ETHERLINE®
RJ45 Plugs & Receptacles
Ethernet Cable, Connectors & Tools
RJ45 CAT.6A Industry 10G Connectors
Application Advantage
Approvals
• Suitable for solid and stranded conductors
• Nickel-plated brass housing
• Supports 10 Gigabit Ethernet
• Provides IP68 protection
• Conforms to IEC 60603-7-51
Part
Number
RJ45 Plug
21700630
21700631
RJ45 Receptacle
21700632
21700633
Conductor Size
Description
Cable Outer Diameter
(in)
(mm)
Standard
Pack
Stranded
Solid
Inclusive RJ45 Connector
Dust Cap
27 - 22 AWG (7 wire)
24 - 22 AWG
0.197 - 0.355
5-9
1
10
Inclusive RJ45 Connector acc. to T568B
Dust Cap
26 - 22 AWG
0.197 - 0.355
5-9
1
10
RJ45 90° CAT.5e
• Die-cast zinc housing
• Suitable for PROFINET® applications
Approvals
Part
Number
RJ45 90°
21700638
Conductor Size
Stranded
Solid
24 - 22 AWG
(in)
(mm)
0.217 - 0.394
5.5 - 10
Standard
Pack
1
RJ45 90° CAT.6A
Approvals
Part
Number
Conductor Size
Stranded
RJ45 90° CAT.6A
21700636
21700639
26 AWG (19 wire)
21700637
21700640
26 AWG (19 wire)
Solid
Color
Code
24 - 22 AWG
26 - 24 AWG
24 - 22 AWG
26 - 24 AWG
T568A
T568A
T568B
T568B
(in)
(mm)
0.217 - 0.394
0.217 - 0.394
0.217 - 0.394
0.217 - 0.394
5.5 - 10.0
5.5 - 10.0
5.5 - 10.0
5.5 - 10.0
Standard
Pack
1
1
1
1
PROFINET® is a registered trademark of the PNO (PROFIBUS User Organization). If not otherwise specified, all values relating to the product are nominal values.
Photographs are not to scale and are not true representations of the products in question. For current information go to our website.
800-774-3539 • www.lappusa.com • www.lappcanada.com • www.lappmexico.com
253
很抱歉,暂时无法提供与“21700636”相匹配的价格&库存,您可以联系我们找货
