0722EN0818
0722EN0818
    KURTZERSA
0722EN0818 数据手册
44 722 series  DIGITAL ERSADUR desoldering tips for: Product group 1 Figure / Description Order No. pcs € / pu p. pu excl. VAT 2000 A  XTOOLKIT1  i-CON/i-CON2 VARIO 2  i-CON VARIO 4 X-TOOL desoldering tool each with X-TOOL desoldering tool GTIN (EAN-Code)  i-CON X-TOOL desoldering tool Figure / Description Order No. pcs € / pu p. pu excl. VAT ERSADUR, ID 0.8 mm/0.031 in, OD 2.1 mm/0.083 in 0722ED 0821/SB 1 24.00 nickel-plated, ID 1.2 mm/0.047 in OD 2.3 mm/0.091 in 0722EN 1223/SB 1 18.70 ERSADUR, ID 1.2 mm/0.047 in, OD 2.6 mm/0.102 in 0722ED 1226/SB 1 24.00 nickel-plated, ID 1.5 mm/0.059 in OD 2.9 mm/0.114 in 0722EN 1529/SB 1 18.70 ERSADUR, ID 1.0 mm/0.039 in / 1.5 mm/0.059 in, OD 2.3 mm/0.091 in 0722ED 1023/SB 1 24.00 nickel-plated, ID 1.5 mm/0.059 in OD 4.8 mm/0.189 in 0722EN 1548/SB 1 18.70 ERSADUR, ID 1.0 mm/0.059 in / 1.5 mm/0.059 in, OD 2.9 mm/0.114 in 0722ED 1529/SB 1 24.00 nickel-plated, ID 2.3 mm/0.091 in OD 3.2 mm/0.126 in 0722EN 2332/SB 1 18.70 ERSADUR, ID 2.4 mm/0.094 in OD 3.8 mm/0.150 in 0722ED 2438/SB 1 24.00 nickel-plated, ID 2.3 mm/0.091 in OD 4.8 mm/0.189 in 0722EN 2348/SB 1 18.70 nickel-plated, ID 0.8 mm/0.031 in OD 1.8 mm/0.071 in 0722EN 0818/SB 1 18.70 nickel-plated, ID 0.6 mm/0.236 in OD 1.5 mm/0.059 in 0722EN 0615S/SB 1 18.70 nickel-plated, ID 0.8 mm/0.031 in OD 2.3 mm/0.091 in 0722EN 0823/SB 1 18.70 nickel-plated, ID 1.0 mm/0.039 in OD 1.8 mm/0.071 in 0722EN 1018S/SB 1 18.70 nickel-plated, ID 1.0 mm/0.039 in OD 2.0 mm/0.079 in 0722EN 1020/SB 1 18.70 nickel-plated, ID 1.0 mm/0.039 in OD 2.3 mm/0.091 in 0722EN 1023/SB 1 18.70 Further tips on request. Subject to technical changes! pu = packing unit; /SB = single piece package; /10 = 10 pcs packing unit GTIN (EAN-Code)
0722EN0818 价格&库存
很抱歉,暂时无法提供与“0722EN0818”相匹配的价格&库存,您可以联系我们找货
