TESTER,GAS LAMP (5715)
Gas Lamp Tester
Cat No:
50345290
UPC No:
783310345299
Description
Test most fluorescent lamps, low pressure sodium vapor, high pressure sodium discharge lamps,
neon tubes, mercury vapor and metal halide lamps
Checks starters, resistors, ignitors, capacitors and photo cells
Indicates AC/DC voltage and continuity
Includes detachable antenna, batteries, leads, probes, clamps and holster
Lifetime Limited Warranty
Specifications
Antenna Length : 27.000 IN (686.000 MM)
Application : Test Most Fluorescent Lamps, Low Pressure Sodium Vapor, High Pressure Sodium
Discharge Lamps, Neon Tubes, Mercury Vapor And Metal Halide Lamps,ChecksStarters,
Resistors, Ignitors, Capacitors And Photo Cells
Battery : 2 - 9 V, Included
Capacity :
ƕ Voltage - Up To 500 VAC And VDC
ƕ Continuity - To 300 KOHM
Includes : Antenna, Batteries, Leads, Probes, Clamps And Holster
Replacement Part : 5713 Holster, 35450 Battery Door, 5710 Antenna, 5786 Small Alligator
Clamps (2), 5783 Push-on Probes (2)
Size : 6.000 IN (152.000 MM) x 2-3/4IN (70.000 MM) x 1-3/4 IN (45.000 MM)
Type : Gas Lamp
Weight : 2.400 LB (1.100 KG)
很抱歉,暂时无法提供与“5715”相匹配的价格&库存,您可以联系我们找货
