Tel.: USA & Canada 800-435-0786 • Fax: USA 800-451-2632, Canada 800-524-2853
International Tel.: +1-815-397-7070 • Fax: +1-815-397-9247 • www.greenlee.textron.com
Knockout Punches
R
The contractor’s choice – worldwide.
Unique punch profile splits slugs allowing easy slug removal.
Use with manual, ratchet, hydraulic or battery-powered drivers.
Uses standard Greenlee dies and draw studs.
Available in sizes up thru 2.52" (64.0 mm).
U.S. Patent #4,543,722.
SPECIFICATIONS
Capacity:
Mild steel up through 10 gauge (3.5 mm).
Application: Punch mild steel, aluminum, fiberglass and plastic.
Hole Sizes:
Conduit Sizes – Hole size is outside diameter of US conduit sizes. Example: 1/2" conduit
size punch actually makes a 7/8" hole.
Pg Sizes – European standard pipe sizes.
ISO Sizes – International Standards Organization pipe sizes.
Operation: Operate manually, or with ratchet, hydraulic or battery drivers. When used with
ratchet, hydraulic or battery drivers, buy the punch and die only; the draw stud
is part of the driver kit.
Split slugs fall free from
the die and stud.
Slug is split in half as
punching operation is
completed.
Unique Slug Buster®
punch design creases
slug as the punch is
drawn into the die.
“Custom Size” punches and dies available. See page 56 or contact your Greenlee Distributor.
PUNCH UNIT
REPLACEMENT PARTS
Punch Unit includes:
Punch, Die and Draw Stud Conduit &
Cat. No.
UPC No. Pipe Size
Hole Size
ø inch
Actual
ø mm
Weight
lbs.
g
Replacement Punch
Cat. No. UPC No.
Replacement Die
Cat. No. UPC No.
Replacement
Manual Draw Stud
Cat. No.
UPC No.
Pg
ISO
06727
06727
0.492
12.5
7
12
16
1.5
0.3
137
06728
06728
06729
06729
1675AV
04218
7211EBB-15.2
31989
0.598
15.2
9
14
2.0
0.3
137
31969
31969
32002
32002
00042
00042
35177
35177
7211EBB-18.6
31990
0.638
16.2
16
14
2.0
0.3
137
35163
35163
35162
35162
00042
00042
0.732
18.6
11
14
2.0
0.3
137
31970
31970
32003
32003
00042
00042
7211EBB-20.4
31991
0.803
20.4
13
2.0
0.3
137
31971
31971
32004
32004
00042
00042
7211BB-1/2
31962
1/2"
7/8
0.885
22.5
16
10
3.5
0.3
137
721-1/2
31756
14722
14722
00042
00042
1/2"
7/8
0.885
22.5
16
10
3.5
721-1/2P◊
01980
14722P◊
01992
00042P
06678
35178
35178
1
1.000
25.4
25
14
2.0
0.5
227
35165
35165
35164
35164
249AVBB
04040
7211BB-3/4
31963
3/4"
1.115
28.3
10
3.5
0.8
363
721-3/4
31757
124AV
06972
249AVBB
04040
3/4"
1.115
28.3
10
3.5
721-3/4P◊
01981
124AVP◊
01993
249AVBBP◊
01987
7211EBB-28.3
31993
1.115
28.3
21
14
2.0
0.5
227
31973
31973
32006
32006
00042
00042
60246
60246
1-7/32
1.210
30.5
10
3.5
0.6
273
60237
60237
36278
36278
249AVBB
04040
36508
36508
1-7/32
1.210
30.5
14
2.0
0.6
273
36284
36284
36279
36279
00042
00042
35179
35179
1.280
32.5
32
10
3.5
0.8
363
35169
35169
35168
35168
249AVBB
04040
7211BB-1
31964
1"
1.362
34.6
10
3.5
1
454
721-1◊
31758
126AV
04011
249AVBB
04040
1"
1.362
34.6
10
10
3.5
721-1P◊
01982
126AVP◊
01994
249AVBBP◊
01987
7211EBB-37
31995
1.457
37.0
29
10
3.5
1.2
545
31975
31975
32008
32008
249AVBB
04040
35180
35180
1.595
40.5
40
10
3.5
1.2
545
35158
35158
35159
35159
249AVBB
04040
7211BB-1-1/4
31965
1-1/4"
1.701
43.2
10
3.5
1.3
590
721-1-1/4◊
31759
128AV
04013
249AVBB
04040
1-1/4"
1.701
43.2
10
3.5
721-1-1/4P◊
01983
128AVP◊
01995
249AVBBP◊
01987
7211EBB-47
31996
1.850
47.0
36
10
3.5
1.9
862
31976
31976
32009
32009
304AVBB
04042
7211BB-1-1/2
31966
1-1/2"
1.951
49.6
10
3.5
2.1
953
721-1-1/2
31760
440AV
04061
304AVBB
04042
1-1/2"
1.951
49.6
10
3.5
721-1-1/2P◊
01984
440AVP◊
01996
304AVBBP◊
01988
35181
35181
2
2.000
50.8
50
10
3.5
35160
35160
35161
35161
304AVBB
04042
2.3 1043
36171
36171
2-1/8
2.125
54.0
42
10
3.5
2.5 1134
36172
36172
36173
36173
304AVBB
04042
7211EBB-60
31998
2.362
60.0
48
10
3.5
2.8 1270
31978
31978
32011
32011
304AVBB
04042
7211BB-2
31967
2"
2-3/8
2.416
61.5
10
3.5
3.2 1452
721-2
31761
442AV
04063
304AVBB
04042
2"
2-3/8
2.416
61.5
10
3.5
721-2P◊
01985
442AVP◊
01997
304AVBBP◊
01988
35182
35182
2.520
64.0
63
10
3.5
35167
35167
35166
35166
304AVBB
04042
◊ Individually Packaged in Point of Purchase clamshell for display opportunities
32
Capacity
Mild Steel
GA. mm
3.4 1542
很抱歉,暂时无法提供与“128AV”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+325.764561+42.16683
