842 JD
842 JD
    KURTZERSA
    ERSA - 842 JD - Soldering Iron Tip, Bent, 2.2 mm
842 JD 数据手册
Your Guide 842 ERSADUR Long-Life Soldering Tip Series 0842UD / UDLF 0842SD / SDLF 0842BD / BDLF For: • ANALOG 60 / 60 A • ANALOG 80 / 80 A • DIGITAL 80 A • DIGITAL 2000 A with Power tool soldering iron • ELS 8000 / M / D pencil point, extenced, 0.4 mm ø pencil point, extenced, 0.8 mm ø pencil point, 1.0 mm ø 0842YD / YDLF 0842CD / CDLF 0842KD / KDLF • MICRO-CON 60 iA with Power tool soldering iron • MS 6000 • MS 8000 / D • Multi-Pro • Multi-Sprint • Multi-TC • RDS 80 chisel-shaped, 1.6 mm chisel-shaped, 2.2 mm chisel-shaped, extended, 2.2 mm 0842ED / EDLF 0842ID 0842JD chisel-shaped, 3.2 mm pencil point, bent, 0.4 mm ø chisel-shaped, bent, 2.2 mm 722 Desoldering Tip Series, ERSADUR / nickel-plated 0722ED1023 0722EN0615S 0722EN1018S • TWIN 80 A with Ergo tool soldering iron For: • DIGITAL 2000 A with X-Tool desoldering iron • XTOOLKIT1 ERSADUR, ID 1.0 mm, OD 2.3 mm nickel-plated, ID 0.6 mm , OD 1.5 mm nickel-plated, ID 1.0 mm , OD 1.8 mm 0722ED0821 0722EN0818 0722EN1020 0722ED1529 0722EN0823 0722EN1023 0722EN1223 0722EN1529 0722EN2332 0722ED1226 0722EN1548 0722EN2348 ERSADUR, ID 0.8 mm, OD 2.1 mm ERSADUR, ID 1.5 mm, OD 2.9 mm nickel-plated, ID 1.2 mm, OD 2.3 mm ERSADUR, ID 1.2 mm, OD 2.6 mm nickel-plated, ID 0.8 mm, OD 1.8 mm nickel-plated, ID 0.8 mm, OD 2.3 mm nickel-plated, ID 1.5 mm, OD 2.9 mm nickel-plated, ID 1.5 mm, OD 4.8 mm nickel-plated, ID 1.0 mm, OD 2.0 mm nickel-plated, ID 1.0 mm,OD 2.3 mm nickel-plated, ID 2.3 mm, OD 3.2 mm nickel-plated, ID 2.3 mm, OD 4.8 mm 39
842 JD 价格&库存
很抱歉,暂时无法提供与“842 JD”相匹配的价格&库存,您可以联系我们找货
