46602
46602
    GREENLEECOMMUNICATIONS(格林利)
    PRO COAX TOOL KIT-SHORT
46602 数据手册
WWW.GREENLEECOMMUNICATIONS.COM PROFESSIONAL COAX CABLE TOOL KIT 46602 AND 46603 46602 – Short style RG59/6 “F” Connectors 46603 – Long style RG59/6 “F” Connectors 46602 Two kits for reproducing the exact same high quality connection every time Each of these two kits have been designed to cut, strip, terminate and tighten coax connectors based on highly engineered specifications. Each kit contains: • 0251-08D 8” diagonal cutting pliers • 45592 stripping tool with depth stop, allowing you to easily replicate exact cutbacks and a Velcro pad to pull back insulators without risk of injury • 0153-42C 6-in-1 multi tool • FL2AAAP LED pen light • 0354-1430T 7/16” torque wrench engineered to tighten connectors up to 30 in-lb • PA5001 Grip pack with quick release belt clip • Kits are available for shorter (PA7602) or longer (PA7603) style “F” connectors USA PHONE 800.642.2155 FAX 760.598.5634 CANADA PHONE 866.384.8813 FAX 800.524.2853 INT’L PHONE +1.815.397.7070 FAX +1.815.397.9247 KIT INCLUDES: CAT NO. DESCRIPTION QTY. 0251-08D 8" Diagonal Cutting Pliers • Cuts most hardened wire, ACSR, bolts, screws, and nails • Laser-hardened edges and chrome-vanadium steel construction for strength and durability • Exceeds ASME/ANSI specifications • Limited lifetime warranty 1 45592 RG 59/6/6Q – 7/11 Coaxial Cable Stripper • Works with a variety of coaxial cables (RG59/6/6Q/7/11) • Depth stop to repeat exact strip every time • Velcro pad to pull back insulating strands and save your fingers • Lightweight, single-handed operation with spring loaded handles 1 PA7602 Fixed compression tool (short) PA7602 is designed for use on the shorter style F connectors (Such as PPC® Aquatight Connector EX or shorter connectors and other similar length connectors) 1 PA7603 Fixed Compression tool (long) PA7603 is designed for use on the longer style F connectors (such as PPC ® EXXLWS Aquatight connector EX-XL and other similar length connectors) 1 0153-42C 6-in-1 Multi-Tool • Quickly and easily drives nuts and screws • Sizes: Hex Nut: 1/4" and 5/16" Phillips Screw: #1 and #2 Flat Screw: 3/16" and 1/4" • Limited lifetime warranty 1 FL2AAAP LED Penlight • Sealed against water and dust • 50,000 Hours, 7 Lumen • 14-15 hours battery life, AAA batteries 1 0354-1430T 7/16” Torque wrench designed to tighten coax “F” Connectors to 30 in-lb. • 7/16” Hex head torque wrench • Creates an audible click when 30 in-lb torque is reached • TPR Handle provides a tacky grip and comfortable use 1 PA5001 Custom Grip Pack Pouch with Quick Release Belt Clip • Custom-molded PVC pouch securely holds tools • Quick-release belt clip for fast operation • Swivel allows pouch to move for added comfort 1 ORDERING INFORMATION CAT NO. UPC NO. DESCRIPTION 46602 03620 PROFESSIONAL COAX TOOL KIT (SHORT) 1 46603 03619 PROFESSIONAL COAX TOOL KIT (LONG) 1 www.greenleecommunications.com QTY. MA5839 rev 05/15 1390 Aspen Way • Vista, CA 92081 • USA • 760-598-8900 ©2015 Greenlee Textron Inc. • Greenlee Textron Inc. is a subsidiary of Textron Inc.
46602 价格&库存
很抱歉,暂时无法提供与“46602”相匹配的价格&库存,您可以联系我们找货
