DTAP6-32
DTAP6-32
    GREENLEECOMMUNICATIONS(格林利)
DTAP6-32 数据手册
The search is over TAP DRILL DEBURR/COUNTERSINK Finally, one bit that does it all... Ever have to hunt around or figure out which drill bit to use with a certain tap? Tired of using a T-handle to tap the hole? No more, because now you've got the Greenlee combination Drill/Tap bit, which drills the proper hole size and taps the hole in one operation! Made from high speed steel to ensure longer life, the Greenlee Combo Drill/Tap Bit is designed to tap up to 10 gauge metal and has a high quality hex shank to ensure a strong connection. • Complete hole drilling and tapping in one operation with power drill saves labor and time • Back taper beyond tap to prevent thread damage from over-drilling • Deburr/Countersink also provided on bit beyond back taper • Made from high-speed steel vs. carbon steel for longer life • High quality hex shank to ensure strong connection to drill chuck • Designed to tap up to 10 gauge metal Material thickness - 10g Material type - mild steel, copper, brass, aluminum Shank - 1/4” quick change hex Drill Material - high speed steel Drill point - split point with web thinning CAT. NO. UPC NO. QTY. DESCRIPTION DTAPKIT 17620 6 6-32 to 1/4-20 6 piece drill/tap set DTAP6-32 17611 1 6-32NC drill/tap bit DTAP8-32 17612 1 8-32NC drill/tap bit DTAP10-24 17613 1 10-24NC drill/tap bit DTAP10-32 17614 1 10-32NF drill/tap bit DTAP12-24 17615 1 12-24NC drill/tap bit DTAP1/4-20 17616 1 1/4-20NC drill/tap bit DISTRIBUTED BY 4426 rev02/04
DTAP6-32 价格&库存
很抱歉,暂时无法提供与“DTAP6-32”相匹配的价格&库存,您可以联系我们找货
