I-CON PICO
I-CON PICO
    KURTZERSA
I-CON PICO 数据手册
Ersa i-CON PICO & i-CON NANO Powerful, inexpensive and extremely compact i-CON PICO i-CON NANO The i-CON PICO does without ESD capability but has an impact-proof housing. The i-TOOL PICO has a heat-resistant cable and uses an exchangeable high-performance heating element in the combined metal/plastic housing. The i-CON NANO has an impact-proof, conductive and ESD-safe housing. The ESD-safe i-TOOL NANO is connected to the station via a heat-resistant cable and has the original high-performance heating element in a metal housing. The compact tool holder with silicone base and spring support for the soldering iron has room for the dry sponge and soldering tips. The ESD-safe silicone tool holder with its heat-resistant ceramic support holds the soldering tool safely and has room for the dry sponge as well for holding up to four soldering tips. Intuitive 2-button operating concept MicroSD card with SD card and USB adapter The Ersa soldering stations i-CON PICO and i-CON NANO provide professional soldering technology for price-conscious users. Both stations use the technology of the i-CON industrial soldering stations. They have been optimised to meet the requirements of ambitious beginners as well as soldering professionals looking for tried-and-trusted technology at an attractive price. Features SENSOTRONIC temperature control Three settable fixed temperatures Very often, space on the workbench is limited, which is why the compact stations manage with a footprint of only 8 x 4.5 cm. The i-CON NANO is a fully ESD-capable station available for customers who work with ESDsensitive components. The i-CON PICO serves all those looking for a compact solution for standard THT or SMD soldering tasks. The whole range of ERSADUR industrial soldering tips of the 102 series is available for both stations. Tip temperature can be calibrated The stations have an easily legible LC display as well as modern standby and sleep functions available to save energy and go easy on the soldering tips when they are not in use. Unusual for this class: both stations are easy to configure and lock using PC software and microSD card. ESD-design Configurable with microSD card Heating element and tips can be exchanged separately Standby mode Potential equalization soldering tip i-CON PICO i-CON NANO Ersa i-CON PICO & i-CON NANO Powerful, inexpensive and extremely compact Technical data Ersa i-CON PICO soldering station Dimensions (L x W x H) 145 x 80 x 103 mm Voltage 220 – 240 VAC Rating 80 W Temperature range 150 – 450 °C Connectable tools i-TOOL PICO Rating i-TOOL PICO Nominal rating 80 W, max. rating 150 W Heating time approx. 9 s Antistatic version no Technical data Ersa i-CON NANO soldering station 145 x 80 x 103 mm Voltage 220 – 240 VAC Rating 80 W Temperature range 150 – 450 °C Connectable tools i-TOOL NANO Rating i-TOOL NANO Nominal rating 80 W, max. rating 150 W Heating time approx. 9 s Antistatic version yes  0,2 9 0,4 3'/) 0102PDLF02  0102CDLF20 chisel-shaped, 2.0 mm 0102ADLF13 $'/) angled face, 1.5 mm &'/) ,6   5,2   ‘ 30 ‘     Ø   ‘ ‘   23 0102CDLF04 chisel-shaped, 0.4 mm pencil point, 0.2 mm ø    4,5    Ø ‘  ‘  ‘  5,2 ,2 26 ‘  Ø   Dimensions (L x W x H) Ø 0,4   3'/) 0102PDLF06 pencil point, 0.6 mm ø  45 ° 9,5 0102CDLF16 chisel-shaped, 1.6 mm  0102SDLF04 bent, 0.4 mm ø &'/)  0102ADLF20 angled face, 2.0 mm $'/) See 102.ersa.de for further tips Ordering information: Accessories: Order no. Description Order no. Description 0IC1300 i-CON PICO soldering station, complete with i-TOOL PICO soldering iron (0130CDK), with soldering tip 1.6 mm, chisel-shaped (0102CDLF16) and tool holder (0A53) 0IC138 SD card reader with USB adapter and configuration software for i-CON PICO 0IC1200A i-CON NANO soldering station, complete with i-TOOL NANO soldering iron (0120CDK), with soldering tip 1.6 mm, chisel-shaped (0102CDLF16) and tool holder (0A52) 0IC128 SD card reader with USB adapter and configuration software for i-CON NANO 343 413 - 05/2018 | Subject to change | © Ersa GmbH Ersa Ersa GmbH GmbH Leonhard-Karl-Str. Leonhard-Karl-Str. 24 24 97877 97877 Wertheim Wertheim Germany Germany Tel. Tel.+49 +499342 9342800-0 800-0 Fax Fax+49 +499342 9342800-127 800-127 info@ersa.de info@ersa.de www.ersa.de www.ersa.com Frankreich France info-efr@kurtzersa.com info-efr@kurtzersa.com Amerika America info-ena@kurtzersa.com info-ena@kurtzersa.com China Korea Mexico China info-eap@kurtzersa.com info-kmx@kurtzersa.com kmc@kmckr.co.kr info-eap@kurtzersa.com Besuchen Sie www.ersa.de weitere Informationen! Visit www.ersa.com for für further information!
I-CON PICO 价格&库存
很抱歉,暂时无法提供与“I-CON PICO”相匹配的价格&库存,您可以联系我们找货
