212 MS
212 MS
    KURTZERSA
    ERSA - 212 MS - Soldering Iron Tip, Blade, 2.3 mm
212 MS 数据手册
ERSA SMT UNIT 60 A Micro tool / Pincette 40 65 / 130 W heat up rating 212 SD 2 1 2 212 BD 1 2 212 CD 1 2 212 ED 1 212 KD 2 212 FD 2 212 GD 2 212 MS 2 212 WD Cross section of an ERSADURsoldering tip (see p. 9) Please ask for our tip sheet with addtional tips! 20 1 2 Tips for SMD 8012 Tips for SMD 8013 SMD Soldering and Desoldering Station - to meet every budget The SMT UNIT 60 A from ERSA will handle virtually any soldering job - whether it is SMD soldering, desoldering or repair work. It is electronically temperaturecontrolled and antistatic according to MIL-SPEC/ESA-standards and has two separately controlled tools: the ultra-light ERSA Micro tool SMD soldering iron and the versatile ERSA Pincette 40 for desoldering. An extensive range of SMD soldering and desoldering tips compliments these tools. The Micro tool has a range of long-lasting ERSADUR soldering tips beginning at 0.2 mm (0.008“), making it ideal for very fine and compact soldering work. The revolutionary ERSA MicroWell tip enables you to install fine-pitch SMDs in a matter of seconds. The desoldering tip range of the Pincette 40 covers everything from MELFs and mini-MELFs to SOIC packages, QFPs and PLCC’s. Its wide range of tips means you can use the ERSA SMT UNIT 60 A to work on practically any commercially available SMT component. And because you can change the rapid heat up tips in a matter of seconds, even when they are hot, you can work quickly and efficiently. The multifunctional holder with its swiveling sponge container also functions as a hot tip holder. The holder is designed so that you can use ERSA soldering irons with any commercially available solder fume extraction system provided you have an adapter. The ultra-fine 0.2 mm (0.008”) tip (212 SD) Quick and easy SMD rework A B C Desoldering tips (pair) for Pincette 40 422 ED: 1 2 6 mm (0.236 in) SOIC 8 422 FD 3: 7,5 mm (0.295 in) SOIC 12 422 FD 1: 10 mm (0.394 in) 1 2 SOIC 16 422 FD 4: 12,5 mm (0.492 in) 2 SOIC 20 422 FD 2: 15 mm (0.591 in) 1 2 SOIC 24 422 FD 5: 17,5 mm (0.689 in) 2 SOIC 28 422 FD 6: 20 mm (0.787 in) 2 SOIC 32 422 FD 7: 25 mm (0.984 in) SOIC 40 422 FD 8: 27,5 mm (1.082 in) 422 FD 9: 40 mm (1.574 in) Technical data: SMT 603 A electronic station Supply voltage: 230 V~, 50-60 Hz Secondary voltage: 24 V~ Rating: 60 W Control technique: RESISTRONIC Temperature range: Micro tool: stepless 150°C (300°F) - 400°C (750°F) Pincette 40: subject to tips Function display: red LED Cable: 2 m (6.6 ft) PVC with connector Model: safety insulated, antistatic according to MIL-SPEC/ESA standards Micro tool soldering iron Voltage: 24 V~ Rating: 30 W / 280°C (545°F) - 20 W / 350°C (660°F) Heat up rating: 65 W Heating time: appr. 50 s (to 280°C/545°F) C.CAPAC./MELF SOT&DPAK Weight (without cable): appr. 25 g (1 oz) Cable: 1.2 m (3.9 ft) highly flexible/ heat resistant, antistatic Model: antistatic according to MIL-SPEC/ESA standards Order nos: Pincette 40 desoldering tweezers Voltage: 24 V~ Rating: 2 x 30 W / 280°C (545°F) - 2 x 20 W / 350°C (660°F) Heat up rating: 130 W Heating time: subject to tips Weight (without cable): appr. 75 g (3 oz) Cable: 1.2 (3.9 ft) m highly flexible/ heat resistant, antistatic Model: antistatic according to MIL-SPEC/ESA standards consisting of: SMT 603 A Electronic station 270 BDJ Micro tool soldering iron with 212 BD soldering tip 430 EDJ Pincette 40 desoldering tweezers with 422 ED desoldering tips A 29 Holder for Micro tool A 30 Holder for Pincette 40 43400 Tip turn protection set for type 422 43500 Tip turn protection set for type 212 and 422 TSOP/SOIC SMT 60 A PLCC/LCCC SMT UNIT 60 A soldering and desoldering station complete BQFP/PQFP Please choose your suitable SMD desoldering tips out of the series 422. (further SMD desoldering tips upon request) ERSA SMD tip holder Please ask for our free-of-charge process descriptions „Fine-Pitch Installation“ and „SMD-removal“ (see page 31) Order nos.: 422 QD 5: 10 mm (0.394 in) 2 PLCC 20 422 QD 1: 12,5 mm (0.492 in) 1 PLCC 28 422 QD 6: 15 mm (0.591 in) QFP, TQFP, TTQFP TTQFP 80T25 422 QD 3: 17,5 mm (0.689 in) 1 2 PLCC 44 422 QD 4: 20 mm (0.787 in) 1 PLCC 52 SMD 8012 422 QD 2: 25 mm (0.984 in) 1 PLCC 68 422 QD 7: 30 mm (1.191 in) PLCC 84 422 QD 8: BQFP 132 SMD 8012 422 QD 9: BQFP 100 422 QD 10: 22,5 mm (0.886 in) QFP 112 422 RD 1: 22,5 x 16,5 mm (0.886 x 0.650 in) QFP 100 422 RD 2: 15 x 12,5 mm (0.591 x 0.492 in) PLCC 32 422 RD 3: 15 x 10 mm (0.591 x 0.394 in) PLCC 28-1 422 SD: MICROMELF 2 422 MD: MELFS/MINIMELFS 1 2 1 2 Tips for SMD 8012 Tps for SMD 8013 The fully equipped tip holder makes organizing and accessing your SMD soldering/desoldering tips an easy task, while at the same time saving space! Order nos: SMD 8013 SMD tip holder completely equipped consisting of: SH 03 Tip holder ERSADUR-SMD soldering tips 212 SD pencil point, 0.2 mm/0.008 in ø 212 BD pencil point; 0.4 mm/0.016 in ø 212 CD chisel-shaped, 1.0 mm/0.039 in 212 ED chisel-shaped, 1.8 mm/0.071 in 212 FD chisel-sh., reinf., 2.2 mm/0.087 in 212 GD chisel-sh., reinf, 3.2 mm/0.126 in This extremely practical and ergonomical tip holder is an indispensable aid that no SMD workbench should be without. 212 MS 212 WD SMD tip holder completely equipped consisting of: SH 03 Tip holder ERSADUR-SMD soldering tips 212 BD pencil point 0.4 mm ø (0.016 in ø) 212 CD chisel shaped, 1.0 mm (0.039 in) 212 ED chisel shaped, 1.8 mm (0.071 in) 212 KD chisel shaped, extended, 1.8 mm (0.071 in) SMD-desoldering tips (pair) 422 MD for MELFs a. MINIMELFs 422 ED 6 mm (0.236 in) for SOIC 8 422 FD 1 10 mm (0.394 in) for SOIC 16 422 FD 2 15 mm (0.591 in) for SOIC 24 422 QD 1 12.5 mm (0.492 in) for PLCC 28 422 QD 3 17.5 mm (0.689 in) for PLCC 44 422 QD 4 20 mm (0.787 in) for PLCC 52 422 QD 2 25 mm (0.984 in) for PLCC 68 MicroWell, 2.3 mm/0.091 in MiniMicroWell, 1.6 mm/0.063 in SMD-desoldering tips (pair) 422 SD for MICROMELF 422 MD for MELFs a. MINIMELFs 422 ED 6 mm/0.236 in, for SOIC 8 422 FD 1 10 mm/0.394 in, for SOIC 16 422 FD 4 12.5 mm/0.492 in, for SOIC 20 422 FD 2 15 mm/0.591 in, for SOIC 24 422 FD 5 17.5 mm/0.689 in, for SOIC 28 422 FD 6 20 mm/0.787 in, für SOIC 32 422 QD 5 10 mm/0.394 in, for PLCC 20 422 QD 3 17.5 mm/0.689 in, for PLCC 44 SMD 8013 21
212 MS 价格&库存
很抱歉,暂时无法提供与“212 MS”相匹配的价格&库存,您可以联系我们找货
