DTAP10-24
DTAP10-24
    GREENLEECOMMUNICATIONS(格林利)
DTAP10-24 数据手册
The search is over DRILL TAP DEBURR/COUNTERSINK DTAPKITM DTAP5/16-18 DTAP3/8-16 Finally, one bit that does it all... Ever have to hunt around or figure out which drill bit to use with a certain tap? Tired of using a T-handle to tap the hole? No more, because now you’ve got the Greenlee combination Drill/Tap bit, which drills the proper hole size and taps the hole all in one operation and at an affordable price – saving you time and money. Made from high speed steel to ensure longer life, the Greenlee Combo Drill/Tap Bit is designed to tap up to 10 gauge metal and has a high quality hex shank to ensure a strong connection. The Combination Drill/Tap Bits are now available packaged individually or in kits, in both standard* and metric sizes. In addition, Greenlee now has two larger standard size Drill/Tap Bits, 5/16” and 3/8”, to meet all your needs when it comes to drilling, tapping and deburring. *STANDARD KIT (DTAPKIT) NOT SHOWN PRODUCT FEATURES • Complete hole drilling, tapping and deburring/countersinking in one operation with power drill – saves labor, time and frustration • Back taper beyond tap to prevent thread damage from over-drilling • Deburr/Countersink also provided on bit beyond back taper • Made from high-speed steel vs. carbon steel for longer life • High quality hex shank to ensure strong connection to drill chuck • Designed to tap up to 10 gauge metal • Quick Change Adaptor included in both metric and standard kits SPECIFICATIONS Material thickness - 10g Material type - mild steel, copper, brass, aluminum Shank - 1/4” quick change hex Drill Material - high speed steel Drill point - split point with web thinning ORDERING INFORMATION CAT NO. DTAP10-24 DTAP10-32 DTAP12-24 DTAP6-32 DTAP8-32 DTAPKITM DTAP1/4-20 DTAP3/8-16 DTAP5/16-18 DTAPKIT DTAPM10C DTAPM3C DTAPM4C DTAPM5C DTAPM6C DTAPM8C UPC NO. 17613 17614 17615 17611 17612 12151 17616 11628 11627 17620 12165 12160 12161 12162 12163 12164 DESCRIPTION 10-24NC drill/tap bit 10-32NF drill/tap bit 12-24NC drill/tap bit 6-32NC drill/tap bit 8-32NC drill/tap bit M3-M10, 6 piece drill/tap set 1/4-20NC drill/tap bit 3/8-16NC drill/tap bit 5/16-18NC drill/tap bit 6-32 to 1/4-20, 6 piece drill/tap set M10 X 1.50 drill/tap bit M3 X .50 drill/tap bit M4 X .70 drill/tap bit M5 X .80 drill/tap bit M6 X 1.00 drill/tap bit M8 X 1.25 drill/tap bit QTY 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 FOR BEST RESULTS USE GREENLEE DARK CUTTING/THREADING OIL CAT. NO. 462B UPC NO. 11412 DISTRIBUTED BY: USA: 800-435-0786 815-397-7070 Canada: 800-435-0786 International: +1-815-397-7070 Fax: 800-451-2632 Fax: 815-397-1865 Fax: 800-524-2853 Fax: +1-815-397-9247 4455 Boeing Drive • Rockford, IL 61109-2988 • USA • 815-397-7070 ©2005 Greenlee Textron Inc. • An ISO 9001 Company • Printed in USA Greenlee Textron Inc. is a subsidiary of Textron Inc. www.greenlee.com MA-4426 rev 08/05
DTAP10-24 价格&库存
很抱歉,暂时无法提供与“DTAP10-24”相匹配的价格&库存,您可以联系我们找货
