3CA06-1001
3CA06-1001
    KURTZERSA
3CA06-1001 数据手册
Ersa EASY ARM 110 plus i Ersa solder fume extraction – compact, economic, powerful and energy efficient Technical Highlights: Efficient particle and gas filtration Connections for two flexible extraction arms, ø 55 mm Continuously adjustable suction power and automatic switch-off Optic and acoustic indication of low suction or end of filter lifetime Easy filter exchange 3 different types of universal extraction nozzles Interface to connect i-CON C soldering stations or a standby switch Ersa CLEAN-AIR systems – powerful, quiet, efficient and intelligent The intelligent filter unit Ersa EASY ARM EXTRACTION EA 110 plus i is a compact and powerful system to efficiently clean soldering process air at the workbench. Combined with up to two i-CON C or i-CON2 C soldering stations, connected with an interface cable, this filter system opens up a completely new dimension of intelligent solder fume filtration. The extraction unit is only working while at least one of the attached soldering stations is in operation. Do both i-CON units rest in the standby mode, the EA 110 plus i will automatically switch off. Filter usage times are increasing, energy costs and operation noise level will be significantly reduced to a minimum. The variable and easy to change mounting of the unit allows usage in any industrial environment. The solder fume filtration follows two stages: First a particle filter separates even floating particles from the process air. Activated carbon absorbs harmful gas molecules in the gas filter. A powerful blower guarantees a constant suction power during the entire filter lifetime. Due to its variable power control and high suction power, the unit can extract solder fume from up to two workbenches. Filtration efficiency is controlled by a time control (filter lifetime) and by suction power measurement. A necessary filter exchange is indicated by optic and acoustic signals. If the filter is clogged completely, the unit switches off automatically. Filter exchange is very easy to handle by only lifting the unit’s lid, changing the filter box and closing the system again. Solder fumes are known to be a big risk to health Arm extraction is most efficient and flexible Filtration of particles and gases is a must Very silent operation - for all environments Optional IR remote control Different extraction nozzles are available for various working conditions. Each extraction nozzle can easily be attached to the flexible extraction arm enabling the user to adapt the EA 110 plus i to any new working conditions within seconds. A very low noise level is another feature of this filter unit. Silent operation in a robust metallic case allows running the system in basically all industrial surroundings from electronic production to testing floor and laboratories. Long-life and robust metal housings for industrial use Remote control generates filter and energy savings Ersa EASY ARM 110 plus i Ersa solder fume extraction – compact, economic, powerful and energy efficient Technical Data: Dimensions (L x W x H): 460 x 210 x 470 mm Weight: 10 kg Extraction arms: ø 55 mm, length 0.7 m or 1 m Electrical data: 100 W / 100 - 250 V / 50 - 60 Hz Volume flow (free flowing / with new filter): 140 m³/h / 100 m³/h Vacuum: Noise level: Ordering information: Order Number 0CA08-002 Filter area: Ersa EASY ARM 110 plus i, complete, with i-CON C interface, for 2 extraction arms Separation degree: Spare parts and accessories: Description 3CA06-9001 Table clamp 3CA06-1001 Spare filter 3CA06-4001 Extraction arm with 700 mm flexible hose, with table mounting 3CA06-4002 Extraction arm with 1,000 mm flexible hose, to be installed directly at the filter unit 51 dB (A) max. Filter class of particle filter: Description Order Number 2,200 Pa Part H13 2.3 m² > 99.97 % (HEPA) Gas filter: activated carbon Order Number Description Part 3CA06-5001 Extraction nozzle metallic, ø 50 mm 3CA06-5002 Extraction nozzle 190 x 100 mm, ESD 3CA06-5004 Extraction nozzle “Plus” 215 x 90 mm, ESD 3CA06-9006 Shut-off valve 3CA08-3004 Interface cable set 3CA08-3005 Standby switch 0CA08-3006 Remote control Ersa soldering stations with interface: (optional) Order Number Description Order Number Description 0IC1100A0C Ersa i-CON 1 C 0ICV2000A (all versions) Ersa i-CON VARIO 2 0ICV4000A (all versions) Ersa i-CON VARIO 4 electronic temperature-controlled soldering station with interface, antistatic, 230/24 V, 80 W 0IC2000A0C Ersa i-CON 2 C electronic temperature-controlled double iron soldering station with interface, antistatic, 230/24 V, 150 W multi-channel soldering and desoldering station with interface, i-TOOL AIR S hot air iron and i-TOOL soldering iron for classical soldering applications or the new CHIP TOOL VARIO desoldering tweezers, antistatic, 230/24 V, 200 W multi-channel soldering and desoldering station for the operation of up to 4 tools (i-TOOL AIR S hot air iron, i-TOOL soldering iron, CHIP TOOL VARIO desoldering tweezers and X-TOOL desoldering iron), with interface, antistatic, 230/24 V, 500 W Subject to changes | 11/2012 © by Ersa GmbH Ersa GmbH Leonhard-Karl-Str. 24 97877 Wertheim Germany Tel. +49 9342 800-0 Fax +49 9342 800-127 info@ersa.de www.ersa.com France info@ersa-electronics.fr America info-ena@kurtzersa.com China info-eap@kurtzersa.com Just visit our homepage http//:www.ersa.com for further information! Korea kmc@kmckr.co.kr
3CA06-1001 价格&库存
很抱歉,暂时无法提供与“3CA06-1001”相匹配的价格&库存,您可以联系我们找货
3CA06-1001
  • 1+3597.443121+465.42530
