229
229
    GREENLEECOMMUNICATIONS(格林利)
    STRAP BATT DUAL SERIES 9V 7"LEAD
229 数据手册
Cat No: 229 UPC No: 783310344360 Description • "Cut-out and mounting slotsare punched in one operation • Drill only one 7/16"" (11.1 mm) pilot hole. (See page 82for Kwik Stepper step bits.) • Fast, accurate panel punching with no sawing or filing required • Universal size punches forfront or back mount of TRW Cinch and ITT Cannon-type or equivalent connectors in 9, 15, 25, 37 or 50-pin configurations • U.S. Patent No. 4,899,447 " Specifications • Capacity : o 16 GA (1.500 MM) Mild Steel o 10 GA (3.500 MM) Aluminum • No. Of Pins : 9 • Operation Type : o Manual With A Wrench o Quick Draw And Quick Draw 90 Hydraulic Drivers, Battery Driver, Ram And Pump HydraulicDrivers Aluminum • Replacement Part : 34441 Punch, 35196 Die Unit, 34421 Draw Stud, 04638 Square Counter Nut, 34733 Drive Nut • Size : 0.787 IN X 0.982 IN X 0.469 IN (20.000 MM X 24.900 MM X 11.900 MM) • Type : Electronic Connector Panel • Weight : 1.400 LB (0.640 KG)
很抱歉,暂时无法提供与“229”相匹配的价格&库存,您可以联系我们找货
