0WICKNC1.5/10
0WICKNC1.5/10
    KURTZERSA
0WICKNC1.5/10 数据手册
ACCESSORIES The ERSA Stacking Rack saves space by letting you stack two soldering stations safely on the workbench by means of the special recesses in the base plate and the rear wall. There is no danger of your ERSA soldering stations slipping. Save valuable workspace Order no.: STR 100 Stacking Rack (Delivery without soldering station) ERSA STR 100 Stacking Rack for soldering stations Specifications: Sn63Pb37; Sn60Pb40; Sn60Pb38Cu2; Sn62Pb36Ag2; Lead-free solder wire Sn96,5Ag3,5 and Tiffany solder wire Order nos.: see separate ERSA price list Dimensions: 0.6 mm (0.024 in); 0.8mm (0.031 in); 1.0 mm (0.039 in); 1.5 mm (0.059 in) and 2.0 mm (0.079 in) on 100 g (4 oz), 250 g (10 oz) and 500 g (20 oz) spool. 1.0 mm (0.039 in); 1.5 mm (0.059 in) and 2.0 mm (0.079 in) on 1,000 g(40 oz) spools. Other alloys, wire diameter, packing drumsizes and quantities on request. ERSA Solder wire Order nos: FMKANC 32-005 No-Clean flux core cream F-SW 32, DIN 8511, 5 ml cartridge on colophony basis, low activated, incl. tappet and 1 needle (plastic) diameter 0.4 mm (0.016 in) FMIF8001-PEN Flux-Pen with flux core IF 8001, FSW-34, DIN 8511, 7 ml FMIF 2005-001 Low solid No-Clean flux core IF 2005 M F-SW 34, DIN 8511, 100 ml (without picture) ERSA SMD solder paste / flux cream ERSA desoldering wicks are indispensable for effectively and gently removing flux and solder residue from SMD-boards in particular. Fine tissue, high capillarity and optimal flux content ensure optimal soldering results. Order nos.: No-Clean desold. wicks, 1.5 m (4.9ft) long WICK NC 1,5/10 1.5 mm (0.06 in) width (10 pieces) WICK NC 2,2/10 2.2 mm (0.09 in) width (10 pieces) WICK NC 2,7/10 2.7 mm (0.1 in) width (10 pieces) WICK-NC SET No-Clean desold.wicks consisting of WICK NC 1,5 (1 pcs), WICK NC 2,2 (2 pcs) and WICK NC 2,7 (1 pcs.) ERSA Desoldering wicks A must for every workbench 28 This ESD-safe tool allows for quick and reliable replacement of all internally heated ERSA soldering tips and the 422-type desoldering inserts. It incorporates an additional side cutter and screw driver allowing the multi-purpose use of this versatile tool. Order no.: 3ZT00164 Tip exchanger Crooked tweezers to grip components easily and safely. Order no.: 3ZT00165 Crooked tweezers ERSA Tip Exchanger / Tweezers
0WICKNC1.5/10 价格&库存
很抱歉,暂时无法提供与“0WICKNC1.5/10”相匹配的价格&库存,您可以联系我们找货
