082 KD/SB
082 KD/SB
    KURTZERSA
    ERSA  082 KD/SB  TIP, STRAIGHT, 80W, 4.8MM
082 KD/SB 数据手册
ERSA Standard Soldering Irons 50 W 052 JD / JN 052 KD 052 BD 052 ND 052 DD 80 W 082 JD / JN 082 KD ERSA 50 W ERSA 80 W ERSA 150 W This standard soldering iron is particularly suitable for copper conductor soldering up to a maximum cross section of 2.5 mm 2 (0.123 in 2). This classic soldering iron is extremely useful to solder copper conductors up to a 4 mm 2 (0.15 in 2 ) cross section. This externally heated ERSA soldering iron is designed to solder copper cross sections up to 6 mm 2 (0.2 in 2). Technical data: Rating: 50 W Heating time: appr. 3 min Sold. tip temperature: appr. 400°C/752°F Weight (without cable): 160 g / 5.6 oz Cable: 1.5 m / 4.9 ft, rubber sheathed Voltage: 230 V Different voltages on request Technical data: Rating: 80 W Heating time: appr. 3 min Sold. tip temperature: appr. 410°C/770°F Weight (without cable): 220 g / 7.6 oz Cable: 1.5 m / 4.9 ft rubber sheathed Voltage: 230 V Different voltages on request Technical data: Rating: 150 W Heating time: appr. 3 min Sold. tip temperature: appr. 450°C/842°F Weight (without cable): 245 g / 8.6 oz Cable: 1.5 m / 4.9 ft rubber sheathed Voltage: 230 V Different voltages on request Order nos.: 050 JN 50 W soldering iron with 052 JN nickel-plated copper soldering tip and A 04 tool holder 050 JD 50 W soldering iron with 052 JD long-life soldering tip and A 04 tool holder 05100 Spare heating element for 50 W soldering iron Order nos.: 080 JN 80 W soldering iron with 082 JN nickel-plated copper soldering tip and A 04 tool holder 080 JD 80 W soldering iron with 082 JD long-life soldering tip and A 04 tool holder 08100 Spare heating element for 80 W soldering iron Order nos.: 150 JN 150 W soldering iron with 152 JN nickel-plated copper soldering tip and A 04 tool holder 150 JD 150 W soldering iron with 152 JD long-life soldering tip and A 04 tool holder 15100 Spare heating element for 150 W soldering iron 150 W 152 JD / JN 152 KD 152 HD Dimensions in brackets for ERSADUR long-life soldering tips (for tip design see page 14) 7
082 KD/SB
PDF文档中提到的物料型号包括ERSA Standard Soldering Irons的50W、80W和150W版本。
例如,50W型号有052 JD/JN、052 KD、052 BD、052 ND和052 DD;80W型号有ERSA 80 W、082 JD/JN;150W型号有ERSA 150 W、082 KD。
器件简介指出这些烙铁适用于不同截面积的铜导体焊接,例如50W适合最大2.5 mm²,80W适合最大4 mm²,150W适合最大6 mm²。
引脚分配封装信息在文档中没有明确提及。
参数特性包括功率、加热时间、烙铁头温度、重量、电缆长度和电压,例如50W型号的烙铁头温度约为400°C,重量约为160克,电缆长度为1.5米。
功能详解描述了不同功率烙铁的适用场景,如50W适合细铜导体焊接,80W和150W适用于更粗的铜导体。
应用信息指出这些烙铁适用于铜导体的焊接工作,具体适用的截面积根据不同型号的功率而定。
封装信息在文档中没有详细描述,但提供了不同型号烙铁的订购编号和备件信息,如加热元件和烙铁头。
082 KD/SB 价格&库存
很抱歉,暂时无法提供与“082 KD/SB”相匹配的价格&库存,您可以联系我们找货
