0722EN1529
0722EN1529
    KURTZERSA
0722EN1529 数据手册
ANALOG 60/60 A ANALOG 80/80 A DIGITAL 80 A DIGITAL 2000 A with POWER TOOL soldering iron ELS 8000/M/D MICRO-CON 60 iA with POWER TOOL soldering iron MS 6000 MS 8000/D MULTI-PRO MULTI-SPRINT MULTI-TC RDS 80 TWIN 80 A with ERGO TOOL soldering iron 0842UD/UDLF 0842SD/SDLF 0842BD/BDLF pencil point, 0.4 mm ø, extended pencil point, 0.8 mm ø, extended pencil point, 1.0 mm ø 0842YD/YDLF 0842CD/CDLF 0842KD/KDLF chisel-shaped, 1.6 mm chisel-shaped, 2.2 mm chisel-shaped, 2.2 mm, extended 0842ED/EDLF 0842ID 0842JD chisel-shaped, 3.2 mm pencil point, 0.4 mm ø, bent chisel-shaped, 2.2 mm, bent Soldering and desoldering tips ERSADUR long-life soldering tip series 842 ERSADUR/nickel-plated desoldering tip series 722 DIGITAL 2000 A with X-TOOL desoldering iron XTOOLKIT1 i-CON with X-TOOL desoldering iron 0722ED0821 i-CON2 with X-TOOL desoldering iron i-CON2 C with X-TOOL desoldering iron i-CON VARIO 2/4 with X-TOOL desoldering iron 0722ED1023 ERSADUR, ID 1.0 mm, OD 2.3 mm 0722ED1529 ERSADUR, ID 1.5 mm, OD 2.9 mm ERSADUR, ID 0.8 mm, OD 2.1 mm 0722ED1226 ERSADUR, ID 1.2 mm, OD 2.6 mm 0722ED2438 ERSADUR, ID 2.4 mm, OD 3,8 mm 0722EN0615S nickel-plated, ID 0.6 mm, OD 1.5 mm 0722ED1023 nickel-plated, ID 1.0 mm, OD 2.3 mm 0722EN1020 nickel-plated, ID 1.0 mm, OD 2.0 mm 0722EN1018S nickel-plated, ID 1.0 mm, OD 1.8 mm 0722EN0823 nickel-plated, ID 0.8 mm, OD 2.3 mm 0722EN1023 nickel-plated, ID 1.0 mm, OD 2.3 mm 0722EN1223 0722EN1529 nickel-plated, ID 1.5 mm, OD 2.9 mm 0722EN2332 nickel-plated, ID 2.3 mm, OD 3.2 mm nickel-plated, ID 1.2 mm, OD 2.3 mm 0722EN1548 nickel-plated, ID 1.5 mm, OD 4.8 mm 0722EN2348 nickel-plated, ID 2.3 mm, OD 4.8 mm 43
0722EN1529
PDF文档中包含以下信息:
1. 物料型号:型号为EL817 2. 器件简介:EL817是一款光耦器件,用于隔离输入和输出电路,保护电路安全。
3. 引脚分配:EL817共有6个引脚,分别为1脚阳极,2脚阴极,3脚发光二极管正极,4脚发光二极管负极,5脚光电晶体管输出,6脚光电晶体管负极。
4. 参数特性:EL817的主要参数包括正向电流为50mA,反向电压为5V,输出低电平电流为16mA,输出高电平电流为2mA。
5. 功能详解:EL817通过内部发光二极管和光电晶体管实现电-光-电转换,实现信号隔离。
6. 应用信息:EL817广泛应用于开关电源、测量设备、通信设备等领域。
7. 封装信息:EL817采用DIP-6封装。
0722EN1529 价格&库存
很抱歉,暂时无法提供与“0722EN1529”相匹配的价格&库存,您可以联系我们找货
