Ersa EASY ARM 1 and EASY ARM 2
Ersa solder fume extractions – silent and efficient as never before!
Technical highlights:
Efficient 3-stage particle- and gas filtering
Super silent operation
Independently adjustable suction power per arm
Optical and acoustical filter exchange status
Easy and fast filter exchange – without tools
Identical filters for EASY ARM 1 and EASY ARM 2
Interface to interact with i-CON soldering stations
Ersa solder fume extractions satisfy with high exhaust power and super silent operation!
Ersa solder fume extraction units are based on
over 15 years of experience in process air cleaning
by Ersa.
They stand out by a high suction power and an
efficient filter performance combined with super silent operation. Exhaust volume per arm is
110 m³/h. Both the EASY ARM 1 and EASY ARM 2
are equipped with filters that clean the process
air in three stages: The pre-filter absorbs dust
and big particles. The combined filter separates
micro particles which occur during soldering and
absorbs dangerous gas molecules in the incorporated activated carbon filter.
The operator can choose between a system with
one exhaust arm – the EASY ARM 1 – and a unit
with two exhaust arms – the EASY ARM 2. Both
units can be mounted individually by means of
their table clamp. Exhaust power is set independently for each extraction arm at the touch of a
button. The EASY ARM 1 and EASY ARM 2 use
an identical pre-filter and combined filter. Optical and acoustical signals inform the operator
when filters have to be exchanged. A wide range
of exhaust arms and nozzles for all applications
are available so that the user will find the proper
solution for his requirements.
For energy saving purposes and to extend filter
lifetime, both units can be connected with Ersa
i-CON soldering stations or a standby switch. In
this way, the extraction unit is only working whilst
the attached soldering station is in operation,
stopping as soon as the soldering station goes
into standby mode.
Detailbild + Bildunterschrift
Clearly structured
control panel
Ersa EASY ARM 1
with exhaust arm
Omniflex and round
exhaust nozzle
High-end filter materials,
same filters for EASY ARM 1 and EASY ARM 2
Efficient solder fume extraction
directly at the solder joint
Technical data
Accessories and spare parts
Ersa EASY ARM 1
Ersa EASY ARM 2
Ord. no.
Dimensions (L x W x H), incl. inlet:
255 mm x 255 mm x 470 mm
490 mm x 255 mm x 470 mm
Weight:
7.5 kg
15 kg
Volume flow (with new filter):
1 x 110 m³/h
2 x 110 m³/h
0CA10-4002 extraction arm, 1,000 mm
Highflex, direct mount at
the filter unit
Volume flow of blower:
1 x 130 m³/h
2 x 130 m³/h
Vacuum:
1 x 1,800 Pa
2 x 1,800 Pa
Noise level:
50 dB (A)
50 dB (A)
Filter class
Prefilter (mat):
Combined filter:
F7
H13
F7
H13
Separation degree (HEPA)
Prefilter 1 – 10 μm particles:
Combined filter
很抱歉,暂时无法提供与“0CA10-4001”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+4648.698691+596.71583
- 5+4380.762415+562.32302
