0G072AN
0G072AN
    KURTZERSA
0G072AN 数据手册
DATA Independent 75 Maximum independence with the multifunctional ERSA gas soldering sets 15–75 ^ = Watt ERSA-product range Soldering tools • NEW DIMENSION • PROFI-LINE • IR-Rework • CLEAN-AIR Soldering systems Wave soldering • • • • Fig.: Independent 75 Profi Set Off the line gas soldering power, infinitely variable up to 75 W. Comfortable piezo ignition. Operated with lighter gas. Mobile power - wherever you may need it! Efficient, In addition to the „Basic Set“, the Independent with a wide range of high quality accessories, 75 „Profi Set“ includes another 2 soldering tips small, handy and a convenient packaging: this suitable for virtually every soldering application. gas soldering set is very versatile! The ergonomic A hot blade to shape and cut high-resistance antistatic gas soldering iron with piezo ignition foam, a hot gas nozzle, a deflector to shrink is the perfect tool for service and maintenance heat-shrinkable sleeves and to solder SMD com- work - especially when there is no electric power ponents as well as a flame nozzle to micro supply available. weld complete the equipment and open up many With its infinitely variable power rating from different applications. 15 up to 75 watts (compared with electrical ETS-line EWS-line N-Wave-line Solution Reflow soldering • • • • • • Hotflow 3 Hotflow 5 Hotflow 7 Hotflow 9 Hotflow 11 ERS 250 Selective soldering • • • • • EAS-line Multiflow Versaflow Versaflow Compact Versaflow High Speed • Place & Solder soldering irons) max. soldering tip temperatures Inspection systems of 500°C can be achieved. The Independent 75 • ERSASCOPE • ImageDoc Software operates on commercially available butane lighter gas. The Independent 75 „Basic Set“ is supplied in a practical transport case, consisting of a gas soldering iron with pre-installed catalytic soldering tip, a spare tip and a sponge container with cleaning sponge. Other services • • • • Know-how seminars In-House trainings Test soldering Installation and maintenance assistance • Process support Independent 75 DATA Maximum independence with the multifunctional ERSA gas soldering sets Technical data: Rating: 15 - 75 W Heating time: 183°C in approx. 30 sec. Sold. tip temp.: approx. 500°C max. Weight: 73 g Ignition: piezo ignition, operates on butane gas Order nos.: 0G07400141 Gas soldering set Indpendent 75 „Profi Set“ consisting of: 0G070KN 0G072CN 0G072AN 0G072VN 0G072BE 0G072HE 0G072MN 0G072RE 0A20 0006 0G156 Gas soldering iron Independent 75 with chisel-shaped soldering tip 0G072KN, 2.4 mm Chisel-shaped sold. tip, 1.0 mm Chisel-shaped sold. tip, 3.2 mm Chisel-shaped sold. tip, 4.8 mm Flame nozzle Hot gas nozzle Hot blade Deflector to shrink heatshrinkable sleeves Holder Cleaning sponge Sponge container original size 5PE0701-IN75 • subject to changes • © by ERSA Order nos.: 0G07400041 Gas soldering set Indpendent 75 „Basic Set“ consisting of: 0G070KN 0G072CN 0A20 0006 0G156 Gas soldering iron Independent 75 with chisel-shaped soldering tip 0G072KN, 2.4 mm Chisel-shaped sold. tip, 1.0 mm Holder Cleaning sponge Sponge container Accessories: 0G 806 K Gas cartridge, 65 ml ERSA GmbH Otto-Schott-Straße 3-7 P.O.Box 1261 97862 Wertheim/Germany Tel: +49(0)9342/800-0 Fax:+49(0)9342/800-250 e-mail: info@ersa.de http://www.ersa.de
0G072AN 价格&库存
很抱歉,暂时无法提供与“0G072AN”相匹配的价格&库存,您可以联系我们找货
0G072AN
    库存:29
