ERSA 150 S
ERSA 150 S
    KURTZERSA
    ERSA - ERSA 150 S - SOLDERING IRON, 150W, 230V, EURO PLUG
ERSA 150 S 数据手册
ERSA 150 S Art.Nr.: 0155JD EAN: 4003008019223 Suitable Soldering tip: · 152 ERSA 150 S This externally heated ERSA soldering iron is designed to solder copper cross sections up to 6 mm² (0.2 in²). Supplied with ERSADUR long-life soldering tip 0152JD and tool holder 0A04 Technical data Power rating (Watt): 150 Supply (Volt): 230 Preheating time in seconds: 180 Max Temperature in °C: 450 Design Lötspitze: Coating Tip: ERSADUR tip Antistatic design: No Shape of soldering tip: chisel-shaped Soldering tip diameter / width, mm: 5,3 Soldering / Desoldering tip: 152 Replacement heating element: E015100
ERSA 150 S 价格&库存
很抱歉,暂时无法提供与“ERSA 150 S”相匹配的价格&库存,您可以联系我们找货
