0IRHR100A
0IRHR100A
    KURTZERSA
0IRHR100A 数据手册
DATA ERSA HR 100 A Hybrid Rework System HR 100 A ERSA Product Range Soldering Tools Soldering / Desoldering • i-CON series BGA/SMT Rework IR Rework Center • IR/PL 550 A • IR/PL 650 A Hybrid Tool HR 100 A Inspection Systems • ERSASCOPE plus • ImageDoc Software Revolutionary Hybrid Rework Technology – Added Value at you finger tips! Safe IR & Hot Air Combined – The Hybrid Rework Revolution Getting the Best of Both Worlds! The new HR 100A uses ERSA’s revolutionary Hybrid Rework Technology (patent pending) for the safest removal and replacement of small SMDs in a lead free environment! Safe, medium wave IR- radiation combined with a gentle hot air stream guarantees optimal energy transfer to the component. The Hybrid Tool delivers smooth and homogeneous heat to lead free components sizing from 0201s to 20 x 20 mm SMDs. Exchangeable Hybrid Adaptors focus 200 W of hybrid heating power onto the component while protecting neighbouring areas from heat damage. The user friendly operation allows for even non experienced operators to handle the HR 100 A safely and quickly. Advanced operators using the HR/IRHP 100A complete system can not only set air volume and heating power, but they can also run & record profiles! The ergonomically designed Hybrid Tool handle contains a positioning laser which helps the operator to focus the heat precisely throughout the entire process. With the ERSA VacPen attached to the basic unit, safe component handling is ensured. Via the Mini-USB port, the HR 100A can be connected to ERSA’s top of the line and well established rework software, ERSA IRSoft. IRSoft provides multiple functions to operate the system, set and store process parameters and document all soldering or desoldering results. The HR 100 A has been designed to be used with the IRHP 100A, an 800 W IR-heating plate. This complete set provides powerful & safe IR bottom side heating as well as a Z-axis tool stand for the Hybrid Tool and an x-y PCB board holder. The Ktype thermocouple included monitors PCB temperature and even allows for a closed loop soldering processes with ramp profiles. The HR/IRHP 100A set fulfils all needs of a modern Rework System: provides highest flexibility at the lowest cost! Advantages of Hybrid Technology: • Low cost & easy to use • Hybrid technology combines safe IR-radiation and convection • Uniform heating with minimal air movement and turbulence • No chip blowing; low noise rework blower (below 40db) • Designed for beginners & advanced operators • Widest range of components with only three Hybrid Adaptors • Powerful 800 W Safe IR-heating plate for preheating of thick substrates (IRHP100A) Soldering Sytems Wave soldering • ETS series • EWS series • N-Wave series • POWERFLOW series Reflow soldering • HOTFLOW 2 series Selective soldering • VERSAFLOW series Process Software • EPOS • CAD Assistant Paste Printing • VERSAPRINT series Accessories • Solder bar & wire • Solder paste • Flux Other Services • Know-how seminars • In-House training • Test soldering • Installation and maintenance assistance • Process support DATA ERSA HR 100 A Hybrid Rework System HR 100 A Hybrid rework system HR 100A, basis station Mains voltage 220-240 VAC / 110-120 VAC Mains frequency 50-60 Hz / 50-60 Hz Fuse (slow-blow) 2A/4A Secondary voltage 13 VAC Maximum heating power 200 W Safety class I Permissable ambient temperature 0 – 40 °C Temperature range at air outlet 30 – 550 °C Function display LED-Display PC-interface Mini USB Vacuum pressure -0,2 to -0,4 bar Dimensions 211 x 220 x 168 mm Weight 4,5 kg Supply line 2m, PVC, with connector Single-knob control via incremental encoder Hybrid Tool Length of supply line 1,35 m Weight 300 g Laser Class II Heating plate IRHP100A Mains voltage 220-240 VAC / 110-120 VAC Mains frequency 50-60 Hz / 50-60 Hz Fuse (slow-blow) 4A/8A Maximum heating power 800 W Safety class Dimensions Basis station Heating plate Height of tool attachment Circuit board holder I 211 x 220 x 188 200 x 260 x 53,5 214,5 330 x 250 Weight mm mm mm mm 2,5 kg Supply line 2m, PVC, with connector, Control line with RCA(Cinch)-connector. Valid for all electrical devices Antistatic surface, suited for the application in ESD areas, EMV-tested. Conformity ERSA Hybrid Tool Hybrid Tool with closed loop preheat Technical Highlights: • Hybrid Tool with 200 W combined Infrared and convection heating element • Three exchangeable Hybrid Adaptors (6 x 6 mm, 10 x 10 mm & 20 x 20 mm) • Positioning laser in the Hybrid Tool handle • HR 100A station controls Hybrid Tool with integrated vacuum pump and VacPen, tool holder and K-Typ TC input socket, Mini USB interface, 7-segement LED- display, single knob “Turn & Push” control and connection socket for optional heating plate • K-type thermocouple AccuTC and Flexpoint TCholder (optional) • ERSA IRSoft Rework Control- and Documentation software (optional) IRSoft profiling and recording software • 800 W IR-heating plate with glass cover, 125 x 125 mm high performance heating element, Zaxis adjustable tool holder and x-y PCB board holder to precisely fix PCBs up to 290 x 250 mm (IRHP100A) Hybrid Rework System HR 100 A with 200 W Hybrid Tool, three Hybrid Adaptors, Adaptor changer, VacPen and tool holder 0IRHR100A (230 V system) 1IRHR100A0A67 (115 V system) Hybrid Rework System HR 100 A with 200 W Hybrid Tool, three Hybrid Adaptors, Adaptor changer, VacPen and tool holder plus Heating Plate for HR 100 A 800 W IR-heating complete with tool holder for Hybrid Tool and PCB cardboard holder, Flexpoint TC-holder with AccuTC thermocouple, USB – connection cable and CDRom containing software IRSoft and drivers Asien: ERSA Asia Pacific • Hong Kong Phone: +8 52 / 23 31 22 32 Fax: +8 52 / 27 58 77 49 e-mail: kurtz@kfe.com.hk www.ersa.com ERSA Asia Pacific • Shanghai Phone: +86 21 / 52 41 60 00 Fax: +86 21 / 52 41 99 18 e-mail: kurtz@kurtz.com.cn www.ersa.com Ordering information: 142855 - 0807 • subject to changes • © by ERSA Temperature controlled SMD soldering 0IRHR100A-HP (230 V system) 1IRHR100AHPA67 (115 V system) USA: KURTZ North America Phone: 800 363 3772 Fax: +1 / 92 08 93 33 22 e-mail: ersainfo@kna.net www.ersa.com Europe (Headquarters): ERSA GmbH Leonhard-Karl-Str. 24 97877 Wertheim / Germany Phone: +49 (0) 9342 / 800-0 Fax: +49 (0) 9342 / 800-100 e-mail: info@ersa.de www.ersa.de
0IRHR100A
物料型号: - HR 100 A
器件简介: - 这是一个革命性的混合返工技术,结合了安全的中波红外辐射和温和的热风,适用于无铅环境下小型SMD的移除和替换。
引脚分配参数特性: - 该系统配备了可交换的混合适配器,聚焦200瓦的混合加热能力于组件上,同时保护邻近区域免受热损伤。 - 操作界面友好,即使是非经验丰富的操作员也能安全快速地使用。 - 高级操作员可以使用HR/IRHP 100A完整系统设置空气流量和加热功率,还可以运行和记录配置文件。
功能详解: - 人体工程学设计的混合工具手柄包含定位激光,帮助操作员在整个过程中精确聚焦热量。 - 通过Mini-USB端口,HR 100A可以连接到ERSA的顶级返工软件IRSoft,提供多种功能来操作系统、设置和存储过程参数,并记录所有焊接或拆焊结果。
应用信息: - 适用于从0201尺寸到20 x 20毫米SMD的各种组件。
封装信息: - HR 100 A设计用于与IRHP 100A配合使用,这是一个800瓦的红外加热板,提供强大且安全的红外底部加热以及Z轴工具支架和x-y PCB板支架。
0IRHR100A 价格&库存
很抱歉,暂时无法提供与“0IRHR100A”相匹配的价格&库存,您可以联系我们找货
