ÖLFLEX®
Tray-Rated Cable
ÖLFLEX® TRAY II/TRAY II CY
Extremely Oil-Resistant & Flexible Tray Cable with UL & CSA; Unshielded & Shielded
Unshielded Construction
LAPP KABEL
Conductors: Finely stranded bare copper
ÖLFLEX TRAY II
Insulation: Specially formulated PVC/nylon
LAPP KABEL
Jacket: Specially formulated thermoplastic polymer; black
ÖLFLEX® TRAY II CY
ÖLFLEX® TRAY II is an industrial grade tray cable with superior oil performance
for long cable life. It has a pressure-extruded jacket and fine copper stranding
for excellent flexibility, making it much easier to pull through tray. With UL
TC-ER approval, no conduit is needed so you can reduce material costs along
with saving on labor. ÖLFLEX® TRAY II CY is designed with foil tape and tinned
copper braid shield for improved effectiveness.
Shielded Construction
Shielding: Foil tape; tinned copper braid (70% coverage)
Recommended Applications
Industrial plant expansions; automotive plants; tray wiring; anywhere VNTC®
cables are used
Approvals
Application Advantage
•O
il-resistant pressure-extruded jacket improves flexibility
• E asier to pull than standard tray cables; lower labor costs
•U
L TC-ER reduces material costs; no conduit is needed
• Black numbered conductors for easy identification
• Improved shielding effectiveness
F
IRE
PROTECTION
Cable Attributes
OIL
MOTION
page 640
OR-03
FLAME
FR-03
WT-02
MECH.
MP-03
Complete the Installation
SKINTOP®
Strain Relief
page 488
EPIC®
Connectors
page 280
Technical Data
Minimum Bend Radius:
- for installation:
- < 1 AWG: 4 x cable diameter
- ≥ 1 AWG: 6 x cable diameter
- shielded: 6 x cable diameter
Temperature Range:
- UL/CSA TC: -25°C to +90°C
- for stationary use: -40°C to +105°C
- for flexible use: -25°C to +105°C
Nominal Voltage:
- UL/CSA TC: 600V
- UL WTTC/CSA AWM: 1000V
Test Voltage:
- up to 1 AWG: 2000V
- 1 AWG & larger: 4000V
Conductor Stranding:
- 18 - 6 AWG: Class 5 fine wire*
- 4 - 2 AWG: Class K fine wire
- 1 AWG - 500 KCMIL: Stranded wire
* 18 AWG meets only Class 5 cross section and DC resistance
Color Code: Black with white printing,
plus green/yellow ground
Approvals:
UL: TC-ER per UL 1277
MTW per UL 1063
WTTC per UL 2277
Submersible Pump (14 - 2 AWG)
PLTC-ER per UL 13 (18 - 12 AWG)
ITC-ER per UL 2250 (18 - 12 AWG)
DP-1 per UL 1690
AWM 20886 (18 - 2 AWG)
Attributes: UL Oil Res I/II
75°C Wet; 90°C Dry
Sunlight Resistant
Direct Burial
NFPA 79
NEC: Class 1 Division 2 per NEC Article 501
Canada: c(UL) CIC/TC FT4 (18 - 4/0 AWG)
CSA AWM I/II A/B FT4
Additional: Torsion Rated for Wind Market
(± 90°/m) & (± 150°/m)
(18 - 2 AWG)
CE & RoHS
MSHA: P-07-KA050016-MSHA
(shielded only)
VNTC® is a registered trademark of General Cable. ECOLAB® is a registered trademark of Ecolab, Inc.
If not otherwise specified, all values relating to the product are nominal values.
Photographs are not to scale and are not true representations of the products in question. For current information go to our website.
56
800-774-3539 • www.lappusa.com • www.lappcanada.com • www.lappmexico.com
ÖLFLEX®
Tray-Rated Cable
ÖLFLEX® TRAY II
Part
Number
Number of
Conductors
(incl. ground)
Nominal Outer
Diameter
(in)
(mm)
Copper
Weight
(lbs/mft)
18 AWG (1.00 mm2)
221803
3
0.297
7.5
4
0.320
8.1
26
221805
5
0.346
8.8
33
221807
7
0.373
9.5
46
221809
9
0.429
10.9
59
221812
12
0.477
12.1
79
221818
18
0.587
14.9
118
221825
25
0.664
16.9
164
221850
50
0.939
23.9
303
16 AWG (1.50 mm2)
221603
3
0.325
8.3
29
221604
4
0.351
8.9
39
221605
5
0.381
9.7
49
221607
7
0.412
10.5
68
221608
8
0.444
11.3
78
221609
9
0.476
12.1
88
221612
12
0.565
14.4
117
221616
16
0.621
15.8
155
221618
18
0.652
16.6
175
221625
25
0.741
18.8
242
221634
34
0.904
23.0
296
221641
41
0.986
25.0
357
221650
50
1.048
26.6
436
221661
61
1.085
27.6
533
14 AWG (2.50 mm2)
221403
3
0.362
9.2
49
221404
4
0.392
10.0
65
221405
5
0.427
10.8
81
221407
7
0.463
11.8
113
221409
9
0.571
14.5
146
221412
12
0.636
16.2
194
221418
18
0.737
18.7
290
221425
25
0.886
22.5
404
12 AWG (4 mm2)
221203
3
0.423
10.7
78
221204
4
0.460
11.7
104
221205
5
0.503
12.8
129
221207
7
0.581
14.8
181
* SKINTOP® MS-M: nickel-plated brass with metric thread.
Approx.
Weight
(lbs/mft)
SKINTOP®
Non-Metallic
PG Thread
57
66
77
99
112
172
245
322
646
S2111
S2111
S2111
S2111
S2113
S2116
S2121
S2121
S2129
68
84
99
128
137
172
220
271
289
397
540
626
760
771
S2111
S2111
S2113
S2113
S2113
S2116
S2121
S2121
S2121
S2129
S2129
S2136
S2136
S2136
88
106
128
170
225
309
439
586
S2111
S2113
S2113
S2116
S2121
S2121
S2129
S2129
126
152
187
258
S2113
S2113
S2116
S2121
Part
Number
Number of
Conductors
(incl. ground)
10 AWG (6 mm2)
221003
3
221004
4
221005
5
221007
7
8 AWG (10 mm2)
220804
4
220805
5
2
6 AWG (16 mm )
220603
3
220604
4
220605
5
4 AWG (21 mm2)
220403
3
220404
4
2
2 AWG (33.7 mm )
220203
3
220204
4
1 AWG (42.5 mm2)
220104
4
1/0 AWG (53.7 mm2)
221104
4
2/0 AWG (67.7 mm2)
222204
4
3/0 AWG (85.3 mm2)
223304
4
4/0 AWG (107.6 mm2)
224404
4
250 KCMIL (127.1 mm2)
222504
4
350 KCMIL (177.9 mm2)
223504
4
500 KCMIL (254.1 mm2)
225004
4
Nominal Outer
Diameter
(in)
(mm)
Copper
Weight
(lbs/mft)
Approx.
Weight
(lbs/mft)
SKINTOP®
Non-Metallic
PG Thread
0.498
0.578
0.631
0.686
12.6
14.7
16.0
17.4
117
155
194
271
218
264
317
445
S2116
S2121
S2121
S2129
0.703
0.772
17.9
19.6
258
323
384
518
S2129
S2129
0.776
0.899
0.982
19.7
22.8
24.9
310
413
517
454
580
725
S2129
S2129
S2136
0.999
1.094
25.3
27.8
386
544
919
952
S2136
S2136
1.155
1.272
29.3
32.3
658
859
1085
1320
S2136
S2248
1.323
33.6
1033
1780
S2142
1.419
36.0
1337
2035
S2148
1.540
39.1
1602
2475
S2148
1.757
44.6
2000
3015
S2148
1.901
48.3
2503
3835
53112080*
2.084
52.9
3105
4405
53112511*
2.241
56.9
4602
5995
53112510*
2.694
68.4
5649
6216
53112512*
ÖLFLEX® TRAY II CY
Part
Number
Number of
Conductors
(incl. ground)
18 AWG (1.00 mm2)
2218030
3
2218040
4
2218050
5
2218070
7
2218120
12
2218180
18
2218250
25
16 AWG (1.50 mm2)
2216030
3
2216040
4
2216050
5
2216070
7
2216120
12
2216180
18
2216250
25
14 AWG (2.50 mm2)
2214030
3
2214040
4
2214050
5
2214070
7
2214120
12
2214180
18
2214250
25
Nominal Outer
Diameter
(in)
(mm)
Copper
Weight
(lbs/mft)
Approx.
Weight
(lbs/mft)
SKINTOP®
MS-SC
PG Thread
0.322
0.346
0.371
0.398
0.508
0.618
0.695
8.2
8.8
9.4
10.1
12.9
15.7
17.7
29
38
45
59
101
145
238
79
93
99
130
223
295
386
53112220
53112220
53112230
53112230
53112240
53112250
53112260
0.350
0.376
0.406
0.443
0.596
0.683
0.772
8.9
9.6
10.3
11.3
15.1
17.3
19.6
41
51
63
88
144
210
280
97
117
128
165
287
346
430
53112220
53112230
53112230
53112240
53112250
53112260
53112260
0.387
0.423
0.458
0.494
0.667
0.768
0.917
9.8
10.7
11.6
12.5
16.9
19.5
23.3
62
85
101
136
225
328
461
121
150
181
220
399
527
705
53112230
53112230
53112240
53112240
53112250
53112260
53112260
Part
Number
Number of
Conductors
(incl. ground)
12 AWG (4 mm2)
2212040
2212050
2212070
10 AWG (6 mm2)
2210040
2210050
2210070
8 AWG (10 mm2)
2208040
6 AWG (16 mm2)
2206040
4 AWG (21 mm2)
2204040
2 AWG (33.7 mm2)
2202040
Nominal Outer
Diameter
(in)
(mm)
Copper
Weight
(lbs/mft)
Approx.
Weight
(lbs/mft)
SKINTOP®
MS-SC
PG Thread
4
5
7
0.491
0.568
0.612
12.5
14.4
15.5
126
157
209
212
260
335
53112240
53112250
53112250
4
5
7
0.609
0.662
0.717
15.5
16.8
18.2
183
224
308
370
412
575
53112250
53112250
53112260
4
0.737
18.7
295
575
53112260
4
0.918
23.3
470
811
53112260
4
1.127
28.6
579
1331
53112270
4
1.309
33.2
950
1951
53112670*
* SKINTOP® MS-SC with metric thread.
Recommended SKINTOP® assumes minimal OD variance. Additional configurations are available; please see our SKINTOP® section.
If not otherwise specified, all values relating to the product are nominal values. For current information go to our website.
57
很抱歉,暂时无法提供与“221404”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+64.859661+8.42980
- 10+58.9475210+7.66140
- 25+53.0353825+6.89300
- 50+47.4710150+6.16980
- 100+41.29804100+5.36750
- 国内价格 香港价格
- 2500+16.853172500+2.19041
- 5000+15.990245000+2.07825
- 国内价格 香港价格
- 1+748.102151+97.23073
