ANALOG 60
ANALOG 60
    KURTZERSA
    ERSA - ANALOG 60 - SOLDERING STATION, 60W, 230V, EU/UK
ANALOG 60 数据手册
ERSA ANALOG 60 Basic tool 60 190 Watt heat up rating 832 UD 832 SD 832 BD 832 CD 832 KD 832 ED 832 VD 832 HD 832 PW ERSADUR tip design see p. 9 Please ask for our tip sheet with additional tips! 8 The Standard - proven technology for all-round use The electronically temperaturecontrolled ERSA ANALOG 60 soldering station is the standard model in ERSA’s new series of soldering stations. The precise ERSA RESISTRONIC control system exploits the positive effect of the PTC (Positive Temperature Coefficient) heating element. The high heat up rating of 190 W ensures an immediate supply of heat. The station’s sensitive electronics control the working temperature by measuring the resistance of the ceramic heating element. Temperature can be adjusted at the soldering station on a continuous scale between 150°C (300°F) and 450°C (840°F). The easy-to-handle ERSA Basic tool 60 soldering iron heats up from room temperature to 280°C (545°F) in only 60 seconds. Its ergonomic design earned the IF design award at the Hanover trade fair. All the controls are at the front of the station, and the front panel is set at the perfect angle for the user’s line of vision. A potential equalization jack with a high-resistance connection to the soldering tip ensures the safety of sensitive components. The large selection of long-lasting, Conventional soldering with Basic tool 60 internally heated ERSADUR soldering tips make this versatile soldering station suitable for most industrial soldering applications. The multifunctional holder with its swiveling sponge container also functions as a hot tip holder. In addition, the holder is designed so that you can use ERSA soldering irons with virtually any commercially available solder fume extraction system provided you have an adapter. Technical data: Order nos.: ANA 60 ANALOG 60 soldering station complete consisting of: ANA 603 Electronic station 670 CDJ Basic tool 60 soldering iron with 832 CD soldering tip A 28 Tool holder Spare parts: 67100J Spare heating element for Basic tool 60 Basic tool 60 soldering iron Voltage: 24 V~ Rating: 75 W / 280°C (545°F) - 60 W / 350°C (660°F) Heat up rating: 190 W Heating time: appr. 60 s to 280°C / 545°F) Weight (without cable): appr. 60 g (2.4 oz) Cable: 1.5 m (4.9 ft) highly flexible / heat resistant ANA 603 electronic station Supply voltage: 230 V~, 50-60 Hz Secondary voltage: 24 V~ Rating: 60 W Control technique: RESISTRONIC Temperature range: stepless 150°C (300°F) - 450°C (840°F) Function display: red LED Cable: 2 m (6.6 ft) PVC with connector Model: antistatic
ANALOG 60 价格&库存
很抱歉,暂时无法提供与“ANALOG 60”相匹配的价格&库存,您可以联系我们找货
