601807
601807
    LAPP(缆普)
    7 芯 多芯 线缆 灰色 18AWG 在订单数量中输入英尺数
601807 数据手册
ÖLFLEX® Flexible Power & Control Cable UL/CSA PVC Cable ÖLFLEX® 190/190 CY Extremely Oil-Resistant Flexible Control Cable with UL MTW; Unshielded & Shielded Unshielded Construction LAPP KABEL Conductors: Finely stranded bare copper ÖLFLEX 190 ® Insulation: Specially formulated PVC/nylon Jacket: Specially formulated PVC; gray LAPP KABEL ÖLFLEX® 190 CY ÖLFLEX® 190 is a multi-conductor cable with a highly oil-, coolant-, and solvent-resistant PVC jacket for control and power applications in an industrial environment. It is designed for use in all electrical equipment under dry, damp, and wet conditions. ÖLFLEX® 190 CY is a shielded version for EMI and RFI protection. Shielded Construction Conductors: Finely stranded bare copper Insulation: Specially formulated PVC/nylon Shielding: PVC inner jacket; tinned copper braid (85% coverage) Jacket: Specially formulated PVC; gray Application Advantage Recommended Applications CNC machining centers; grinding machines; bottling equipment; conveyors; processing equipment; assembly lines; control panels Approvals • Extremely oil-resistant (Oil Res I & II) • Meets NFPA 79 machinery wiring standard • Very flexible and number-coded for easy routing and termination • Round jacket for optimal seal with a SKINTOP® strain relief cable gland F IRE PROTECTION Cable Attributes page 640 OIL OR-04 FLAME FR-02 MOTION FL-02 MECH. MP-02 Complete the Installation SKINTOP® Strain Relief page 488 EPIC® Connectors page 280 Technical Data Minimum Bend Radius: - for installation: 4 x cable diameter - shielded: 6 x cable diameter Temperature Range: - for stationary use: -40°C to +90°C - for flexible use: -5°C to +90°C Nominal Voltage: - UL MTW/CSA AWM: 600V - UL AWM: 1000V Color Code: Black with white numbers, plus green/yellow ground Approvals: UL: MT W per UL 1063 (P/Ns with * are not MTW) AWM 2587 & 21098 (Oil) Attributes: UL Oil Res I/II NFPA 79 Canada: CSA AWM I/II A/B FT1 CSA C22.2 210.2 Additional: Passes Impact and Crush tests per UL 1277 (excluding 20 AWG) CE & RoHS Test Voltage: 2000V Conductor Stranding: - 20 - 6 AWG: Class 5 fine wire* - 4 AWG and larger: - MTW: Class K fine wire - AWM only: Class 5 fine wire * 18 AWG meets only Class 5 cross section and DC resistance If not otherwise specified, all values relating to the product are nominal values. Photographs are not to scale and are not true representations of the products in question. For current information go to our website. 30 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com ÖLFLEX® UL/CSA PVC Cable Flexible Power & Control Cable ÖLFLEX® 190 Part Number Number of Conductors (incl. ground) 20 AWG (0.50 mm²) 602002** 2 602003 3 602004 4 602005 5 602007 7 602009 9 602012 12 602018 18 602025 25 18 AWG (1.00 mm²) 601802** 2 601803 3 601803NG 3 601804 4 601805 5 601807 7 601809 9 601812 12 601818 18 601825 25 601834 34 621834* 34 601841 41 621841* 41 601850 50 621850* 50 16 AWG (1.50 mm²) 601602** 2 601603 3 601604 4 601605 5 601607 7 601609 9 601612 12 601618 18 601625 25 601634 34 621634* 34 601641 41 * Part numbers are not MTW Nominal Outer Diameter (in) (mm) Copper Weight (lbs/mft) Approx. Weight (lbs/mft) SKINTOP® Non-Metallic PG Thread 0.253 0.265 0.285 0.308 0.331 0.409 0.421 0.487 0.586 6.4 6.7 7.2 7.8 8.4 10.4 10.7 12.4 14.9 7 10 13 17 23 30 39 59 82 40 42 51 60 82 100 168 198 242 S1109 S1109 S1111 S1111 S1111 S1113 S1113 S1116 S1121 0.277 0.291 0.291 0.314 0.340 0.367 0.454 0.471 0.579 0.656 0.937 0.783 1.041 0.846 1.092 0.961 7.0 7.4 7.4 8.0 8.6 9.3 11.5 12.0 14.7 16.7 23.8 19.9 26.4 21.5 27.7 24.4 13 20 20 26 33 46 59 79 118 164 206 232 250 289 305 336 42 44 44 55 64 84 119 141 207 278 575 475 680 541 825 697 S1111 S1111 S1111 S1111 S1111 S1111 S1113 S1116 S1121 S1121 S1129 S1129 S1136 S1129 S1136 S1129 0.303 0.319 0.345 0.375 0.406 0.509 0.557 0.644 0.733 1.020 0.925 1.101 7.7 8.1 8.8 9.5 10.3 12.9 14.1 16.4 18.6 25.9 23.5 28.0 20 29 39 49 68 88 112 175 242 296 339 357 57 62 75 90 121 174 209 298 417 760 652 875 S1111 S1111 S1111 S1111 S1113 S1116 S1121 S1121 S1129 S1136 S1129 S1136 ** 2c cable does not include ground † Part Number Number of Conductors (incl. ground) 621641* 41 601650 50 621650* 50 601661 61 621661* 61 14 AWG (2.50 mm²) 601402** 2 601403 3 601404 4 601405 5 601407 7 601409 9 601412 12 601418 18 601425 25 12 AWG (4 mm²) 601203 3 601204 4 601205 5 601207 7 601211 11 10 AWG (6 mm²) 601003 3 601004 4 601005 5 8 AWG (10 mm²) 600804 4 600805 5 6 AWG (16 mm²) 600604 4 600605 5 4 AWG (25 mm²) † 600404 4 620404* 4 600405† 5 620405* 5 2 AWG (35 mm²) † 600204 4 620204* 4 † 600205 5 Nominal Outer Diameter (in) (mm) Copper Weight (lbs/mft) Approx. Weight (lbs/mft) SKINTOP® Non-Metallic PG Thread 0.988 1.192 1.079 1.265 1.142 25.1 30.3 27.4 32.1 29.0 407 437 504 530 591 768 1020 911 1180 1036 S1136 S1136 S1136 S1248 S1136 0.337 0.356 0.386 0.421 0.457 0.609 0.628 0.729 0.872 8.6 9.0 9.8 10.7 11.6 15.5 16.0 18.5 22.1 33 49 65 81 113 145 194 290 404 88 93 121 145 192 317 401 575 860 S1111 S1111 S1113 S1113 S1113 S1121 S1121 S1129 S1129 0.417 0.454 0.497 0.573 0.745 10.6 11.5 12.6 14.6 18.9 78 104 129 181 284 156 198 238 363 397 S1113 S1113 S1116 S1121 S1129 0.492 0.570 0.623 12.5 14.5 15.8 116 155 194 223 267 322 S1116 S1121 S1121 0.695 0.764 17.7 19.4 258 323 436 525 S1129 S1129 0.870 0.955 22.1 24.3 413 516 699 842 S1129 S1129 1.118 0.976 1.228 1.094 28.4 24.8 31.2 27.8 515 646 645 807 950 863 1200 1105 S1136 S1136 S1248 S1136 1.292 1.091 1.422 32.8 27.7 36.1 876 904 1129 1405 1165 1752 S1248 S1136 S1142 4 AWG cable is built with 21 mm² cross-section. 2 AWG cable is built with 33.7 mm² cross-section ÖLFLEX® 190 CY Part Number Number of Conductors (incl. ground) 20 AWG (0.50 mm²) 602002CY** 2 602003CY 3 602004CY 4 602005CY 5 602007CY 7 602012CY 12 602025CY 25 18 AWG (1.00 mm²) 601802CY** 2 601803CY 3 601804CY 4 601805CY 5 601807CY 7 601812CY 12 601818CY 18 601825CY 25 16 AWG (1.50 mm²) 601603CY 3 601604CY 4 601605CY 5 601607CY 7 601612CY 12 601618CY 18 601625CY 25 Nominal Outer Diameter (in) (mm) Copper Weight (lbs/mft) Approx. Weight (lbs/mft) SKINTOP® MS-SC PG Thread 0.329 0.341 0.361 0.384 0.407 0.497 0.678 8.4 8.7 9.2 9.8 10.3 12.6 17.2 25 30 35 41 51 73 139 66 82 88 99 112 181 295 53112220 53112220 53112220 53112230 53112230 53112240 53112260 0.353 0.367 0.390 0.416 0.443 0.586 0.678 0.764 9.0 9.3 9.9 10.6 11.3 14.9 17.2 19.4 28 40 48 57 94 153 216 226 75 82 106 123 139 229 317 436 53112220 53112230 53112230 53112230 53112240 53112250 53112260 53112260 0.395 0.421 0.451 0.482 0.656 0.743 0.897 10.0 10.7 11.5 12.2 16.7 18.9 22.8 52 66 76 98 167 235 313 115 128 150 181 311 456 639 53112230 53112230 53112240 53112240 53112250 53112260 53112260 * Part numbers are not MTW Part Number Number of Conductors (incl. ground) 14 AWG (2.50 mm²) 601403CY 3 601404CY 4 601405CY 5 601407CY 7 601412CY 12 601418CY 18 12 AWG (4 mm²) 601203CY 3 601204CY 4 601205CY 5 601207CY 7 10 AWG (6 mm²) 601003CY 3 601004CY 4 601005CY 5 601007CY 7 8 AWG (10 mm²) 600804CY 4 6 AWG (16 mm²) 600604CY 4 4 AWG (25 mm²) 620404CY* 4 2 AWG (35 mm²) 620204CY* 4 Nominal Outer Diameter (in) (mm) Copper Weight (lbs/mft) Approx. Weight (lbs/mft) SKINTOP® MS-SC PG Thread 0.432 0.462 0.497 0.572 0.736 0.905 11.0 11.7 12.6 14.5 18.7 23.0 75 93 115 147 253 361 148 181 218 282 516 741 53112230 53112240 53112240 53112250 53112260 53112260 0.500 0.585 0.628 0.672 12.7 14.9 16.0 17.1 124 154 180 234 227 311 359 494 53112240 53112250 53112250 53112260 0.623 0.669 0.731 0.786 15.8 17.0 18.6 20.0 164 208 255 335 311 386 474 639 53112250 53112250 53112260 53112260 0.803 20.4 324 574 53112260 0.994 25.2 494 1115 53112270 1.133 28.8 777 1153 53112270 1.247 31.7 1051 1987 53112270 ** 2c cable does not include ground Recommended SKINTOP® assumes minimal OD variance. Additional configurations are available; please see our SKINTOP® section. If not otherwise specified, all values relating to the product are nominal values. For current information go to our website. 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com 31
601807 价格&库存
很抱歉,暂时无法提供与“601807”相匹配的价格&库存,您可以联系我们找货
  • 5000+19.477615000+2.51636
  • 1+42.989151+5.55387
  • 5+38.395235+4.96037
  • 10+36.5696310+4.72452
  • 25+34.2651925+4.42680
  • 50+32.6065550+4.21252
  • 100+31.01749100+4.00722
库存:6628
