930XC-20C-APC-FC
930XC-20C-APC-FC
    GREENLEECOMMUNICATIONS(格林利)
    OTDRSMDUALWAVE13/15OPMSLS
930XC-20C-APC-FC 数据手册
WWW.GREENLEE.COM 930XC OTDR OPTICAL TIME-DOMAIN REFLECTOMETER FAST. ACCURATE. RELIABLE. USA PHONE 800.435.0786 FAX 800.451.2632 CANADA PHONE 866.384.8813 FAX 800.524.2853 INT’L PHONE +1.815.397.7070 FAX +1.815.397.9247 ALL IN ONE OTDR SOLUTION OPM, VFL, AND SLS STANDARD ON ALL 930XC MODELS 930XC OTDR PROTECTIVE RUBBER BOOT FAST. • One button test functions. Start measurements with the push of one button. • Autotest. Automatically sets test parameters for optimum test results. • Live fiber testing.* Tests fibers without disrupting live services. MENU FUNCTIONS for settings and trace store/recall. LARGE COLOR LCD DISPLAY ACCURATE. • Graphical interface. Easy to read, even in low or bright lighting conditions. • Up to 38 dB dynamic range. Probe longer cables and see smaller reflections. • Measure lengths and defects. Quickly locates faults. RUN/STOP BUTTON True single button testing. RELIABLE. • Cable acceptance reports. Generate customized reports that include trace signature and fiber events. • Long life battery. Work longer without recharge – up to 8 hours continuous use. • Rugged construction. Drop-tested from 2m, impact resistant and built to perform (GR-196 certified). • BellCore standard required by major telcos. – Meets all specifications at specified temperature extremes. – Operational and within specification after a simulated dust storm. – EMI resistant as per GR-1089. – Rain resistant with no direct paths of entry SEALED MEMBRANE PANEL DC CHARGER PORT OPTICAL POWER METER USB PORT VISUAL FAULT LOCATOR OTDR PORT OTDR 1625nm live out of band testing port CABLE ACCEPTANCE | FAULT LOCATING | FIBER TESTING * 930XC-30F only. Now available with password protection WWW.GREENLEE.COM OTDR CABLE ACCEPTANCE REPORT GENERATION OTDR OPERATION MODES INSTRUMENT SETUP OTDR TRACE VIEWER • View and measure all trace files stored on the 930XC • Bellcore Standard OTDR Report (SOR) file storage format • Display trace, fiber events and measurement information on single screen • Display measurement settings used to acquire trace • Auto mode selects optimal distance range and pulsewidth • All settings selected through easy to use menu selections • Short pulsewidth (5ns) available for high-resolution measurements • Color and high intensity monochrome settings for bright sunlight conditions • Complete control of fiber analysis settings for auto measurement of splice and end of fiber CABLE ACCEPTANCE REPORT • Generate professional OTDR cable acceptance reports • Cable acceptance report can be customized by user • Trace signature and fiber events are printed on each report SPECIFICATIONS MODEL Wavelength (± 20nm) Dynamic Range (dB)a Event Deadzone (m)b Attenuation Deadzone (m)b Pulsewidth 930XC-20C 930XC-30F 930XC-30P 930XC-20M 1310/1550 35 1m 4.5m 1310/1550/1625 38/37/37 1m 4.5m 1310/1490/1550 38/37/37 1m 4.5m 850/1300 21/24 ≤2.5m ≤12m 5, 10, 30, 100, 300, 1us, 2.5us, 10us, 20us 12, 30, 100, 275, 1us/30, 100, 275, 1us, 2us 0.3, 1.3, 2.5, 5, 10, 20, 40, 80, 120, 160, 240 0.1, 0.3, 0.5, 1.3, 2.5, 5, 10/0.1, 0.3, 0.5, 1.3, 2.5, 5, 10, 20, 40, 80 Selectable Ranges (km) Average Time Distance Measurement Accuracy Connector Type Reflection Detect Accuracy Attenuation Detect Accuracy Measurement Data Storage Data Transmission Visual Fault Locator (VFL) Optical Power Meter (OPM) OPM Wavelengths OPM Range OPM Display resolution OPM MOD Identification Stabilized laser Source (SLS) Power Supply Battery Life Operating Temperature Storage Temperature Relative Humidity Weight Dimensions Compliance Fiber Analysis Software Password Protection 15s/30s/1 min/2 min/3 min ±(1m + 5 X 10-5 x distance + sampling space) PC or APC (interchangeable FC, SC, ST) ±4 dB ±0.05 dB/dB 1,000 test curves RS-232/USB port -3dBm; 650nm InGaAs 850, 1300, 1310, 1490, 1550, 1625nm +6 to -70dBm (+6 to -60dBm 850nm) 0.01dB 1kHz, 2kHz Wavelength same as selected in OTDR mode ≤ -7dBm NiMH chargeable battery/AC adapter Support over 8 hours operating on one charge or over 20 hours standby -10° to 50° C -20° to 60° C 0 to 95% (non-condensing) 1.9 lbs. (0.87 kg) 7.7” H x 3.9” W x 2.4” L (196mm x 100mm x 64mm) BelCore GR196, CE, FCC, UL, WEEE Version 3.2 Owner defined password feature (Recoverable) *Specifications subject to change without notice a Using a pulse width of 20us b Using a pulse width of 5ns OTDR TRACE • View and measure test results • One button measurement of distance and loss information Event View Mode Page through each loss event for location in (meters/miles and feet) and loss in dB Manual Measurement Mode Perform manual measurement with A and B cursor for distance, loss and reflectance measurements Measurement Setup View settings used to acquire measurement Fiber Analysis Software View settings used for auto measurement of events HI-RESOLUTION EVENT VIEWING • • • • • Easy to view and measure in high-resolution mode One button to jump to high-resolution view One button jump back to entire trace view 0.1 meter sampling resolution Active cursor snaps to the next event in the fiber analysis table FOR PRODUCT VIDEOS, DEMONSTRATIONS AND MORE VISIT: www.youtube.com/GreenleeDEMO EACH MODEL COMES WITH: • Instrument • Rechargeable battery • OTDR Trace Viewer software • Installation disk • Data transfer cable • AC adapter • Protective cover • Carrying case • Warranty card • Certificate of calibration Default language is English and Spanish. Alternate languages of Russian, Portuguese, Polish, and German available upon request. ORDERING INFORMATION CAT NO. UPC NO. DESCRIPTION CAT NO. UPC NO. DESCRIPTION DUAL WAVELENGTH SINGLE MODE OTDR ACCESSORIES 930XC-20C-UPC-FC 02610 OTDR, SM DUAL WAVE, 13/15, OPM, SLS, UPC FC AC-ADPT-20-UNI 25691 Universal Power Supply 930XC-20C-UPC-SC 02609 OTDR, SM DUAL WAVE, 13/15, OPM, SLS, UPC SC AC-CONN-FC-L2 20996 FC Connector (For UPC & APC) 930XC-20C-UPC-ST 02611 OTDR, SM DUAL WAVE, 13/15, OPM, SLS, UPC ST AC-CONN-ST-L2 20997 ST Connector (For UPC) 930XC-20C-APC-FC 02613 OTDR, SM DUAL WAVE, 13/15, OPM, SLS, APC FC AC-CONN-SC-UPC-L2 06445 SC Connector (For UPC) 930XC-20C-APC-SC 02612 OTDR, SM DUAL WAVE, 13/15, OPM, SLS, APC SC AC-CONN-SC-APC-L2 ADAPTER, OPM SC (930XC) ADAPTER, OPM FC (930XC) 20998 SC Connector (For APC) 06446 OPM SC Adapter 06447 OPM FC Adapter 06448 OPM ST Adapter TRIPLE WAVELENGTH SINGLE MODE OTDR 930XC-30P-UPC-FC 02615 OTDR, SM TRIPLE PON, 13/14/15, OPM, SLS, UPC FC 930XC-30P-UPC-SC 02614 OTDR, SM TRIPLE PON, 13/14/15, OPM, SLS, UPC SC 930XC-30P-UPC-ST 02616 OTDR, SM TRIPLE PON, 13/14/15, OPM, SLS, UPC ST 930XC-30P-APC-FC 02618 OTDR, SM TRIPLE PON, 13/14/15, OPM, SLS, APC FC 930XC-30P-APC-SC 02617 OTDR, SM TRIPLE PON, 13/14/15, OPM, SLS, APC SC ADAPTER, OPM ST (930XC) AC-CONN-ST-L2 20997 ST Connector (For UPC Only) TRIPLE WAVELENGTH SINGLE MODE FILTERED OTDRS 1155-0526 10582 Vehicle Adapter (6FT, 5.5 OD, 2.1M) 930XC-30F-UPC-FC 02620 OTDR, SM TRIPLE FILT, 13/15/16, OPM, SLS, UPC FC 20988 20988 Soft Carry Case 930XC-30F-UPC-SC 02619 OTDR, SM TRIPLE FILT, 13/15/16, OPM, SLS, UPC SC 20989 20989 USB Cable For OTDR 930XC-30F-UPC-ST 02621 OTDR, SM TRIPLE FILT, 13/15/16, OPM, SLS, UPC ST 20990 20990 RS-232 Cable 930XC-30F-APC-FC 02626 OTDR, SM TRIPLE FILT, 13/15/16, OPM, SLS, APC FC 20999 20999 NiMH Battery (9.6V) 930XC-30F-APC-SC 02623 OTDR, SM TRIPLE FILT, 13/15/16, OPM, SLS, APC SC 946 60571 Cleaning Wand (10/PK) 948 60692 ReelCleaner™ Connector Cleaning System MULTI-MODE OTDR 930XC-20M-UPC-FC 02607 OTDR, MM DUAL WAVE, 85/13, OPM, SLS, UPC FC LC-500 05625 500m Universal Launch Cable 930XC-20M-UPC-SC 02606 OTDR, MM DUAL WAVE, 85/13, OPM, SLS, UPC SC FCP-2.5 03576 2.5mm Fiber Cleaning Pen 930XC-20M-UPC-ST 02608 OTDR, MM DUAL WAVE, 85/13, OPM, SLS, UPC ST FCP-1.25 03577 1.25mm Fiber Cleaning Pen SINGLE MODE/MULTI-MODE OTDR KIT SM MM KIT 27294 www.greenlee.com 930XC-20M-UPC-SC and 930XC-20C-APC-SC MA6041 02/16 1390 Aspen Way, Vista, CA, 92081 • USA • 800-642-2155 ©2016 Greenlee Textron Inc. • An ISO 9001 Company • Printed in USA Greenlee Textron Inc. is a subsidiary of Textron Inc. Greenlee sells a variety of 1m patch cords to protect your bulkhead. Please contact customer service for more details.
930XC-20C-APC-FC 价格&库存
很抱歉,暂时无法提供与“930XC-20C-APC-FC”相匹配的价格&库存,您可以联系我们找货
