761004
761004
    LAPP(缆普)
    4 芯 多芯 线缆 黑色 10 AWG 箔,编织线 在订单数量中输入英尺数
761004 数据手册
ÖLFLEX® Flexible Cable for Drives, Motors & Assemblies VFD Cable ÖLFLEX® VFD SLIM Reduced-Diameter VFD Cable; 600V/1000V; UL & c(UL) TC-ER Approval Construction LAPP KABEL ÖLFLEX® VFD SLIM Conductors: Finely stranded tinned copper ÖLFLEX® VFD SLIM is a reduced-diameter shielded motor cable for VFD drives. It is designed with the Lapp Surge Guard insulation system, which includes a semiconductive layer made to withstand nonlinear power distortions associated with VFD drives and to disperse increases in voltage caused by wave reflection, spikes, in-rush current, and harmonics. Insulation: Lapp Surge Guard insulation system Shielding: Barrier tape; triple layer foil tape (100% coverage); tinned copper braid (85% coverage) Jacket: Specially formulated thermoplastic polymer; black Application Advantage Recommended Applications VFD drive and motor applications; web presses; HVAC; conveyors; any on/off, slow down/speed up applications using VFD drives and motors • Lapp Surge Guard insulation protection • UL TC-ER & c(UL) CIC/TC approved • Double shielded for extra protection • Resistant to a wide range of disinfecting solutions used in the food, beverage, chemical and related industries, according to ECOLAB® PM 40-1 test procedure Approvals F IRE PROTECTION Cable Attributes OIL MOTION page 640 OR-03 FLAME FR-03 FL-01 MECH. MP-03 Complete the Installation SKINTOP® MS-SC page 516 EPIC® ULTRA HB page 397 Technical Data Minimum Bend Radius: 7.5 x cable diameter Temperature Range: - UL/CSA TC: -25°C to +90°C - for stationary use: -40°C to +105°C - for flexible use: -25°C to +105°C Nominal Voltage: - UL/CSA TC: - UL WTTC: - UL Flexible Motor Supply: - UL/CSA AWM: Color Code: Black with white numbers, plus green/yellow ground Approvals: UL: TC-ER per UL 1277 MTW per UL 1063 WTTC per UL 2277 AWM 20886 Attributes: UL Oil Res I/II 75°C Wet; 90°C Dry -40°C Cold Bend; -25° Cold Impact Sunlight Resistant Submersible Pump (14 AWG & larger) Direct Burial NFPA 79 NEC: Class 1 Division 2 per NEC Article 501 Canada: c(UL) CIC/TC FT4 CSA AWM I/II A/B 1000V FT4 Additional: MSHA P-07KA050013-MSHA CE & RoHS 600V 1000V 1000V 1000V Test Voltage: 2000V Peak Voltage: 7500V Conductor Stranding: - 18 - 6 AWG: Class 5 fine wire* - 4 - 2 AWG: Class K fine wire * 18 AWG meets only Class 5 cross section and DC resistance Part Number Number of Conductors (incl. ground) Nominal Outer Diameter (in) (mm) 18 AWG (1.00 mm2) 761804 4 0.394 16 AWG (1.5 mm2) 761604 4 + drain 0.465 14 AWG (2.5 mm2) 761404 4 0.514 12 AWG (4 mm2) 761204 4 0.583 10 AWG (6 mm2) 761004 4 0.697 Copper Approx. Weight Weight (lbs/mft) (lbs/mft) SKINTOP® MS-SC PG Thread SKINTOP® MS-M BRUSH Metric Thread 10.0 53 112 53112230 — 11.8 73 154 53112240 53112676 13.1 100 194 53112240 53112676 14.8 139 254 53112250 53112676 17.7 195 346 53112260 53112677 Part Number Number of Conductors (incl. ground) 8 AWG (10 mm2) 760804 4 6 AWG (16 mm2) 760604 4 4 AWG (21 mm2) 760404 4 2 AWG (33.7 mm2) 760204 4 Nominal Outer Diameter (in) (mm) Copper Approx. Weight Weight (lbs/mft) (lbs/mft) SKINTOP® MS-SC PG Thread SKINTOP® MS-M BRUSH Metric Thread 0.829 21.1 326 596 53112260 53112678 1.002 25.5 494 785 53112270 53112678 1.186 30.1 648 965 53112270 53112679 1.395 35.4 985 1339 — 53112680 ECOLAB® is a registered trademark of Ecolab, Inc. Recommended SKINTOP® assumes minimal OD variance. Additional configurations are available; please see our SKINTOP® section. If not otherwise specified, all values relating to the product are nominal values. Photographs are not to scale and are not true representations of the products in question. For current information go to our website. 96 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com
761004 价格&库存
很抱歉,暂时无法提供与“761004”相匹配的价格&库存,您可以联系我们找货
  • 1+133.060551+17.29079
