UNITRONIC®
Flexible Data, Signal & Control Cable
Flexible UL/CSA Electronic Cable
UNITRONIC® 300/300 S
Multi-Conductor, 300V Flexible Industrial Signal & Control Cable; Unshielded & Shielded
Control cable (20 AWG - 16 AWG)
Unshielded Construction
LAPP KABEL
UNITRONIC 300
LAPP KABEL
UNITRONIC® 300 S
Conductors: Finely stranded tinned copper
Insulation: Blended PVC
Jacket: Specially formulated PVC; gray
Signal cable (24 AWG - 22 AWG)
LAPP KABEL
UNITRONIC® 300
LAPP KABEL
UNITRONIC® 300 S
Shielded Construction
UNITRONIC® 300/300 S is a rugged, multi-conductor, low voltage control and
signal cable for internal and external wiring of OEM equipment for industrial
applications. The jacket is very oil resistant and is pressure-extruded for
improved flexibility and easier installation. UNITRONIC® 300 S has a foil tape
and tinned copper braid shield for maximum RFI & EMI protection.
Shielding: Tri-laminate foil shield and tinned copper braid
(75% coverage); drain wire
Application Advantage
Recommended Applications
Process control; electrical equipment; industrial machinery; low-voltage
control interconnect
Approvals
Cable Attributes
page 640
OIL
OR-02
FLAME
FR-03
MOTION
WT-02
MECH.
MP-02
• Extended temperature rating of -40°C to +105°C
• Flexible design for ease of routing
• Suitable for use in cable tray
• Oil- and UV-resistant jacket (Oil Res I)
• Sequential foot marking for ease of installation
Complete the Installation
SKINTOP®
Strain Relief
page 488
EPIC®
Connectors
page 280
Technical Data
Minimum Bend Radius:
- for installation: 4 x cable diameter
- shielded: 6 x cable diameter
Temperature Range:
- for stationary use: -40°C to +105°C
- for flexible use: -25°C to +105°C
Nominal Voltage: 300V
Test Voltage: 1500V
Conductor Stranding: Fine wire
Color Code:
- 24 - 22 AWG: Chart 4, page 673
- 20 - 16 AWG: Chart 5, page 673
Approvals:
UL:
Attributes:
NEC:
Canada:
Additional:
CMG per UL 444
PLTC-ER per UL 13
ITC-ER per UL 2250
AWM 2464
UL Oil Res I
-40°C Cold Bend; -25°C Cold Impact
Sunlight Resistant
Direct Burial
NFPA 79
Meets NEC Art. 725 & 800
Class 1 Division 2 (PLTC only)
cUL CMG FT4
CSA AWM I/II A/B FT1
24 AWG is not PLTC
18 & 16 AWG rated PLTC-ER & ITC-ER
CE & RoHS
If not otherwise specified, all values relating to the product are nominal values. Photographs are not to scale and are not true representations of the products in question.
For current information go to our website.
204
800-774-3539 • www.lappusa.com • www.lappcanada.com • www.lappmexico.com
UNITRONIC®
UNITRONIC® 300
Part
Number
Number of
Conductors
24 AWG (0.24 mm2)
302402
2
302403
3
302404
4
302406
6
302408
8
302410
10
302415
15
302420
25
22 AWG (0.38 mm2)
302202
2
302203
3
302204
4
302206
6
302208
8
302210
10
302215
15
302220
25
20 AWG (0.62 mm2)
302002
2
302003
3
302004
4
302006
6
302008
8
302010
10
302015
15
302020
25
Nominal Outer
Diameter
(in)
(mm)
Copper
Weight
(lbs/mft)
Approx.
Weight
(lbs/mft)
SKINTOP®
Non-Metallic
PG Thread
0.165
0.172
0.183
0.209
0.223
0.253
0.284
0.321
0.355
4.2
4.4
4.6
5.3
5.7
6.4
7.2
8.2
9.0
3
5
6
9
12
15
23
30
38
13
15
18
22
29
35
46
57
71
S1107
S1107
S1107
S1107
S1107
S1109
S1111
S1111
S1111
0.179
0.187
0.200
0.229
0.245
0.289
0.324
0.355
0.414
4.5
4.7
5.1
5.8
6.2
7.3
8.2
9.0
10.5
5
7
10
15
19
24
36
47
59
15
31
37
44
62
99
126
S1107
S1107
S1107
S1107
S1107
S1111
S1111
S1111
S1113
0.225
0.237
0.256
0.308
0.331
0.381
0.452
0.497
0.554
5.7
6.0
6.5
7.8
8.4
9.7
11.5
12.6
14.1
8
12
15
23
30
38
57
76
94
37
40
51
66
90
97
121
174
238
S1107
S1107
S1109
S1111
S1111
S1113
S1113
S1116
S1121
Part
Number
Number of
Conductors
18 AWG (1.00 mm2)
301802
2
301803
3
301804
4
301806
6
301808
8
301810
10
301815
15
301820
25
16 AWG (1.32 mm2)
301602
2
301603
3
301604
4
301606
6
301608
8
301610
10
301615
15
301620
25
Nominal Outer
Diameter
(in)
(mm)
Copper
Weight
(lbs/mft)
Approx.
Weight
(lbs/mft)
SKINTOP®
Non-Metallic
PG Thread
0.241
0.254
0.285
0.333
0.358
0.437
0.494
0.544
0.629
6.1
6.5
7.2
8.5
9.1
11.1
12.5
13.8
16.0
12
18
24
36
47
61
91
121
151
42
44
53
68
95
130
165
220
276
S1107
S1109
S1111
S1111
S1111
S1113
S1116
S1121
S1121
0.263
0.288
0.312
0.366
0.417
0.481
0.546
0.603
0.696
6.7
7.3
7.9
9.3
10.6
12.2
13.9
15.3
17.7
17
25
33
49
65
82
122
163
204
55
60
75
110
163
181
242
331
410
S1109
S1111
S1111
S1111
S1113
S1116
S1121
S1121
S1129
UNITRONIC® 300 S
Part
Number
Number of
Conductors
24 AWG (0.24 mm2)
302402S
2
302403S
3
302404S
4
302406S
6
302408S
8
302410S
10
302415S
15
302420S
302425S
25
22 AWG (0.38 mm2)
302202S
2
302203S
3
302204S
4
302206S
6
302208S
8
302210S
10
302215S
15
302220S
302225S
25
20 AWG (0.62 mm2)
302002S
2
302003S
3
302004S
4
302006S
6
302008S
8
302010S
10
302015S
15
302020S
302025S
25
Nominal Outer
Diameter
(in)
(mm)
Copper
Weight
(lbs/mft)
Approx.
Weight
(lbs/mft)
SKINTOP®
MS-SC
PG Thread
0.193
0.201
0.209
0.236
0.248
0.280
0.311
0.346
0.382
4.9
5.1
5.3
6.0
6.3
7.1
7.9
8.8
9.7
10
12
14
18
22
26
35
44
53
19
22
26
31
37
44
60
71
86
53112210
53112210
53112210
53112210
53112210
53112210
53112220
53112220
53112230
0.202
0.210
0.223
0.252
0.278
0.312
0.347
0.378
0.445
5.1
5.3
5.7
6.4
7.1
7.9
8.8
9.6
11.3
13
16
19
25
30
37
52
64
81
22
26
31
42
48
57
77
95
117
53112210
53112210
53112210
53112210
53112210
53112220
53112220
53112230
53112240
0.248
0.260
0.289
0.331
0.354
0.426
0.483
0.528
0.585
6.3
6.6
7.3
8.4
9.0
10.8
12.3
13.4
14.9
19
23
27
35
46
56
77
88
104
48
51
62
79
106
115
143
203
271
53112210
53112210
53112220
53112220
53112220
53112230
53112240
53112240
53112250
Part
Number
Number of
Conductors
18 AWG (1.00 mm2)
301802S
2
301803S
3
301804S
4
301806S
6
301808S
8
301810S
10
301815S
15
301820S
301825S
25
16 AWG (1.32 mm2)
301602S
2
301603S
3
301604S
4
301606S
6
301608S
8
301610S
10
301615S
15
301620S
301625S
25
Nominal Outer
Diameter
(in)
(mm)
Copper
Weight
(lbs/mft)
Approx.
Weight
(lbs/mft)
SKINTOP®
MS-SC
PG Thread
0.266
0.289
0.310
0.358
0.383
0.469
0.525
0.575
0.660
6.8
7.3
7.9
9.1
9.7
11.9
13.3
14.6
16.8
25
33
41
55
69
88
121
157
189
53
57
68
88
115
154
196
256
311
53112210
53112220
53112220
53112220
53112230
53112240
53112240
53112250
53112250
0.298
0.313
0.337
0.413
0.448
0.512
0.577
0.654
0.727
7.6
8.0
8.6
10.5
11.4
13.0
14.7
16.6
18.5
34
43
52
71
91
114
157
201
247
66
79
95
141
181
209
342
401
496
53112220
53112220
53112220
53112230
53112240
53112240
53112250
53112250
53112260
Recommended SKINTOP® assumes minimal OD variance. Additional configurations are available; please see our SKINTOP® section.
If not otherwise specified, all values relating to the product are nominal values. For current information go to our website.
205
很抱歉,暂时无法提供与“302206S”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 2500+23.379112500+3.03342
- 国内价格 香港价格
- 1+91.794041+11.91020
- 10+83.4332910+10.82540
- 25+75.0725425+9.74060
- 50+66.7118050+8.65580
- 100+58.35105100+7.57100
