0G132CN
0G132CN
    KURTZERSA
0G132CN 数据手册
DATA Independent 130 Maximum independence with the multifunctional ERSA gas soldering sets 25–130 ^ = Watt ERSA-product range Soldering tools • NEW DIMENSION • PROFI-LINE • IR-Rework • CLEAN-AIR Soldering systems Wave soldering • • • • Fig.: Independent 130 Profi Set Off the line gas soldering power, infinitely variable up to 130 W. Comfortable piezo ignition. Operation with lighter gas. The „larger edition“ of ERSA gas soldering irons, soldering tip, a spare tip and a sponge container the Independent 130, is most suitable in situati- with cleaning sponge. ons where sophisticated soldering solutions are The Independent 130 „Profi Set“ includes, in required off the line. Due to a large power spec- addition to the „Basic Set“, another 2 soldering trum which is infinitely variable from 25 - 130 watts tips, a hot blade to shape and cut high-resistance (compared with electrical soldering irons) and a foam, a hot gas nozzle and a deflector to shrink large selection of soldering tips, the Independent 130 different sizes of heat-shrinkable sleeves and offers many applications in the servicing, installation, to solder SMD components as well as a flame repair and maintenance field. nozzle to micro weld. The integrated piezo ignition together with the fact that the iron operates on commercially available butane gas ensures easy handling and high reliability. One filling is sufficient for an operating time of approx. 120 min, the max. soldering tip temperature is approx. 580°C. The Independent 130 „Basic Set“ consists of a gas soldering iron with pre-installed catalytic ETS-line EWS-line N-Wave-line Solution Reflow soldering • • • • • • Hotflow 3 Hotflow 5 Hotflow 7 Hotflow 9 Hotflow 11 ERS 250 Selective soldering • • • • • EAS-line Multiflow Versaflow Versaflow Compact Versaflow High Speed • Place & Solder Inspection systems • ERSASCOPE • ImageDoc Software Other services • • • • Know-how seminars In-House trainings Test soldering Installation and maintenance assistance • Process support Independent 130 DATA Maximum independence with the multifunctional ERSA gas soldering sets Technical data: Rating: 25 - 130 W Heating time: 183°C in approx. 30 sec. Sold. tip temp.: approx. 580°C max. Weight: 121 g Ignition: piezo ignition, operates on butane gas Order nos.: 0G13400141 consisting of: 0G130KN 0G132CN 0G132AN 0G132VN 0G132BE 0G132HE 0G132MN 0G132RE 0006 0G156 original size 5PE0701-IN130 • subject to changes • © by ERSA Order nos.: 0G13400041 consisting of: 0G130KN 0G132CN 0006 0G156 Gas soldering set Indpendent 130 „Profi Set“ Gas soldering iron Independent 130 with chisel-shaped soldering tip 0G132KN, 2.4 mm Chisel-shaped sold. tip, 1.0 mm Chisel-shaped sold. tip, 3.2 mm Chisel-shaped sold. tip, 4.8 mm Flame nozzle Hot gas nozzle Hot blade Deflector to shrink heatshrinkable sleeves Cleaning sponge Sponge container Gas soldering set Indpendent 130 „Basic Set“ Gas soldering iron Independent 130 with chisel-shaped soldering tip 0G132KN, 2.4 mm Chisel-shaped soldering tip, 1.0 mm Cleaning sponge Sponge container Accessories: 0G 806 K Gas cartridge, 65 ml ERSA GmbH Otto-Schott-Straße 3-7 P.O.Box 1261 97862 Wertheim/Germany Tel: +49(0)9342/800-0 Fax:+49(0)9342/800-250 e-mail: info@ersa.de http://www.ersa.de
0G132CN 价格&库存
很抱歉,暂时无法提供与“0G132CN”相匹配的价格&库存,您可以联系我们找货
