SKINTOP®
UNCONTROLLED COPY
Strain relief cable glands
EMC cable glands
SKINTOP® MS-NPT BRUSH/MS-M BRUSH
Nickel-plated brass strain relief for EMC applications with NPT & metric thread
Complete the installation
SKINDICHT®
SM-PE locknuts
page 543
The SKINTOP® MS-NPT/MS-M BRUSH provides centered, fixed strain relief
with a liquid-tight and dust-proof seal, all in one step. Simply insert the cable,
push the braid shield under the innovative EMC brush, tighten the cap, and the
connection is made. Plus sizes offer extra large clamping ranges.
Application advantage
• Faster, easier, reliable cable shield contact
• Maximum assembly and adjustment possibilities
•3
60° contact area allows for optimal low-resistance
current return ground path
Approvals: NPT
•M
75 - M110 feature an innovative double lamellar gasket
for easier assembling of cables with large diameters.
Approvals: metric
Technical data
Material:
- body:
- brush:
- insert:
- bushing:
- O-ring:
Protection:
- NPT: IP68, 10 bar
IP69 (does not apply to NPT 2" plus)
NEMA 1, 4X, 6, 12
nickel-plated brass
brass
polyamide
special elastomer
special elastomer
(does not apply to NPT 2” & 2” plus)
- metric: IP68, 10 bar
IP69
Locknuts: add SKINDICHT® SM-PE-M
for metric glands, page 543
(does not apply to M63 plus & larger)
NEMA 1, 4X, 6, 12
(does not apply to M75 & larger)
Temperature range:
- static: -40°C to +100°C
- dynamic: -25°C to +100°C
Part
number
NPT
53112037
53112047
53112057
53112067
53112077
53112087
Metric
53112676
53112677
53112678
53112679
53112680
53112681
53112501
53112500
53112503
53112505
53112504
in
mm
Wrenching flats
(SW)
in
NPT ¾"
NPT 1"
NPT 1¼"
NPT 1½"
NPT 2"
NPT 2", plus
0.354 - 0.669
0.433 - 0.827
0.748 - 1.103
1.063 - 1.379
1.339 - 1.773
1.733 - 2.167
9 - 17
11 - 21
19 - 28
27 - 35
34 - 45
44 - 55
1.142
1.418
1.773
2.127
2.639
2.955
1.694
1.891
2.265
2.323
2.482
2.836
0.591
0.591
0.669
0.669
0.669
0.669
0.236
0.315
0.394
0.551
0.787
0.984
10
1
1
1
1
1
M25 x 1.5
M32 x 1.5
M40 x 1.5
M50 x 1.5
M63 x 1.5
M63 x 1.5, plus
M75 x 1.5
M75 x 1.5, plus
M90 x 2.0
M110 x 2.0
M110 x 2.0, plus
0.354 - 0.669
0.433 - 0.827
0.748 - 1.103
1.063 - 1.379
1.339 - 1.773
1.733 - 2.167
2.088 - 2.482
2.285 - 2.679
2.600 - 3.073
2.994 - 3.467
3.388 - 3.861
9 - 17
11 - 21
19 - 28
27 - 35
34 - 45
44 - 55
53 - 63
58 - 68
66 - 78
76 - 88
86 - 98
1.142
1.418
1.773
2.127
2.639
2.955
3.743
3.743
4.531
5.319
5.319
1.418
1.663
2.344
2.049
2.415
2.719
4.137
4.137
5.339
6.068
6.068
0.315
0.354
0.354
0.394
0.591
0.591
0.591
0.591
0.788
0.985
0.985
0.236
0.315
0.394
0.551
0.788
0.985
1.379
1.379
1.773
2.167
2.167
10
1
1
1
1
1
1
1
1
1
1
Thread
Clamping range (øF)
Overall length
(C)
in
Thread length
(D)
in
Min ø
above braiding
in
Pack
size
If not otherwise specified, all values relating to the product are nominal values.
Photographs are not to scale and are not true representations of the products in question.
524
for current information see: www.lappusa.com • www.lappcanada.com
很抱歉,暂时无法提供与“53112677”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+391.69253
- 50+384.83606
- 100+380.58409
- 国内价格 香港价格
- 1+594.485581+76.90579
