60A-3/4
60A-3/4
    GREENLEECOMMUNICATIONS(格林利)
60A-3/4 数据手册
BIT,AUGER,QUICK CHANGE 3/4A (POP) 3/4 Stubby Auger Wood Bit Cat No: 52027523 UPC No: 783310124177 Description ‡ ‡ ‡ ‡ ‡ ‡ ‡ ‡ Over center single flute design for cleaner holes and less splintering Unique cutting edge design for fast and smooth cutting action Shorter than the top competitor's bit for better access to tight spaces between studs and joists Perfect for drilling 2 IN and 4 IN joists Augers have self-feeding screw point that draws bit through all wood types with less operator fatigue Eliminates the need for special tools such as expensive right angle drills or multiple steps to cut the hole to size ¼ IN hex quick change design for fast and easy use in all drill types Clearly marked with bit diameter and catalog number on shank for easy identification Specifications ‡ ‡ ‡ ‡ ‡ ‡ ‡ Application : For Drilling 2.000 IN And 4.000 IN Joists And Wood Bit Diameter : 3/4 IN (19.100 MM) Overall Length : 4.500 IN (144.000 MM) Shank Diameter : 1/4 IN Shank Type : Hexagonal Type : Stubby, Quick Change Weight : 0.300 LB (136.000 GM)
60A-3/4 价格&库存
很抱歉,暂时无法提供与“60A-3/4”相匹配的价格&库存,您可以联系我们找货
