The search is over
DRILL
TAP
DEBURR/COUNTERSINK
DTAPKITM
DTAP5/16-18
DTAP3/8-16
Finally, one bit that does it all...
Ever have to hunt around or figure out which drill bit to use
with a certain tap? Tired of using a T-handle to tap the hole?
No more, because now you’ve got the Greenlee combination
Drill/Tap bit, which drills the proper hole size and taps the hole
all in one operation and at an affordable price – saving you time
and money.
Made from high speed steel to ensure longer life, the Greenlee
Combo Drill/Tap Bit is designed to tap up to 10 gauge metal
and has a high quality hex shank to ensure a strong connection.
The Combination Drill/Tap Bits are now available packaged
individually or in kits, in both standard* and metric sizes. In
addition, Greenlee now has two larger standard size Drill/Tap
Bits, 5/16” and 3/8”, to meet all your needs when it comes to
drilling, tapping and deburring.
*STANDARD KIT (DTAPKIT) NOT SHOWN
PRODUCT FEATURES
• Complete hole drilling, tapping and deburring/countersinking in one operation with power drill –
saves labor, time and frustration
• Back taper beyond tap to prevent thread damage from over-drilling
• Deburr/Countersink also provided on bit beyond back taper
• Made from high-speed steel vs. carbon steel for longer life
• High quality hex shank to ensure strong connection to drill chuck
• Designed to tap up to 10 gauge metal
• Quick Change Adaptor included in both metric and standard kits
SPECIFICATIONS
Material thickness - 10g
Material type - mild steel, copper, brass, aluminum
Shank - 1/4” quick change hex
Drill Material - high speed steel
Drill point - split point with web thinning
ORDERING INFORMATION
CAT NO.
DTAP10-24
DTAP10-32
DTAP12-24
DTAP6-32
DTAP8-32
DTAPKITM
DTAP1/4-20
DTAP3/8-16
DTAP5/16-18
DTAPKIT
DTAPM10C
DTAPM3C
DTAPM4C
DTAPM5C
DTAPM6C
DTAPM8C
UPC NO.
17613
17614
17615
17611
17612
12151
17616
11628
11627
17620
12165
12160
12161
12162
12163
12164
DESCRIPTION
10-24NC drill/tap bit
10-32NF drill/tap bit
12-24NC drill/tap bit
6-32NC drill/tap bit
8-32NC drill/tap bit
M3-M10, 6 piece drill/tap set
1/4-20NC drill/tap bit
3/8-16NC drill/tap bit
5/16-18NC drill/tap bit
6-32 to 1/4-20, 6 piece drill/tap set
M10 X 1.50 drill/tap bit
M3 X .50 drill/tap bit
M4 X .70 drill/tap bit
M5 X .80 drill/tap bit
M6 X 1.00 drill/tap bit
M8 X 1.25 drill/tap bit
QTY
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
FOR BEST RESULTS USE GREENLEE
DARK CUTTING/THREADING OIL
CAT. NO.
462B
UPC NO.
11412
DISTRIBUTED BY:
USA:
800-435-0786
815-397-7070
Canada:
800-435-0786
International: +1-815-397-7070
Fax:
800-451-2632
Fax:
815-397-1865
Fax:
800-524-2853
Fax: +1-815-397-9247
4455 Boeing Drive • Rockford, IL 61109-2988 • USA • 815-397-7070
©2005 Greenlee Textron Inc. • An ISO 9001 Company • Printed in USA
Greenlee Textron Inc. is a subsidiary of Textron Inc.
www.greenlee.com
MA-4426 rev 08/05
很抱歉,暂时无法提供与“DTAP8-32”相匹配的价格&库存,您可以联系我们找货
