8 34.9 30482 30482 1.25 - 1.49 31.6 - 38.0 6120 27.2 Black 8 203.2 56 1422.4 1-5/8 41.2 30484 30484 1.50 - 1.74 38.1 - 44.3 6120 27.2 Red 9 228.6 60 1524.0 1-7/8 47.6 30486 30486 1.75 - 2.24 44.4 - 56.9 9600 42.7 Dark Blue 10 254 70 1778.0 1-7/8 47.6 30502 30502 2.00 - 2.49 50.8 - 63.4 9600 42.7 Yellow 10 254 50 1270 1-7/8 47.6 30504 30504 2.50 - 2.99 63.5 - 76.1 9600 42.7 Orange 10 254 52 1320.8 1-7/8 47.6 30506 30506 3.00 - 3.49 76.2 - 88.8 9600 42.7 Aluminum 10 254 54 1371.6 1-7/8 47.6 30508 30508 3.50 - 3.99 88.9 - 101.3 9600 42.7 Light Green 10 254 56 1422.4 1-7/8 47.6 USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com Split Mesh Rod Closing Basket Type Slack Pulling Grips CABLE DIAMETER RANGE INCH mm Use to pull when the end of the conductor is not available. Type of pulls: light and straight. The rod will not flex around bends. Single weave galvanized steel mesh with rod closing and an offset flexible eye. Select the grip with a maximum rated capacity that meets or exceeds the cable puller’s maximum pulling force. MAXIMUM RATED CAPACITY LBS. kN EYE LENGTH INCH mm MESH LENGTH CAT. NO. UPC NO. 30658 30658 .50 - .61 12.7 - 15.50 300 1.3 7 177.8 INCH 6 mm 152.4 31024 31024 .62 - .74 15.6 - 18.9 360 1.6 7 177.8 8 203.2 30660 30660 .75 - .99 19 - 25.3 440 1.9 7 177.8 10 254 31026 31026 1.00 - 1.24 25.4 - 31.5 680 3 8 203.2 12 304.8 30662 30662 1.25 - 1.49 31.6 - 38.0 900 4 8 203.2 14 355.6 31028 31028 1.50 - 1.74 38.1 - 44.3 1160 5.1 9 228.6 15 381 30664 30664 1.75 - 1.99 44.4 - 50.7 1520 6.7 10 254 16 406.4 31030 31030 2.00 - 2.49 50.8 - 63.4 1800 8 10 254 19 482.6 30666 30666 2.50 - 2.99 63.5 - 76.1 2200 9.7 10 254 20 508 31032 31032 3.00 - 3.49 76.2 - 88.8 2400 10.6 12 304.8 21 533.4 30668 30668 3.50 - 3.99 88.9 -101.3 2400 10.6 12 304.8 24 610 Wire Caddies 905, 906 features: • All welded steel frame. • 6 wire spool axles with spring clip locks. • Pre-drilled caster mounting holes. 906 features: • Collapsible wire guide. • Swivel caster set with 2 locking casters for easy use. CAT. NO. UPC NO. DESCRIPTION 905 33024 Wire Caddy 906 33026 Wire Caddy with Casters and Wire Guide 33405 33405 Caster Set (2 swivel, 2 swivel lock) SPECIFICATIONS 906 Size 16" (406.4 mm) long, 26" (660.4 mm) wide and 17-1/2" (444.5 mm) high Capacity Six 500' (152.4 m) spools up to 8" (203.2 mm) in diameter of #6 thru #10 AWG 600 volt wire Weight 905 – 8 lbs. (3.63 kg); 906 – 10 lbs. (4.54 kg) F I S H I N G , C A B L E P U L L I N G & M AT E R I A L H A N D L I N G • • • • Wire Reel Support Frame • 914 consists of one frame with 2 wheels only; 2 or more 914’s and a spindle made of 1" rigid conduit are required to make a reel support set-up. • Easy to set up. Insert spindle in one 914 support frame, tighten locking screw, slide reels on spindle, insert spindle in second 914 support frame, tighten thumb screw and you’re ready to go. • Casters swivel and lock for ease of use. 14" CAT. NO. UPC NO. DESCRIPTION 914 26438 Wire Reel Support Frame SPECIFICATIONS Size 17-1/2" (444.5 mm) wide, 14" (355.6 mm) high Capacity 1" Rigid Conduit for spindle; holds 500' (152.4 m) to 2500' (762 m) reels up to 18" (457 mm) in diameter Weight 8.4 lbs. (3.81 kg) NOTE: Rope is a very critical link in the cable pulling system. See pages 102 & 103 for proper pulling rope selection. 131 USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com F I S H I N G , C A B L E P U L L I N G & M AT E R I A L H A N D L I N G Folding Hand Caddy • Holds up to 6 spools of #10 wire. • Folds down to 2-1/2" (63.5 mm) for easy storage. • Pinless design eliminates loose parts. CAT. NO. UPC NO. DESCRIPTION 9501 01202 Folding Hand Caddy SPECIFICATIONS Size 10" (254 mm) high; 18-1/2" wide (470 mm) Capacity Maximum Spool Weight: 6 – 500' (152 m) spools Maximum Spool Diameter: 7.5" (190 mm) Maximum Spool Diameter (top spindle, with empty bottom spindle): 12.5" (317.5 mm) Maximum Spool Width: 8.5" (215.9 mm) Weight 6 lbs. (2.7 kg.) Hand Caddy • • • • • 3/8" (9.5 mm) diameter solid steel spool support spindles. Spool retaining washers on spindles. Holds four 500' (152 m) spools of #10 AWG (7" dia. by 6"–10" wide) Holds up to eight 500' (152 m) spools of #12 AWG (7" dia. x 5" wide) Eliminate the need for hitch pins CAT. NO. UPC NO. DESCRIPTION 9502 08187 Hand Caddy SPECIFICATIONS Size 10-1/2" (267 mm) high; 13-1/2" wide (343 mm); 21" (533 mm) length Capacity Maximum Spool Weight : 8 – 500' (152 m) spools of #12 AWG; 4 – 500' spools of #10 AWG Maximum Spool Diameter: 9" (229 mm) Weight 4 lbs. (1.8 kg.) Data Cable Caddy • Width is ideal for large diameter spools of coax, data and communications cable. • Especially handy for 6" (152 mm) wide and up to 19" (483 mm) diameter spools. • Folds down for easy storage. • Pinless design eliminates loose parts. CAT. NO. UPC NO. DESCRIPTION 9520 01228 Data Cable Caddy SPECIFICATIONS Size 21" (533 mm) long; 28-1/2" (724 mm) wide. 11-1/2" high (292 mm) Capacity Maximum Total Spool Weight: 100 lbs. (45.4 kg) Maximum Spool Diameter: 19" (483 mm) Weight 132 11 lbs. ( 5 kg.) USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com Hand Truck Wire Cart Heavy-duty wheels for durability and easy transporting. Dual heavy-duty wire guides for dispensing multiple wires in all directions. Only 23" (584.2 mm) wide to fit through narrow doorways. Comes with five 5/8" (15.9 mm) diameter reel spindles for storing and dispensing up to fifteen spools of #14 THHN wire. • Storage space for 3 spindles and clips eliminates loose parts when they are not in use. • Expander kit available to increase capacity by 60%. CAT. NO. 38733 10462 UPC NO. 38733 10462 DESCRIPTION Hand Truck Wire Cart Expander Kit 38733 SPECIFICATIONS Size 38733 38733 Weight 10462 10462 38733 10462 46" high x 23" wide x 22-1/2" deep (1168 mm x 584.2 mm x 571.5 mm) 41" high x 12-5/8" wide (1041 mm x 321 mm) 58 lbs. (26.3 kg) 15.7 lbs. (7.1 kg) WIRE CAPACITY CHART NUMBER OF SPOOLS 38733 WITH MAXIMUM WIRE 10462 SPOOL CART EXPANDER DIAMETER (mm) 15 24 7" (178 mm) 10 16 7" (178 mm) 3 5 12" (305 mm) 3 3 14" (356 mm) 2 2 22" (559 mm) MAXIMUM SPOOL WIDTH (mm) 5-3/8" (137 mm) 8" (203 mm) 16-3/8" (416 mm) 16-3/8" (416 mm) 16-3/8" (416 mm) TYPICAL WIRE LENGTH (m) 500 ft. (152 m) 500 ft. (152 m) 2,500 ft. (762 m) 2,500 ft. (762 m) 1,000 ft. (305 m) F I S H I N G , C A B L E P U L L I N G & M AT E R I A L H A N D L I N G • • • • Hand Truck Caddy • • • • • Holds up to 12 spools of #12 AWG wire or 8 spools of #10 AWG wire. 10" (254 mm) diameter pneumatic tire for jobsite portability. Pinless design eliminates loose parts. 4 solid steel 1/2" (12.7 mm) spindles included. Lay cart flat when dispensing wire. Upright for use as hand caddy. CAT. NO. 9505 UPC NO. 01205 DESCRIPTION Hand Truck Caddy SPECIFICATIONS Size 46-5/8" (1180 mm) long. 28-1/4" (71.8 mm) wide Capacity Maximum Total Spool Weight: 200 lbs. (90.7 kg) 4000' (1219.2 m) #10 ga. wire Maximum Spool Diameter: 7.5" (190 mm) Dolly Lift (Maximum): 250 lbs. (113.4 kg) Weight 32 lbs. (14.5 kg) NOTE: Rope is a very critical link in the cable pulling system. See pages 102 & 103 for proper pulling rope selection. 133 USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com F I S H I N G , C A B L E P U L L I N G & M AT E R I A L H A N D L I N G Wire Cart • Large capacity, excellent for storing, transporting or feeding wire. • Save space, use and store vertically or horizontally. • 5 strong reel axles with spring clip retainers plus 2 positions for axle storage allows you to configure for large reels with no loose parts. • Strong, yet lightweight, tubular steel welded construction with rugged 8" (203.2 mm) wheels. • Built-in wire guide for horizontal dispensing. • Will pass through a 28" (711.2 mm) opening. 54-1/2" CAT. NO. 911 31523 50303 UPC NO. 31518 31523 50303 DESCRIPTION Wire Cart Reel Shaft (5) Hitch Clip (10) SPECIFICATIONS Size 54-1/2" (1384.3 mm) long, 27" (685.8 mm) wide, 26-1/2" (673.1 mm) high when horizontal. Capacity Six 2,500' (762 m) spools up to 16" (406 mm) in diameter. Six 500' (152.4 m) spools up to 8" (203 mm) in diameter. Weight 62 lbs. (28.12 kg) 27" Deluxe A-Frame Mobile Caddy • • • • • • Holds up to 24 spools of #12 AWG wire or 16 spools of #10 AWG wire. Folds for easy storage. 10" (254 mm) diameter pneumatic tires for jobsite portability. Pinless design eliminates loose parts. 8 solid steel 1/2" (12.7 mm) spindles included. Optional Basket caddy available to dispense metal clad cable. CAT. NO. UPC NO. DESCRIPTION 9510 01214 Deluxe A-Frame Mobile Caddy 9527 01264 Optional Basket Caddy (see p. 135) SPECIFICATIONS Size 47-7/8" (1216 mm) high. 28-1/4" (718 mm) wide Capacity Maximum Total Spool Weight: 400 lbs. (181 kg) Maximum Spool Diameter: 7.5" (190 mm) Weight 47 lbs. (21.5 kg) Large 500' Spool Caddy • • • • Holds from 40 - 60 500' (152 m) spools of #12 AWG wire. Folds for easy storage. 2 large wheels and 2 swivel casters for easy portability. Pinless design eliminates loose parts. CAT. NO. UPC NO. DESCRIPTION 9515 01218 Large 500' Spool Caddy SPECIFICATIONS Size 45-1/2" (1156 mm) high. 34-1/2" (880 mm) wide Capacity Maximum Total Spool Quantity: 60 spools 500' (152.4 m) #14 ga. wire Maximum Total Spool Weight: 600 lbs. (272.2 kg) Maximum Spool Diameter: 7.5" (190 mm) Weight 134 92 lbs. (42 kg) USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com Wire Dispenser 30" CAT. NO. 31" UPC NO. DESCRIPTION 909 22875 Wire Dispenser 52284 52284 Swivel Caster (1) 52285 52285 Wheel (2) SPECIFICATIONS Size 39" (990.6 mm) long, 30" (762 mm) wide, 31" (787.4 mm) high. Capacity Six 2,500' (762 m) spools up to 18" (457.2 m) in diameter. Weight 93 lbs. (42.18 kg) 6-Reel Caddy • • • • • Spindle sleeves to facilitate easier pay-out of wire. Holds up to six, 2,500' (762 m) foot spools of 14, 12, or 10 gauge wire. Folds for easy storage. 2 fixed and 2 locking swivel casters for easy portability. Pinless design eliminates loose parts. CAT. NO. UPC NO. DESCRIPTION 9517 01225 6-Reel Caddy SPECIFICATIONS Size 40-1/2" (1030 mm) High; 33" (838 mm) Wide Capacity Maximum Total Spool Quantity: 6 spools 2500' (762 m) #10 ga. wire Maximum Total Spool Weight: 450 lbs. (204 kg.) Maximum Spool Diameter: 15" (380 mm) Weight 60 lbs. ( 27.22 kg) Wire Dispenser F I S H I N G , C A B L E P U L L I N G & M AT E R I A L H A N D L I N G • All steel welded frame with 6 reel spindles and feeding eye. • Angled spindles keep reels in place without locks and help brake the reel while paying out. • Mobile, 2 fixed wheels and one that swivels and locks, allow easy movement and control. • Fits through a 30" (762 mm) doorway. 39" • All welded steel construction. • Base has 2 fixed and 2 swivel locking heavy duty casters. • The spool rack consists of 10 spindles and an adjustable guide loop, and can be turned 360° independent of the base. • Spindles are angled to contain reels and act as a brake while paying out wire. • Fits through a 36" (915 mm) opening. 59" CAT. NO. UPC NO. DESCRIPTION 910 21982 Wire Dispenser SPECIFICATIONS Size 36-1/4" (921 mm) long, 31-1/2" (800 mm) wide, 59" (1499 mm) high. Capacity Ten 2,500' (762 m) spools up to 18" (457.2 mm) in diameter. Weight 213 lbs. (96.62 kg) 31-1/2" 36-1/4" NOTE: Rope is a very critical link in the cable pulling system. See pages 102 & 103 for proper pulling rope selection. 135 USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com F I S H I N G , C A B L E P U L L I N G & M AT E R I A L H A N D L I N G 10-Reel Caddy • • • • • Spindle sleeves to facilitate easier pay-out of wire. Holds up to ten 2,500' (767 m) spools of 10 gauge wire. Folds down for easy storage. 2 fixed and 2 locking swivel casters for easy portability. Pinless design eliminates loose parts. CAT. NO. UPC NO. DESCRIPTION 9516 01222 10-Reel Caddy SPECIFICATIONS Size 51-1/2" (1308 mm) high. 34-1/2" (876 mm) wide Capacity Maximum Total Spool Quantity: 10 spools 2500' (762 m) #10 ga. wire Maximum Total Spool Weight: 750 lbs. (340 kg) Maximum Spool Diameter: 15" (380 mm) Weight 98 lbs. ( 44.5 kg) Cable Reel Transporter • All steel welded frame with heavy duty wheels. • Unique design provides easy setup for cable payout. • Handle folds to save space when using as a dispenser. CAT. NO. UPC NO. DESCRIPTION 916 32935 Cable Reel Transporter 33035 33035 Spool Spindle 52466 52466 Wheel Replacement Kit (2) SPECIFICATIONS Size 63" (1600.2 mm) long, 29-7/8" (759 mm) wide, 26-3/4" (679 mm) high when horizontal Capacity Reels of cable or BX up to 20" (508 mm) wide and 40" (1016 mm) in diameter maximum total reel weight 300 lbs. (136 kg) Weight 110 lbs. (49.90 kg) 63" long 29-7/8" BX-Armored Coiled Cable Dispenser • Dispense armored cable, flexible conduit, Greenfield® or NM-B cable fast and easy without twists or tangles. • Base with adjustable tension control rotates to dispense the cable without overpulling. • Large pulling eye rotates freely and can be used as a carrying handle when the dispenser is empty. CAT. NO. UPC NO. DESCRIPTION 37218 37218 Armored Cable Dispenser SPECIFICATIONS Size 13-1/2" (342.9 mm) high, 26" (660.4 mm) diameter Capacity One 250' (76.2 m) coil of 14/2, 14/3, 12/2 or 12/3 armored cable or romex. 136 Weight 31 lbs. (14.1 kg) USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com Armored Coiled Cable Dispenser/Transporter CAT. NO. UPC NO. DESCRIPTION 37202 37202 Armored Cable Dispenser/Transporter SPECIFICATIONS Size 45" (1143 mm) high, 28-1/2" (724 mm) wide, 29" (736.6 mm) deep. Capacity Dispense – One 250' (76.2 m) coil of 14/2, 14/3, 12/2 or 12/3 armored cable or romex. Transport – Three coils, maximum capacity 250 lbs. (113 kg). Weight 45 lbs. (20.4 kg) Caddy Basket Cable Dispenser STUD MOUNT CADDY (9525F) • Fits both 2x4 and 2x6 studs. • Dispense coils of NM-B or armored cable. • Swivel eyelet eliminates tangles. • Add 9529F basket to double capacity. • Folds for easy storage. MOBILE MOUNT BRACKET (9527) • Optional caddy for 9510 Deluxe A-frame Mobile Caddy. • Dispense one coil of NM-B or armored cable. • Swivel eyelet eliminates tangles. FLOOR MOUNT BRACKET (9528) • Dispense coils of NM-B or armored cable. • Swivel eyelet eliminates tangles. • Wide base for stable performance. Optional 9529F 9525F Wire Cart sold separately (see page 134) 9527 CAT. NO. 9525F Consists of: 9529F UPC NO. 02070 DESCRIPTION Folding Stud Mount Caddy 02071 Optional Caddy Basket CAT. NO. 9527 Consists of: 9532 9529 UPC NO. 01264 DESCRIPTION Caddy Bracket and Basket 01253 01232 Mobile Mount Bracket Caddy Basket CAT. NO. 9528 Consists of: 9533 9529 UPC NO. 01265 DESCRIPTION Floor Mount Caddy and Basket 01259 01232 Floor Mount Bracket Caddy Basket F I S H I N G , C A B L E P U L L I N G & M AT E R I A L H A N D L I N G • Dispense one coil of armored cable, flexible conduit, Greenfield® or NM-B cable fast and easy without twists or tangles. • Base with adjustable tension control rotates to dispense the cable without overpulling. • Large pulling eye rotates freely. • Transport up to three coils. SPECIFICATIONS 9525F Maximum Capacity 100 lbs. (45.4 kg) Weight 10.5 lbs. (4.77 kg) Size 29-1/2" (749 mm) high x 20-3/4" (527 mm) wide 9536 Weight 5 lb. (2.3 kg) Size 29-1/2" (749 mm) high 9527 Maximum Capacity 50 lbs. (22.7 kg) Weight 10.5 lbs. (4.77 kg) Size 15" (381 mm) high x 18" (457 mm) wide 9528 Maximum Capacity 50 lbs. (22.7 kg) Weight 10.5 lbs. (4.77 kg) Size 15.5 (394 mm) high x 19" (483 mm) wide 9532 Weight 5 lb. (2.3 kg) Size 5-1/2" (394 mm) high x 17-3/4" (451 mm) wide 9533 Weight 5 lbs. (2.3 kg) Size 15-1/2" (394 mm) high x 19" (483 mm) wide 9529/9529F Weight 5.5 lbs. (2.5 kg) Size 12-3/4" (324 mm) high x 20-3/4" (527 mm) wide 137 NOTE: Rope is a very critical link in the cable pulling system. See pages 102 & 103 for proper pulling rope selection. USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com F I S H I N G , C A B L E P U L L I N G & M AT E R I A L H A N D L I N G Screw Type Reel Stands • Wide welded steel base for added stability. • Roller bearings fit in the spindle groove to keep the spindle in place and turning freely. • Two stands and a spindle are required for a complete set-up. 683 CAT. NO. 683 687 684 647 25591 38619 687 UPC NO. 15372 17076 15375 15321 25591 38619 DESCRIPTION Reel Stand 22" - 54" (558.8 - 1372 mm) Reel Stand 13" - 28" (330.2 - 711.2 mm) Spindle for 683 Reel Stand Spindle for 687 Reel Stand Stop Pin (683 - 2; 687 - 1) Jackscrew Replacement Unit for 683 or 687 SPECIFICATIONS Size 683 – 24" x 23" (609.6 x 584.2 mm) base; 54" (1372 mm) maximum height 687 – 14-1/2" x 20" (368.3 x 508 mm) base; 28" (711.2 mm) maximum height Capacity 683 – 2,500 lbs. (1134 kg) each, 46" - 96" (1168 x 2438 mm) reel diameter 687 – 2,500 lbs. (1134 kg) each, 28" - 56" (711.2 x 1422 mm) reel diameter Weight 683 – 49 lbs. (22.2 kg), 687 – 25 lbs. (11.3 kg) Ratchet-Type Reel Stand • Ratchet mechanism to easily raise or lower the height. • Roller bearings fit in the spindle groove to keep the spindle in place and turning freely. • Two stands and a spindle are required for a complete set-up. CAT. NO. UPC NO. DESCRIPTION 656 657 38697 21979 21980 38697 Ratchet Reel Stand 28" - 46-5/8" (711 mm - 1184 mm) Spindle for 656 Reel Stand Jackscrew Replacement Unit SPECIFICATIONS Size Capacity Weight 24-1/2" x 23" (622 mm x 584 mm) base; 46-5/8" maximum height 3,750 lbs. (1701 kg) 58" - 90" (1473 mm - 2286 mm) reel diameter 94 lbs. (42.64 kg) Reel Stand Spindles • Tempered steel with grooves to fit reel stand rollers. CAT. NO. UPC NO. DESCRIPTION 647 657 684 15321 21980 15375 Spindle for 687 Reel Stands Spindle for 656 Reel Stands Spindle for 683 Reel Stands SPECIFICATIONS Size Capacity Weight 138 647 – 2-3/8" diameter x 62" (60.3 x 1575 mm) 657 – 3-1/2" diameter x 100" (89 x 2540 mm) 684 – 2-3/8" diameter x 76" (60.3 x 1930 mm) 647 – 5,000 lbs. (2268 kg) 59" (1500 mm) between grooves 657 – 7,500 lbs. (3402 kg) 100" (2540 mm) between grooves 684 – 5,000 lbs. (2268 kg) 73" (1854 mm) between grooves 647 – 42 lbs. (19.06 kg) 657 – 124 lbs. (56.25 kg) 684 – 50 lbs. (22.68 kg) USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com Reel Rollers 39660 Heavy-duty welded steel construction. Built-in loading ramps. Adjustable to various reel widths and diameters. Roller locks for unloading. Side ball rollers for centering. Fast, convenient ground level set-up for paying out large cable reels. CAT. NO. UPC NO. DESCRIPTION 39660 39660 39666 39666 Reel Roller, single platform roller, 32" (813 mm) long x 34" (864 mm) wide Reel Roller, kit of two rollers and two spreaders, 32" (813 mm) long x 11" (279 mm) wide per frame SPECIFICATIONS Size Capacity 39660 – 32" (813 mm) long x 34" (864 mm) wide 39666 – 32" (813 mm) long x 11" (279 mm) wide 39660 – 2,500 lbs. (1134 kg) 30" (762 mm) wide 39666 – 2,000 lbs. (907.2 kg) 42" (1067 mm) wide 39666 Conduit and Pipe Storage Rack • 7 individual bins allow you to sort by size and type. • Folds down for storage. • Casters included. CAT. NO. UPC NO. DESCRIPTION 668 15343 Mobile Conduit and Pipe Rack with casters 503 28044 6" (152.4 mm) Diameter Caster Set, 4 Swivel 603 23405 6" (152.4 mm) Diameter Caster Set, 2 Swivel and 2 Rigid SPECIFICATIONS Capacity 1000 lbs. (454 kg) Dimensions 58-1/2" (1486 mm) long x 34" (864 mm) wide x 63-1/2" (1613 mm) high Folded Down 58-1/2" (1486 mm) long x 34" (864 mm) wide x 19" (483 mm) high Weight 113 lbs. (51.3 kg) F I S H I N G , C A B L E P U L L I N G & M AT E R I A L H A N D L I N G • • • • • • 139 USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com F I S H I N G , C A B L E P U L L I N G & M AT E R I A L H A N D L I N G Pipe Cart • • • • Easy one-person operation saves time and money. Move standard 20 ft. (6.1 m) lengths of pipe. Large 4.80" x 8" (122 mm x 203 mm) wheels with 4-ply pneumatic tires. Heavy-duty steel construction for long service life. CAT. NO. UPC NO. DESCRIPTION 36745 36745 Pipe Cart SPECIFICATIONS Capacity 20" (508 mm) Diameter – 1000 lbs. (454 kg) Tradesman™ Pipe Jacks • Rapid telescope adjustment with tee-handle screw locks. • 1-1/2" (38 mm) acme thread for infinite final height adjustment. • Choice of two head configurations. Steel Roller CAPACITY WEIGHT LBS. kg CAT. NO. UPC NO. DESCRIPTION LBS. kg 36719 36719 50" (1270 mm) Tradesman w/Vee Head 2000 907 21 36720 36720 50" (1270 mm) Tradesman w/Steel Roller Head 2000 907 23 10.4 9.5 SPECIFICATIONS Height 50" (1270 mm) models, 27" to 50" (686 to 1270 mm) height range, for use with 1/2" to 24" (12.7 to 610 mm) diameter pipe. Quad Pipe Stand Steel Wheel Head • • • • • Available in 31" (788 mm). Fast roller adjustment from either side for easy pipe positioning. Bronze bearing to prevent arcing. Large tee handle wheel locks. 1/2" to 48" (12.7 to 1219 mm) pipe capacity. CAPACITY 140 CAT. NO. UPC NO. DESCRIPTION LBS. kg 36737 36737 31" (787 mm) Quad Stand w/Steel Wheel Head 2500 1134
438-5H 价格&库存
很抱歉,暂时无法提供与“438-5H”相匹配的价格&库存,您可以联系我们找货
