The search is over
TAP
DRILL
DEBURR/COUNTERSINK
Finally, one bit that does it all...
Ever have to hunt around or figure out which drill bit to
use with a certain tap? Tired of using a T-handle to tap
the hole? No more, because now you've got the Greenlee
combination Drill/Tap bit, which drills the proper hole size
and taps the hole in one operation!
Made from high speed steel to ensure longer life, the
Greenlee Combo Drill/Tap Bit is designed to tap up to 10
gauge metal and has a high quality hex shank to ensure a
strong connection.
Complete hole drilling and tapping in one operation with power drill saves labor and time
Back taper beyond tap to prevent thread damage from over-drilling
Deburr/Countersink also provided on bit beyond back taper
Made from high-speed steel vs. carbon steel for longer life
High quality hex shank to ensure strong connection to drill chuck
Designed to tap up to 10 gauge metal
Material thickness - 10g
Material type - mild steel, copper, brass, aluminum
Shank - 1/4” quick change hex
Drill Material - high speed steel
Drill point - split point with web thinning
CAT. NO.
UPC NO.
QTY.
DESCRIPTION
DTAPKIT
17620
6
6-32 to 1/4-20 6 piece drill/tap set
DTAP6-32
17611
1
6-32NC drill/tap bit
DTAP8-32
17612
1
8-32NC drill/tap bit
DTAP10-24
17613
1
10-24NC drill/tap bit
DTAP10-32
17614
1
10-32NF drill/tap bit
DTAP12-24
17615
1
12-24NC drill/tap bit
DTAP1/4-20
17616
1
1/4-20NC drill/tap bit
DISTRIBUTED BY
4426 rev02/04
很抱歉,暂时无法提供与“DTAP10-32”相匹配的价格&库存,您可以联系我们找货
