Ersa i-CON VARIO 2 & i-CON VARIO 4
Multichannel soldering and
desoldering station
Meets the highest standards in
professional soldering and desoldering
equipment
desoldering station
i-CON VARIO 4
The i-CON VARIO 4 multichannel soldering and desoldering station meets even
the most stringent demands placed on
equipment. This flagship of the i-CON
family offers the user four soldering
tools for demanding soldering tasks,
simultaneously: Flexible soldering and
desoldering is provided for by the new,
ergonomically designed soldering and
desoldering hot air iron i-TOOL AIR S
(200 W) with non-contact energy
transfer, highly efficient soldering is
offered with the i-TOOL, delivering a
powerful 150 W, precise desoldering of
the smallest SMD components is
achieved with the new desoldering
tweezers CHIP TOOL VARIO (80 W), and
desoldering of leaded components is
performed with the new X-TOOL VARIO
(150 W). Naturally, attaching other Ersa
soldering tools to the stations is possible.
All functions, including the generation
of the air and the vacuum required in
the process, are bundled in the supply
unit, which is equipped with the easily
to operate i-Op facility and its clearly
arranged displays. In addition, the station makes available interfaces for the
Ersa solder fume extractor unit or the
infrared preheating unit, as well as featuring an USB port. With a microSD
memory card, the station can be
quickly and safely configured, so that it
is optimally prepared for all applications in professional electronic manufacturing. The station is well suited for
the use in ESD protected zones.
i-CON VARIO 2
The i-CON VARIO 2 multichannel soldering and desoldering station offers
to the professional user two simultaneously usable soldering tools. In parallel
to the new, ergonomically designed hot
air soldering unit i-TOOL AIR S (200 W)
is it possible to operate another soldering tool such as the 150 W i-Tool,
the ideal tool for classical soldering applications, or the new developed desoldering tweezers CHIP TOOL VARIO (80
W). instead of the i-TOOL AIR S the
high power soldering iron i-TOOL HP
provides 250 W soldering performance
an all VARIO stations. The soldering
station without pumps (0ICV2000HP)
addresses all users looking for i-TOOL
HP and i-TOOL operation.
The compact, ESD static safe supply
unit offers the easy and clearly arranged display, which is in the i-CON
family of tools a standard feature. As
in the larger i-CON VARIO 4, interfaces
for the Ersa solder fume extractor unit
or the infrared preheating unit are
available, also the method to quickly
and safely configure the station with a
microSD memory card.
equipment
further information
on i-CON 4
further information
on i-CON 2
i-TOOL-AIR S
Handy in size, convincing in power! The
i-TOOL AIR S provides 200 W convection energy and ease of operation on
multiple SMT applications.
The hot air volume (2 to 20 l/min) is
set directly on the hand piece and
shown in the display of an i-CON
VARIO 2 or 4 soldering station. To remove smallest chip components the
operator can dose air volume precisely. Variable nozzles guarantee the
best energy transmission to the solder joint. A built in motion sensor activates the i-TOOL AIR S, an IR-Sensor
in the hand piece switches the tool on
and off.
CHIP TOOL VARIO
The desoldering tweezers CHIP TOOL
VARIO is characterized by its compact
design and 2 x 40 W soldering power.
It is perfectly suited for soldering ap-
plications with smallest SMT components.
The plug-in pairs of soldering tips are
precisely adjustable and easy to exchange.
A switching element changes the
tools operation from self-closing to
self-opening mode. It’s built in motion
sensor activates the CHIP TOOL VARIO
from standby.
i-TOOL
The i-TOOL is an extremely lightweight
but powerful soldering iron, accompanied by a wide range of beneficial Ersa
long life soldering tips. 150 W heating
power guarantee fastest heat up times
and heat recovery. Process-window
alarms, three energy levels and
standby-sensor grant all i-CON-users
an unrivalled process control in hand
soldering.
X-TOOL VARIO
The PTH desoldering tool X-TOOL
VARIO convinces by its highly efficient
150 W heating technology. The integrated design of heating element and
desoldering tip provides a highly efficient heat transmission into the solder joint. Effective solder removal is
possible within shortest time. The
slim line geometry of heating head
and desoldering tip allow striking operation even on densely populated
boards.
i-TOOL HP
Highest performance for heavy mass
soldering applications! The i-TOOL HP
supplies 250 W heating power, exchangeable heating elements and independently exchangeable soldering
tips. All VARIO control units can operate this powerful tool. For singular
operation of the i-TOOL HP Ersa recommends the Version i-CON VARIO
2HP (0ICV2000HP).
Technical informations & configuration options
Electronic stations
Order no.
Description
Rating/voltage
Vakuum
Air flow
Temperature range
OICV403A
i-CON VARIO 4
electronic station
max. 500 W/
230 V, 50 Hz
max. 700 mbar
2 – 20 l/min
150 – 450 °C
(50 – 550 °C – i-TOOL AIR S)
OICV203A
i-CON VARIO 2
electronic station
max. 200 W/
230 V, 50 Hz
2 – 20 l/min
150 – 450 °C
OICV203AP
i-CON VARIO 2
electronic station
max. 200 W/
230 V, 50 Hz
2 – 20 l/min
150 – 450 °C
OICV203HP
i-CON VARIO 2
electronic station
max. 200 W/
230 V, 50 Hz
max. 700 mbar
150 – 450 °C
Soldering and desoldering tools
Order no.
Description
Rating/voltage
Weight (w/o cable)
0470BRJ
i-TOOL AIR S
hot air iron
200 W
approx. 90 g
0100CDJ
i-TOOL
soldering iron
150 W
approx. 30 g
0460MDJ
CHIP TOOL VARIO
2 x 40 W
approx. 75 g
0720EDJ
X-TOOL
desoldering iron
2 x 60 W
approx. 240 g
0740ED
X-TOOL VARIO
desoldering iron
150 W
approx. 210 g
0240CDJ
i-TOOL HP
250 W
approx. 110 g
Soldering and desoldering stations
Order no./contents
i-TOOL AIR S
i-TOOL
CHIP TOOL VARIO
X-TOOL
X-TOOL VARIO
i-TOOL HP
0ICV2000A
0ICV2000AI
0ICV2000AC
0ICV2000AX
0ICV2000AXV
0ICV2000HP
0ICV4000A
0ICV4000AI
0ICV4000AIC
0IC4000AICXV
Ersa GmbH
Leonhard-Karl-Str. 24
97877 Wertheim/Germany
Phone. +49 9342 800-0
Fax +49 9342 800-127
info@ersa.de
www.ersa.com
America
China
Ersa North America
Phone +1 920 893 3772
from the US: 1 800 363 3772
Fax +1 920 893 3322
info-ena@kurtzersa.com
Ersa Shanghai
Phone +86 213126 0818
Fax +86 215239 2001
info-eap@kurtzersa.com
297 833 - 11/2015 | subject to change | © Ersa GmbH
0ICV4000AICX
很抱歉,暂时无法提供与“0ICV4000AICXV”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+26018.070901+3361.33190
