Article no. 0ICT1000A (US Version: 1ICT1000A00A67)
IoT SOLDERING STATION i-CON TRACE
As Ersa‘s first IoT soldering station, i-CON TRACE revolutionizes the
market of industrial soldering stations. The i-CON TRACE is the first
soldering station that enables complete process control in manual
soldering straight out of the box.
The soldering station is primarily intended for use in a digitally
connected environment - essential settings are made via I/O devices
that are already integrated into the company network, such as PCs,
tablets or smartphones. But also a customer‘s MES can be used
for data exchange by means of a suitable interface. This enables
the user simultaneous access to all soldering stations in the
network and makes operation extremely convenient.
The most important differentiating features (USPs) are its
connectivity and high process reliability, from which numerous
significant advantages result:
Increased process reliability by the predefinition of relevant
parameters and recording/documentation of the process data
Increased productivity and soldering quality due to quick
and safe change of the soldering tip: Tip‘n‘Turn
Highest precision and excellent reliability
Significant cost reduction due to separately replaceable
soldering tips
For more
information, see:
142.ersa.com
Technical Data:
Mains voltage:
220 - 240 V AC / 110 - 120 V AC
Mains frequency:
50 / 60 Hz
Fuse protection:
0.8 A / 1.6 A
Power rating:
max. 150 W
Temperature range:
50 - 450 °C
Markings:
VDE, CE, MET, SRRC, FCC
ESD safe:
yes
Dimensions (W x D x H): 156 x 175 x 102 mm /
6,1 x 6,9 x 4 in (Control station)
146 x 135 x 94 mm /
5,7 x 5,3 x 3,7 in (Holder)
Weight:
ca. 3,100 g / 6,83 lbs
(Control station)
ca. 750 g / 1,65 lbs (Holder)
Communication:
WLAN, LAN
(0ICT125 - optional)
Accessories:
0ICT1000A
Soldering station i-CON TRACE 230 V
1ICT1000A00A67 Soldering station i-CON TRACE 115 V
0140CDJ
Soldering tool i-TOOL TRACE
0ICT125
Network card
014100J
Heating element
0A58 Holder
0DTM110
Digital temperature measuring
device
Suitable soldering tip series:
Serie 142
Ersa GmbH | Leonhard-Karl-Straße 24, D-97877 Wertheim | Tel.: +49 9342 800-0 | info@ersa.de | www.kurtzersa.com
很抱歉,暂时无法提供与“014100J”相匹配的价格&库存,您可以联系我们找货
