Ersa i-CON 1V & i-CON 2V
Only if it is an i-CON, it is an i-CON!
i-CON 1V with X-TOOL VARIO and vacuum untit
Ersa soldering and desoldering stations for the industry: i-CON 1V and i-CON 2V!
Ersa has re-engineered it´s well known and
worldwide proven i-CON soldering stations and
enhanced their functions. The i-CON 1V as well
as the i-CON 2V now comprise the control electronics, already implemented in the i-CON VARIO
multi-channel soldering and desoldering stations. For operators multiple new features show
up:
memory card technology. It allows to update the
soldering station´s software. Future soldering
tools and additional functions can be used with
the existing hardware.
Ersa underlines with these soldering stations
technological leadership for its customers benefit. Only if it is an i-CON, it is an i-CON!
One or two channel soldering and desoldering
station
Digital temperature control with intelligent
power management
Operation of eight different soldering tools
Intuitive One-Touch operation with multi-funktional display
Integrated micro-SD card slot for updates
The i-CON 1V and i-CON 2V can now operate the
new soldering and desoldering tools CHIP TOOL
VARIO and X-TOOL VARIO. The compact vacuum
untit supplies vacuum for the X-TOOL VARIO or
existing X-TOOLs.
Optional with interface to control heating
plate and fume extraction unit
In addition, present Ersa soldering tools like the
80 W POWER TOOL can be connected to these
stations. The change over from existing Ersa stations to the new i-CONs becomes even more attractive. Totally, the i-CON 1 V and 2V control
units are able to drive eight different Ersa soldering tools.
Moreover, this new control electronics is a next
generation technology: Besides the intelligent
power management they provide the micro-SD
Technical highlights:
i-CON 2V with two i-TOOLs
applicable soldering and desoldering
tools:
Technical data:
dimensions (W x D x H)
150 x 175 x 105 mm
weight
3,0 kg i-CON 1 V / 3,7 kg i-CON 2V
voltage
230 V AC, 50 Hz
nominal power
80 W i-CON 1 V / 120 W i-CON 2V
design
antistatic
temperature range
50 – 450 °C
0100CDJ
Order information:
0460MDJ
Order No.
Description
0IC1100V
i-CON 1V with i-TOOL
0IC1100VCV
i-CON 1V with CHIP TOOL VARIO
0IC1100VXV
0IC1100V0C
i-CON 1V with i-TOOl and interface
0IC2200V
i-CON 2V with i-TOOL
0IC2200VC
i-CON 2V with i-TOOL and CHIP TOOL VARIO
0IC2200VIT
0IC2200VXT
i-CON 2V with i-TOOL, X-TOOL VARIO and vacuum untit
0IC2200V0C
i-CON 2V with i-TOOL and interface
Accessoires
0CA10-001
Easy Arm 1 filter unit for one extraction arm
0CA10-002
Easy Arm 2 filter unit for 2 extraction arms
3CA10-2003
interface cable for EA 1 and EA 2
0IRHP100A-03
heating plate 230V, 800 W
0IRHP100A-12
control cable for heating plate
i- TOOL
CHIP TOOL VARIO
0740EDJ
X-TOOL VARIO
0270BDJ
MICRO TOOL
0640ADJ
TECH TOOL
0840CDJ
POWER TOOL
further information on our website or webshop
0450MDJ
0720EDJ
CHIP TOOL
X-TOOL
297 624 - 11/2015 | subject to change | © Ersa GmbH
Ersa GmbH
Leonhard-Karl-Str. 24
97877 Wertheim
Germany
Tel. +49 9342 800-0
Fax +49 9342 800-127
info@ersa.de
www.ersa.com
France
info-efr@kurtzersa.com
America
info-ena@kurtzersa.com
Mexico
info-kmx@kurtzersa.com
Visit www.ersa.com for further information!
China
info-eap@kurtzersa.com
很抱歉,暂时无法提供与“0IC2200VIT”相匹配的价格&库存,您可以联系我们找货
