7038865
7038865
    LAPP(缆普)
    LAPP KABEL - 7038865 - Multicore Cable, Sensor Actuator, Unscreened, 4 Core, 22 AWG, 164 ft, 50 m
7038865 数据手册
UNITRONIC® Bus Cable & Connectors Sensor & Actuator Wiring UNITRONIC® SENSOR FD Multi-Conductor Continuous Flex Communication Cable with PUR Jacket; 300V Unshielded Construction LAPP KABEL Conductors: Super fine stranded bare copper UNITRONIC® SENSOR FD Insulation: Polypropylene LAPP KABEL Jacket: Halogen-free polyurethane; black UNITRONIC® SENSOR FD UNITRONIC® SENSOR FD is designed for sensor and actuator wiring. Constructed with extra-fine stranding, this cable is suitable for continuous flex applications. The abrasion- and tear-resistant PUR jacket provides superior service life in harsh environments and is also resistant to most oils, solvents, and coolants. Insulation: Polypropylene Shielding: Tinned copper braid Jacket: Halogen-free polyurethane; black Recommended Applications Wiring of sensors and actuators; data transmission cables to connect to M8 or M12 connectors; automation technology; plant engineering Approvals Cable Attributes Shielded Construction Conductors: Super fine stranded bare copper page 640 OIL OR-04 FLAME FR-01 MOTION CF-02 MECH. MP-05 Application Advantage • Designed for continuous flexing • Highly flexible construction for ease of routing in tight spaces • Excellent abrasion and cut resistance • Outstanding oil, solvent, and coolant resistance • Round geometry facilitates liquid-tight installation ÖLFLEX® CONNECT Solution Complete the Installation SKINTOP® Strain Relief page 488 SKINTOP® MS-SC page 516 ÖLFLEX® CONNECT CABLES page 597 Technical Data Minimum Bend Radius: - for stationary use: 5 x cable diameter - for continuous flexing: 10 x cable diameter Temperature Range: - for stationary use: -40°C to +80°C - for flexible use: -15°C to +80°C Color Code: - 3 conductors: 1: Brown, 2: Blue, 3: Black - 4 conductors: 1: Brown, 2: White, 3: Blue, 4: Black - 5 conductors: 1: Brown, 2: White, 3: Blue, 4: Black 5: Gray - 8 conductors: 1: White, 2: Brown, 3: Green, 4: Yellow, 5: Gray, 6: Pink, 7: Blue, 8: Red Nominal Voltage: 300V Part Number 24 AWG (0.25 mm2) 7038867 7038868 22 AWG (0.34 mm2) 7038864 7038865 7038866 7038885 7038886 7038887 Approvals: (in) (mm) Copper Weight (lbs/mft) Unshielded Unshielded 0.185 0.232 4.7 5.9 8 13 23 34 S2107 S2107 — — Unshielded Unshielded Unshielded Shielded Shielded Shielded 0.181 0.185 0.201 0.181 0.185 0.201 4.6 4.7 5.1 4.6 4.7 5.1 7 8 11 13 16 18 20 27 30 79 88 97 S2107 S2107 S2107 — — — — — — 53112210 53112210 53112210 Number of Conductors (incl. ground) Shielding 5 8 3 4 5 3 4 5 Nominal Outer Diameter UL: AWM 20549 Additional: RoHS Approx. Weight (lbs/mft) SKINTOP® Non-Metallic PG Thread SKINTOP® MS-SC PG Thread Recommended SKINTOP® assumes minimal OD variance. Additional configurations are available; please see our SKINTOP® section. If not otherwise specified, all values relating to the product are nominal values. Photographs are not to scale and are not true representations of the products in question. For current information go to our website. 198 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com
7038865 价格&库存
很抱歉,暂时无法提供与“7038865”相匹配的价格&库存,您可以联系我们找货
