0IC1100A0C
0IC1100A0C
    KURTZERSA
0IC1100A0C 数据手册
Ersa i-CON 1 Only if it is an i-CON, it is an i-CON! Large variety of soldering applications i-CON 1 with i-TOOL Ersa´s professional soldering station for the electronic industry: i-CON 1 The workhorse of electronic production shows reliable and robust technology along with perfect ergonomic design and intuitive one touch operation. All parameters can easily be set and monitored on a multi-language clear text display. Technical highlights: One channel soldering station Digital temperature control with intelligent power management 150 W iron with motion sensor Intuitive One-Touch operation with multi-functional display Optional with interface to control heating plate and fume extraction unit 150 W iron with precise temperature control The unique, light weight 150 W i-TOOL soldering iron provides best soldering results with a wide range of ERSADUR soldering tips ranging from 0.2 to 20 mm size. It´s precise SENSOTRONIC temperature control convinces customers all over the world. Heating element and soldering tip are separately exchangeable. Current features like stand-by, shut-down and process window indication are naturally implemented. The i-CON 1 version with interface allows connectivity for Ersa IR-heating plates, fume extraction units or robot and IoT applications. i-CON 1 with i-TOOL and holder Ersa i-CON 1 Only if it is an i-CON, it is an i-CON! Technical data i-CON 1: Technical data i-TOOL: dimensions (W x D x H) 150 x 175 x 105 mm weight 30 g (without cable) weight 3,0 kg design antistatic voltage 230 V AC, 50 Hz voltage 24 V AC nominal power 80 W nominal power 150 W design antistatic heat up time 9 sec temperature range 150 – 450 °C temperature range 150 – 450 °C further information on Ersa i-CON 1 applicable soldering tool: further information on soldering tips Ersa i- TOOL Order information: Order No. Description 0IC1100A i-CON 1 with i-TOOL 0IC1100A0C i-CON 1 with i-TOOL and interface Ersa explains Soldering Tip Care Soldering tips (ERSADUR) – selection ,5 30  0,8 lead-free, 0,2 mm, pencil point 5,2 0102PDLF02 ‘ Description Ø   Order No. 2 ‘  0102CDLF20 lead-free, 2,0 mm, chisel-shaped 0102CDLF20 28 0102CDLF50 lead-free, 5,0 mm, chisel-shaped 0102SDLF06 lead-free, 0,6 mm, bent 0102SDLF18 lead-free, 1,8 mm, bent 0102ADLF20 lead-free, 2,0 mm, angled face 0102ADLF40 lead-free, 4,0 mm, angled face 0,8 5,2 5,2 lead-free, 0,4 mm, pencil point Ø Ø 0102PDLF04 Description 9,5  3'/) 30 Order No. Ø 0,4 5 9 3,8 0102PDLF08L     lead-free, 0,8 mm, pencil point ‘ ‘ 0102PDLF04   ‘  ‘      ƒ Ø 0102CDLF04 6'/)    0,2 4,5  Ø lead-free, 0,4 mm, chisel-shaped  5,2 ,2 26 ‘ 3'/)/ 9 0,4   ƒ 23      lead-free, 1,2 mm, chisel-shaped   0102CDLF16 $'/) lead-freei,1,6 mm, chisel-shaped      &'/)  ‘   ‘ &'/)   ‘    0102CDLF12 ‘     $'/) 08/2017 | subject to change | © Ersa GmbH Ersa GmbH Leonhard-Karl-Str. 24 97877 Wertheim Germany Tel. +49 9342 800-0 Fax +49 9342 800-127 info@ersa.de www.ersa.com Frankreich info-efr@kurtzersa.com Amerika info-ena@kurtzersa.com Mexiko info-kmx@kurtzersa.com Visit www.ersa.com for further information! China info-eap@kurtzersa.com
0IC1100A0C 价格&库存
很抱歉,暂时无法提供与“0IC1100A0C”相匹配的价格&库存,您可以联系我们找货
