0ICT1000A
0ICT1000A
    KURTZERSA
    ERSA - 0ICT1000A - Soldering Station, i-CON Trace, 150 W, 230 VAC, 450 °C
0ICT1000A 数据手册
Article no. 0ICT1000A (US Version: 1ICT1000A00A67) IoT SOLDERING STATION i-CON TRACE As Ersa‘s first IoT soldering station, i-CON TRACE revolutionizes the market of industrial soldering stations. The i-CON TRACE is the first soldering station that enables complete process control in manual soldering straight out of the box. The soldering station is primarily intended for use in a digitally connected environment - essential settings are made via I/O devices that are already integrated into the company network, such as PCs, tablets or smartphones. But also a customer‘s MES can be used for data exchange by means of a suitable interface. This enables the user simultaneous access to all soldering stations in the network and makes operation extremely convenient. The most important differentiating features (USPs) are its connectivity and high process reliability, from which numerous significant advantages result:  Increased process reliability by the predefinition of relevant parameters and recording/documentation of the process data  Increased productivity and soldering quality due to quick and safe change of the soldering tip: Tip‘n‘Turn  Highest precision and excellent reliability  Significant cost reduction due to separately replaceable soldering tips For more information, see: 142.ersa.com Technical Data: Mains voltage: 220 - 240 V AC / 110 - 120 V AC Mains frequency: 50 / 60 Hz Fuse protection: 0.8 A / 1.6 A Power rating: max. 150 W Temperature range: 50 - 450 °C Markings: VDE, CE, MET, SRRC, FCC ESD safe: yes Dimensions (W x D x H): 156 x 175 x 102 mm / 6,1 x 6,9 x 4 in (Control station) 146 x 135 x 94 mm / 5,7 x 5,3 x 3,7 in (Holder) Weight: ca. 3,100 g / 6,83 lbs (Control station) ca. 750 g / 1,65 lbs (Holder) Communication: WLAN, LAN (0ICT125 - optional) Accessories: 0ICT1000A Soldering station i-CON TRACE 230 V 1ICT1000A00A67 Soldering station i-CON TRACE 115 V 0140CDJ Soldering tool i-TOOL TRACE 0ICT125 Network card 014100J Heating element 0A58 Holder 0DTM110 Digital temperature measuring device Suitable soldering tip series: Serie 142 Ersa GmbH | Leonhard-Karl-Straße 24, D-97877 Wertheim | Tel.: +49 9342 800-0 | info@ersa.de | www.kurtzersa.com
0ICT1000A 价格&库存
很抱歉,暂时无法提供与“0ICT1000A”相匹配的价格&库存,您可以联系我们找货
