ERSA TIP 260
ERSA TIP 260
    KURTZERSA
    ERSA - ERSA TIP 260 - SOLDERING IRON, 230V, 16W, EURO PLUG
ERSA TIP 260 数据手册
ERSA Microsoldering Irons Minor 042 BD 042 LD Minityp 012 BD Tip 260 162 BD / 162 BN 162 LD / 162 LN 162 KD / 162 KN Dimensions in brackets for ERSADUR long-life soldering tips (for tip design see page 14) 4 ERSA Minor ERSA Minityp ERSA Tip 260 Miniature soldering iron with ERSADUR soldering tip for ultrafine soldering of microcircuits and microscope soldering. 6 V transformer-operated (e.g. ERSA SNT 30/6) or 6 V batteryoperated. The reduced distance between handle and soldering tip of the curved type takes particular account of ergonomic requirements. ERSA Minor, in addition to the electronics industry, is used for clock production or repair, and photographic industry and dental engineering applications. Miniature soldering iron for the microelectronics industry. Same applications as ERSA Minor. Minityp can be operated with a 12 V battery or the MS 250 / S soldering station (see p. 20). Light and easy-to-handle soldering iron with internally heated soldering tip. The slim design provides ideal access to the most difficult locations. For small soldering joints in electronics and electrotechnical applications. The PTC (Positive Temperature Coefficient) heating element ensures short heating times and a remarkably long service life. Technical data: Rating: 6 W Heating time: appr. 20 s Sold. tip temperature: appr. 390°C/734°F Weight (without cable): 7 g / 0.25 oz Cable: 1.2 m / 3.9 ft PVC Voltage: 12 V Tubular leg diameter: 2 mm / 0.08 in* Technical data: Rating: 5 W Heating time: appr. 12 s Sold. tip temperature: appr. 440°C/824°F Weight (without cable): 6 g / 0.2 oz Cable: 1.2 m / 3.9 ft PVC Voltage: 6 V Tubular leg diameter: 1.5 mm / 0.06 in* Order nos.: 010 BDH Minityp soldering iron with 012 BD long-life soldering tip 010 BDH 040 Minityp soldering iron with 012 BD long-life soldering tip to connect to MS 250/S soldering station (cinch plug) Order nos.: 040 BDG Minor soldering iron with 042 BD long-life sold. tip * The ERSA Minor and ERSA Minityp soldering irons are equipped with a (tubular leg-integrated) heating element housing which also functions as a return conductor for the heating element. Observe the potential relations during operation. Technical data: Rating: 16 W Heating time: appr. 60 s Sold. tip temperature: appr. 350°C/662°F Weight (without cable): 40 g / 1.4 oz Cable: 1.5 m / 4.9 ft PVC Voltage: 230 V Different voltages on request Order nos.: 260 BN Tip 260 sold. iron with 162 BN nickel-plated copper sold. tip and A 18 tool holder 260 BD Tip 260 soldering iron wih 162 BD long-life soldering tip and tool holder A 18 260 BD0028 Tip 260 soldering iron, though heat resistant cable 26100 Spare heating element for Tip 260
ERSA TIP 260 价格&库存
很抱歉,暂时无法提供与“ERSA TIP 260”相匹配的价格&库存,您可以联系我们找货
