7238SB
7238SB
    GREENLEECOMMUNICATIONS(格林利)
    PUNCH DIE SET 1/2-2"SLUG BUSTER
7238SB 数据手册
Cat No: 7238SB UPC No: 783310347576 Description • 1 IN Hex Ratchet Wrench allows use with both 3/8 IN (9.5 mm) and 3/4 IN (19.1 mm) draw studs • Includes o 34941 Ratchet wrench- 1 IN Hex o 721-1/2 1/2 IN Conduit Size Punch o 14722 1/2 IN Conduit Size Die o 721-3/4 3/4 IN Conduit Size Punch o 124AV 3/4 IN Conduit Size Die o 721-1 1 IN Conduit Size Punch o 126AV 1 IN Conduit Size Die o 721-1-1/4 1-1/4IN Conduit Size Punch o 128AV 1 1/4IN Conduit Size Die o 721-1-1/2 1-1/2 IN Conduit Size Punch o 440AV 1 1/2IN Conduit Size Die o 721-2 2 IN Conduit Size Punch o 442AV 2IN Conduit Size Die o 00042 Ball Bearing Draw Stud with 1" Hex Head - 3/8IN x 1-5/8IN o 04042 Ball Bearing Draw Stud with 3/4IN x 2-15/16IN o High-impact, rugged plastic carrying case Specifications • Maximum Capacity : 10 GA Mild Steel • Replacement Part : 34941 Ratchet wrench- 1 IN Hex, 721-1/2 1/2 IN Conduit SizePunch, 14722 1/2 IN Conduit Size Die, 721-3/4 3/4 IN Conduit Size Punch, 124AV 3/4 IN Conduit Size Die, 721-1 1 IN Conduit Size Punch, 126AV 1 IN Conduit Size Die, 721-1-1/4 1-1/4IN Conduit Size • Sub Brand : Slug-Buster • Type : Knockout • Weight : 10.000 LB (4.540 KG)
7238SB 价格&库存
很抱歉,暂时无法提供与“7238SB”相匹配的价格&库存,您可以联系我们找货
7238SB
  • 1+4286.953251+557.42198
