0CA10-4002
0CA10-4002
    KURTZERSA
    ERSA - 0CA10-4002 - EXTRACTION ARM, 1000 HIGHF, FUME EXTRACN
0CA10-4002 数据手册
Ersa EASY ARM 1 and EASY ARM 2 Ersa solder fume extractions – silent and efficient as never before! Technical highlights: „„ Efficient 3-stage particle- and gas filtering „„ Super silent operation „„ Independently adjustable suction power per arm „„ Optical and acoustical filter exchange status „„ Easy and fast filter exchange – without tools „„ Identical filters for EASY ARM 1 and EASY ARM 2 „„ Interface to interact with i-CON soldering stations Ersa solder fume extractions satisfy with high exhaust power and super silent operation! Ersa solder fume extraction units are based on over 15 years of experience in process air cleaning by Ersa. They stand out by a high suction power and an efficient filter performance combined with super silent operation. Exhaust volume per arm is 110 m³/h. Both the EASY ARM 1 and EASY ARM 2 are equipped with filters that clean the process air in three stages: The pre-filter absorbs dust and big particles. The combined filter separates micro particles which occur during soldering and absorbs dangerous gas molecules in the incorporated activated carbon filter. The operator can choose between a system with one exhaust arm – the EASY ARM 1 – and a unit with two exhaust arms – the EASY ARM 2. Both units can be mounted individually by means of their table clamp. Exhaust power is set independently for each extraction arm at the touch of a button. The EASY ARM 1 and EASY ARM 2 use an identical pre-filter and combined filter. Optical and acoustical signals inform the operator when filters have to be exchanged. A wide range of exhaust arms and nozzles for all applications are available so that the user will find the proper solution for his requirements. For energy saving purposes and to extend filter lifetime, both units can be connected with Ersa i-CON soldering stations or a standby switch. In this way, the extraction unit is only working whilst the attached soldering station is in operation, stopping as soon as the soldering station goes into standby mode. Detailbild + Bildunterschrift Clearly structured control panel Ersa EASY ARM 1 with exhaust arm Omniflex and round exhaust nozzle Detailbild + Bildunterschrift High-end filter materials, same filters for EASY ARM 1 and EASY ARM 2 Efficient solder fume extraction directly at the solder joint Ersa EASY ARM 1 and EASY ARM 2 Ersa solder fume extractions – silent and efficient as never before! Technical data Accessories and spare parts Ersa EASY ARM 1 Ersa EASY ARM 2 Ord. no. Dimensions (L x W x H), incl. inlet: 255 mm x 255 mm x 470 mm 490 mm x 255 mm x 470 mm Weight: 7.5 kg 15 kg Volume flow (with new filter): 1 x 110 m³/h 2 x 110 m³/h 0CA10-4002 extraction arm, 1,000 mm Highflex, direct mount at the filter unit Volume flow of blower: 1 x 130 m³/h 2 x 130 m³/h Vacuum: 1 x 1,800 Pa 2 x 1,800 Pa Noise level: 50 dB (A) 50 dB (A) Filter class Prefilter (mat): Combined filter: F7 H13 F7 H13 Separation degree (HEPA) Prefilter 1 – 10 μm particles: Combined filter
0CA10-4002 价格&库存
很抱歉,暂时无法提供与“0CA10-4002”相匹配的价格&库存,您可以联系我们找货
0CA10-4002
  • 1+2161.259061+279.61655
