ETHERLINE®
M12 Connectors
Ethernet Cable, Connectors & Tools
M12 Field Wireable Connectors
Male
Application Advantage
Female
• Shielded design
Technical Data
Temperature Range: Max. 85°C
Nominal Voltage: up to 60V
Part
Number
Number of
Positions
Screw
Connection
Max. Conductor
Cross-section Size
Male M12 Straight Connector, Screw Connection
C5E201C
18 AWG
8
PG 9
Female M12 Straight Connector, Screw Connection
C5E200C
8
PG 9
18 AWG
Nominal Current: up to 4A
Protection: IP67
Cable
Diameter (mm)
Min.
Max.
Nominal
Current
6
8
4A
6
8
4A
M12 CAT.6A Field Wireable Connectors
Technical Data
• Easy on-site assembly
• F or 10 Gbit/sec data transmission acc.
to CAT.6A
•C
an be used for Power over Ethernet
applications
• Robust and vibration resistant
Temperature Range: -40°C to +85°C
Nominal Voltage: 48V
Nominal Current: 0.5A
Contact Resistance: 100 mΩ
Approvals
Part
Number
Number of
Positions
Coding
Conductor Size
Stranded
Male M12 Straight Connector, Fast Connect
21700602
8
X
27 - 22 AWG (7 wire)
Solid
24 - 22 AWG
Cable Outer Diameter
(in)
(mm)
0.197 - 0.382
5.0 - 9.7
M12 Field Wireable Connectors for PROFINET®
Male
Technical Data
Female
Nominal Voltage: 250V
Nominal Current: 4A
Part
Number
Description
Number of
Positions
Male M12 Connectors, Fast Connect
C5E203C
Male Straight
4
C5E205C
Male 90°
4
Female M12 Connectors, Fast Connect
C5E202C
Female Straight
4
C5E204C
Female 90°
4
Coding
Screw
Connection
D
D
PG 9
PG 9
D
D
PG 9
PG 9
PROFINET® is a registered trademark of the PNO (PROFIBUS User Organization). If not otherwise specified, all values relating to the product are nominal values.
Photographs are not to scale and are not true representations of the products in question. For current information go to our website.
800-774-3539 • www.lappusa.com • www.lappcanada.com • www.lappmexico.com
255
EPIC®
Quick Select
Rectangular Connector Reference
Quick Select Summary: Housings
EPIC® HB Series Housings with Double Levers on Base
EPIC® HB Series Rectangular Connectors
PG
Description
NPT
HB 10
HB 16
Top Entry Hood with Double Lever Bolts
16
½”
100400
21
¾”
100401
100800
29
1”
100900
36 1¼”
Top Entry High Profile Hood with Double Lever Bolts
21
¾”
700504
701002
29
1”
700506
701004
Side Entry Hood with Double Lever Bolts
16
½”
100420
21
¾”
100421C0
100820
29
1”
100920
Side Entry High Profile Hood with Double Lever Bolts
21
¾”
700524
701022
29
1”
700526
701024
Panel Mount Base with Double Levers
100320C0
100720C0
Surface Mount Base with Double Levers
2 entries
16
½”
100350
1 entry
16
½”
100340
2 entries
21
¾”
100750
1 entry
21
¾”
100740
2 entries
29
1”
1 entry
29
1”
High Profile Surface Mount Base with Double Levers
2 entries
21
¾”
700362
700862
1 entry
21
¾”
700352
700852
2 entries
29
1”
700364
700864
1 entry
29
1”
700354
700854
Cable Coupler Hood with Double Levers
16
½”
100460
21
¾”
700402
100860
29
1”
100960C0
High Profile Cable Coupler Hood with Double Levers
21
¾”
700404R
29
1”
700406
700904
Complete with a PG SKINTOP® Cable Gland
HB 24
HB 32
Gray
Black
Metal
MS-SC
101210
101110
101330
101340
53015040
53015050
53015060
53015070
53015340
53015350
53015360
53015370
52015740
52015750
52015760
52015765
53112240
53112250
53112260
53112270
701504
701506
53015050
53015060
53015350
53015360
52015750
52015760
53112250
53112260
101130
101230
101350
101360
53015040
53015050
53015060
53015340
53015350
53015360
52015740
52015750
52015760
53112240
53112250
53112260
701524
701526
53015050
53015060
53015350
53015360
52015750
52015760
53112250
53112260
101020C0
101320C0
101050
101040
101380
101370
53015040
53015040
53015050
53015050
53015060
53015060
53015340
53015340
53015350
53015350
53015360
53015360
52015740
52015740
52015750
52015750
52015760
52015760
53112240
53112240
53112250
53112250
53112260
53112260
701362
701352
701364
701354
53015050
53015050
53015060
53015060
53015350
53015350
53015360
53015360
52015750
52015750
52015760
52015760
53112250
53112250
53112260
53112260
101270
101170
101390
101395
53015040
53015050
53015060
53015340
53015350
53015360
52015740
52015750
52015760
53112240
53112250
53112260
701404R
701406
53015050
53015060
53015350
53015360
52015750
52015760
53112250
53112260
For NPT parts: add “NP” to the end of 6-digit part numbers or replace the last two digits of an
8-digit part number with “NP”. Metric parts are also available.
EPIC® connectors mate with SKINTOP® glands without locknuts.
Use of tapered (NPT) threads is not recommended with EPIC®
rectangular connectors, unless a thread sealant is used.
EPIC® HA 3/4 Rectangular Connectors with Single Lever on Base
Complete with a SKINTOP® Cable Gland
PG
Gray
Black
Metal
MS-SC
11
53015020
53015320
52015720
53112220
Rectangular Hoods
PG with cable gland
Material
PG
NPT
Zinc Die Cast 11
Black Plastic 11
Gray Plastic 11
½”
½”
½”
Top Entry
Side Entry
Surface Mount Bases & Cable Coupler Hoods
NPT without cable gland
PG with cable gland
Top Entry
Base
Side Entry
Coupler
Base
Coupler
Panel Mount Bases
Standard
Angled
With Cover
10426500 10427500 105121NP 105123NP 10424500 10429500 105127NP 105129NP 10422500 10423500 44429015
10426700 10620600 104255NP 104273NP
10620300
104292NP 10422200 10423100
10426400 10427100 104260NP 104270NP 10424200 10429100 104240NP 104290NP 10422000 10423000
291
EPIC®
EPIC® HBE Series
Rectangular Connector Inserts
EPIC® HBE 16 Inserts
Screw-Terminated
view from cable side
Crimp-Terminated
crimp contacts sold
separately, see below
all dimensions are in mm.
Approvals: Screw & Crimp
Screwless Cage Clamp
Approvals: Cage Clamp
Compatible Housing
Description
EPIC® HB 16
page 381
Screw-Terminated with Wire Protection
Screw-Terminated without Wire Protection
Crimp-Terminated: Machined Contacts
Plug
Receptacle
10194000
10194100
10184000
10400200
10195000
10195100
10185000
10401200
Machined Contacts
2.5 mm Diameter
Contact Size
mm2
AWG
0.5
0.75 - 1.0
1.5
2.5
4.0
16
14
12
Stripping Length
(mm)
Pin
Socket
7.4
7.4
7.4
7.4
7.4
# of
Marking
Tracks
Silver Contacts
Pin
Gold Contacts
Socket
7.3
11190000 11195000
7.3
1
11190100
11195100
7.3
2
11190200 11195200
7.3
3
11190300 11195300
7.3
11190400 11195400
part number = 1 contact, sold in bags of 100
Pin
Socket
11192000
11192100
11192200
11197000
11197100
11197200
Complete the Installation
Crimp Tool:
11147000
Crimp Dies:
11147100
Locator:
11147200
For removal of contacts, use a slotted screwdriver;
no special tool is necessary.
If not otherwise specified, all values relating to the product are nominal values. For current information go to our website.
301
EPIC®
EPIC® HBE Series
EPIC® HBE 24 Inserts
Screw-Terminated
Crimp-Terminated
crimp contacts sold
Compatible Housing
Description
EPIC® HB 24
page 387
Plug
Receptacle
10196000
10196100
10186000
10400300
10197000
10197100
10187000
10401300
Machined Contacts
2.5 mm Diameter
Contact Size
mm2
AWG
0.5
0.75 - 1.0
1.5
2.5
4.0
16
14
12
Stripping Length
(mm)
Pin
Socket
7.4
7.4
7.4
7.4
7.4
# of
Marking
Tracks
Silver Contacts
Pin
Gold Contacts
Socket
7.3
11190000 11195000
7.3
1
11190100
11195100
7.3
2
11190200 11195200
7.3
3
11190300 11195300
7.3
11190400 11195400
Pin
Socket
11192000
11192100
11192200
11197000
11197100
11197200
Crimp Tool:
11147000
Crimp Dies:
11147100
Locator:
11147200
303
EPIC®
Rectangular Connector Housings
HB Series
EPIC® HB 16 Standard Hoods
Double Lever Bolts
Technical Data
PG
Specifications: DIN 43652
Protection Class: NEMA 4, NEMA 12, IP65
Temperature Range: -40°C to + 125°C
Material: Powder-coated aluminum alloy
Size of Entry
NPT
Metric
PG
Part Number
NPT
Complete the Installation: SKINTOP® Strain Relief
PG Plastic
PG Metal
Metric Plastic
Metric Metal
Metric
Top Entry
21
¾”
25
100800
100800NP 19080000*
25x2
19080500
29
1”
32
100900
100900NP 19090000*
Side Entry
21
¾”
25
100820
100820NP 19082000
29
1”
32
100920
100920NP 19092000
* Metric top-entry hoods do not come with a neck.
53015050
53015060
52015750
52015760
53111030
53111030
53111040
53112030
53112030
53112040
53015050
53015060
52015750
52015760
53111030
53111040
53112030
53112040
Approvals
HB Dust Covers
page 419
EPIC® HB 16 High Profile Hoods
Double Lever Bolts
Technical Data
PG
Size of Entry
NPT
Metric
PG
Part Number
NPT
Top Entry
21
¾”
25
701002
701002NP
25x2
29
1”
32
701004R 701004NP
32x2
40
Side Entry
21
¾”
25
701022
701022NP
29
1”
32
701024
701024NP
40
* Metric hoods do not come with a neck.
PG Plastic
PG Metal
Metric Plastic
Metric Metal
Metric*
79100200
44422018
79100400
79128600
79100800
53015050
53015060
52015750
52015760
53111030
53111030
53111040
53111040
53111050
53112030
53112030
53112040
53112040
53112050
79102200
79102400
79102800
53015050
53015060
52015750
52015760
53111030
53111040
53111050
53112030
53112040
53112050
Approvals
HB Dust Covers
page 419
384
EPIC®
HB Series
EPIC® HB 16 Panel Mount Bases
Double Levers
Technical Data
Description
Approvals
Part Number
Panel Mount Base
100720C0
HB Dust Covers
page 419
EPIC® HB 16 Surface Mount Bases
Double Levers
Technical Data
PG
Size of Entry
NPT
Metric
2 Entries
21
¾”
1 Entry
21
¾”
PG
Part Number
NPT
Metric
PG Plastic
PG Metal
Metric Plastic
Metric Metal
25
100750
100750NP
19075000
53015050
52015750
53111030
53112030
25
100740
100740NP
19074000
53015050
52015750
53111040
53112030
Approvals
HB Dust Covers
page 419
385
EPIC®
HB Series
EPIC® HB 24 Standard Hoods
Double Lever Bolts
Technical Data
PG
Size of Entry
NPT
Metric
PG
Part Number
NPT
PG Plastic
PG Metal
Metric Plastic
Metric Metal
Metric
Top Entry
21
¾”
25
101210
101210NP 19121000*
25x2
44422019
29
1”
32
101110
101110NP 19111000*
32x2
44422020
Side Entry
21
¾”
25
101130
101130NP 19113000
29
1”
32
101230
101230NP 19123000
Approvals
53015050
53015060
52015750
52015760
53111030
53111030
53111040
53111040
53112030
53112030
53112040
53112040
53015050
53015060
52015750
52015760
53111030
53111040
53112030
53112040
HB Dust Covers
page 419
EPIC® HB 24 High Profile Hoods
Double Lever Bolts
Technical Data
PG
Size of Entry
NPT
Metric
PG
Part Number
NPT
Top Entry
21
¾”
25
701504
701504NP
25x2
29
1”
32
701506
701506NP
32x2
40
Side Entry
21
¾”
25
701524
701524NP
29
1”
32
701526
701526NP
40
PG Plastic
PG Metal
Metric Plastic
Metric Metal
Metric*
79150400
44422021
79150600
79178500
79150800
53015050
53015060
52015750
52015760
53111030
53111030
53111040
53111040
53111050
53112030
53112030
53112040
53112040
53112050
79152400
79152600
79152800
53015050
53015060
52015750
52015760
53111030
53111040
53111050
53112030
53112040
53112050
Approvals
HB Dust Covers
page 419
390
EPIC®
HB Series
EPIC® HB 24 Panel Mount Bases
Double Levers
Technical Data
Description
Approvals
Part Number
Panel Mount Base
101020C0
HB Dust Covers
page 419
EPIC® HB 24 Surface Mount Bases
Double Levers
Technical Data
PG
Size of Entry
NPT
Metric
2 Entries
21
¾”
1 Entry
21
¾”
PG
Part Number
NPT
Metric
PG Plastic
PG Metal
Metric Plastic
Metric Metal
25
101050
101050NP
19105000
53015050
52015750
53111030
53112030
25
101040
101040NP
19104000
53015050
52015750
53111040
53112030
Approvals
HB Dust Covers
page 419
391
EPIC®
POWER LS1 Series
Circular Connectors
EPIC® POWER LS1 Connector Style A3
Angled Rotatable Panel Mount Inlet with Male Contacts
3+PE+4
5+PE
Crimp Tool:
11148000
Removal Tool:
1 mm contacts:75017400
2 mm contacts:75017500
Locator:
11148300
Contact
Configuration
Part Number
5+PE
3+PE+4
24420058
24420056
EPIC® POWER LS1 Connector Style A6
Panel Mount Receptacle with Female Contacts
3+PE+4
5+PE
Crimp Tool:
11148000
Contact
Configuration
Part Number
5+PE
3+PE+4
76083000
76084000
Locator:
11148300
EPIC® POWER LS1 Connector Style D6
Cable Connector with Female Contacts
Short Body
3+PE+4
Short Body
5+PE
Standard Body
3+PE+4
Standard Body
5+PE
Crimp Tool:
11148000
Locator:
11148300
Contact
Configuration
5+PE
3+PE+4
Standard Body
20 - 14 AWG
12 AWG
Short Body
76123000
76124000
76123100
76124100
44420091
44420089
433
EPIC®
Pin & Sleeve Connectors
North American Standard
30A Pin & Sleeve Connectors
Male plugs mate with female connectors, panel-mounted receptacles, and switched-socket outlets. Male inlets mate with female connectors.
Dimensional drawings can be found on the indicated pages and are the same for North American and international standards.
Circuit wiring diagrams can be found on page 484. Additional configurations are available: see www.lappusa.com for a complete listing.
IP44
IP67
Male Plugs & Inlets
Dimensional Data
Plugs: page 467
Inlets: page 468
Color
Code
30A
Voltage /
Current Rating
Number
of Wires
Number
of Poles
Ground-Clock
Position
125
250
3Ø 250
3Ø 480
3Ø Y 120/208
3
3
4
4
5
1+N+PE
2+PE
3+PE
3+PE
3+N+PE
4
6
9
7
9
IP67
IP44
Male Plugs
477206FX
477306FX
477316FX
477516FX
477326FX
IP67
Male Inlets
476206FX
476306FX
476316FX
476516FX
476326FX
700224FX
700226FX
700239FX
700237FX
700249FX
Female Connectors
& Receptacles
Dimensional Data
Connectors: page 468
Receptacles: page 469
Color
Code
30A
Voltage /
Current Rating
Number
of Wires
Number
of Poles
Ground-Clock
Position
125
250
3Ø 250
3Ø 480
3Ø Y 120/208
3
3
4
4
5
1+N+PE
2+PE
3+PE
3+PE
3+N+PE
4
6
9
7
9
IP67
IP44
Female Connectors
473206FX
473306FX
473316FX
473516FX
473326FX
IP67
720224FX
720226FX
720239FX
720237FX
720249FX
Female Receptacles
471267FX
471367FX
471377FX
471577FX
471387FX
IP44
IP44
433211FX
433222FX
443222FX
443250FX
453222FX
471266FX
471366FX
471376FX
471576FX
471386FX
Switched-Socket Outlets
Dimensional Data
page 470
Color
Code
30A
458
Voltage /
Current Rating
Number
of Wires
Number
of Poles
Ground-Clock
Position
125
250
3Ø 250
3Ø 480
3Ø Y 120/208
3
3
4
4
5
1+N+PE
2+PE
3+PE
3+PE
3+N+PE
4
6
9
7
9
with Fuse Holder
IP66/67
EPIC® ULYSSE
400224FX
400226FX
400239FX
400237FX
400249FX
Direct Connect
IP67
EPIC® ALUPRES
460224FX
460226FX
460239FX
460237FX
460249FX
很抱歉,暂时无法提供与“10196000”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+245.57911
- 12+240.85123
- 25+236.34204
- 国内价格 香港价格
- 1+304.883161+38.13390
- 10+259.1419910+32.41273
- 25+242.9248225+30.38433
- 50+231.3336150+28.93454
- 100+220.30140100+27.55466
- 250+206.52631250+25.83171
- 国内价格 香港价格
- 1+287.294831+35.93400
- 10+249.3502310+31.18800
- 25+233.7206725+29.23310
- 50+222.6083250+27.84320
- 国内价格
- 1+238.21653
- 15+226.38641
- 50+219.63824
