0IC2200VXT
0IC2200VXT
    KURTZERSA
    ERSA - 0IC2200VXT - SOLDERING STATION, 230VAC, 150W
0IC2200VXT 数据手册
Ersa i-CON 1V & i-CON 2V Only if it is an i-CON, it is an i-CON! i-CON 1V with X-TOOL VARIO and vacuum untit Ersa soldering and desoldering stations for the industry: i-CON 1V and i-CON 2V! Ersa has re-engineered it´s well known and worldwide proven i-CON soldering stations and enhanced their functions. The i-CON 1V as well as the i-CON 2V now comprise the control electronics, already implemented in the i-CON VARIO multi-channel soldering and desoldering stations. For operators multiple new features show up: memory card technology. It allows to update the soldering station´s software. Future soldering tools and additional functions can be used with the existing hardware. Ersa underlines with these soldering stations technological leadership for its customers benefit. Only if it is an i-CON, it is an i-CON! One or two channel soldering and desoldering station Digital temperature control with intelligent power management Operation of eight different soldering tools Intuitive One-Touch operation with multi-funktional display Integrated micro-SD card slot for updates The i-CON 1V and i-CON 2V can now operate the new soldering and desoldering tools CHIP TOOL VARIO and X-TOOL VARIO. The compact vacuum untit supplies vacuum for the X-TOOL VARIO or existing X-TOOLs. Optional with interface to control heating plate and fume extraction unit In addition, present Ersa soldering tools like the 80 W POWER TOOL can be connected to these stations. The change over from existing Ersa stations to the new i-CONs becomes even more attractive. Totally, the i-CON 1 V and 2V control units are able to drive eight different Ersa soldering tools. Moreover, this new control electronics is a next generation technology: Besides the intelligent power management they provide the micro-SD Technical highlights: i-CON 2V with two i-TOOLs Ersa i-CON 1V & i-CON 2V Only if it is an i-CON, it is an i-CON! applicable soldering and desoldering tools: Technical data: dimensions (W x D x H) 150 x 175 x 105 mm weight 3,0 kg i-CON 1 V / 3,7 kg i-CON 2V voltage 230 V AC, 50 Hz nominal power 80 W i-CON 1 V / 120 W i-CON 2V design antistatic temperature range 50 – 450 °C 0100CDJ Order information: 0460MDJ Order No. Description 0IC1100V i-CON 1V with i-TOOL 0IC1100VCV i-CON 1V with CHIP TOOL VARIO 0IC1100VXV i-CON 1V with X-TOOL VARIO 0IC1100V0C i-CON 1V with i-TOOl and interface 0IC2200V i-CON 2V with i-TOOL 0IC2200VC i-CON 2V with i-TOOL and CHIP TOOL VARIO 0IC2200VIT i-CON 2V with two i-TOOLs 0IC2200VXT i-CON 2V with i-TOOL, X-TOOL VARIO and vacuum untit 0IC2200V0C i-CON 2V with i-TOOL and interface Accessoires 0CA10-001 Easy Arm 1 filter unit for one extraction arm 0CA10-002 Easy Arm 2 filter unit for 2 extraction arms 3CA10-2003 interface cable for EA 1 and EA 2 0IRHP100A-03 heating plate 230V, 800 W 0IRHP100A-12 control cable for heating plate i- TOOL CHIP TOOL VARIO 0740EDJ X-TOOL VARIO 0270BDJ MICRO TOOL 0640ADJ TECH TOOL 0840CDJ POWER TOOL further information on our website or webshop 0450MDJ i-CON 2V with i-TOOL and CHIP TOOL VARIO 0720EDJ CHIP TOOL X-TOOL 297 624 - 11/2015 | subject to change | © Ersa GmbH Ersa GmbH Leonhard-Karl-Str. 24 97877 Wertheim Germany Tel. +49 9342 800-0 Fax +49 9342 800-127 info@ersa.de www.ersa.com France info-efr@kurtzersa.com America info-ena@kurtzersa.com Mexico info-kmx@kurtzersa.com Visit www.ersa.com for further information! China info-eap@kurtzersa.com
0IC2200VXT 价格&库存
很抱歉,暂时无法提供与“0IC2200VXT”相匹配的价格&库存,您可以联系我们找货
